Question about JVC HM-DH40000U VHS/S-VHS playback VCR
JVC HM-DH40000U VCR PM light blinking - JVC HM-DH40000U VHS/S-VHS playback VCR
How do i get the code to program a jvc tv wth my universal remoteserrial # rc24922-c1122
Do a code search method as follows.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Dec 26, 2014 | Universal Remote Control Televison & Video
Need the code to program my universal remote to my jvc tv the serial# to my remote is rc24922-c1122 model jc024
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Dec 26, 2014 | GE 24926 Glow Keys Universal Remote...
Programing jvc remote control 076NOES010
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
    Code Search Method
Apr 19, 2012 | JVC YQ20932 Remote Control
Vcr won't accept tape for recording
Check that the recording tab has not been removed.
If it has, use a small piece of masking tape to cover the hole.
Apr 06, 2011 | JVC HM-DH30000U DVHS VCR
It keeps blinking "loading" and
theres trash inside vcr you will need tape cleaner to clean out vcr.
Mar 01, 2011 | JVC SR-MV40 DVD Recorder/VCR
What is the universal remote code for JVC AV27D302
Hello
Four Digit Universal remote codes for JVC are:-
0060 _0026_ 0197_ 0069_ 0247_ 0923_ 0012_ 0065_ 0067_ 0141_0048
Three digit Universal Remote Code for JVC are:-
013/ 054/ 055/ 060/ 065/ 067/ 089
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Nov 20, 2010 | JVC AV-27D302 27" TV
How to set up auto clock on a jvc vcr
When you have it on VCR mode you can bring up the menu and set the clock.
Nov 25, 2009 | JVC HR-XVC27U DVD Player/VCR
Capture HM-DH5U Video into CS4 Premiere Pro
Personaly I would use either windows movie maker, nero, or the applicatiom that came with the camera just to get it to the PC.
From there It would be easier to edit etc.
Aug 14, 2009 | JVC HM-DH5U 35-Hours Video Recorder
JVC HM-DH40000U VHS/S-VHS playback VCR Logo
56 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
