Health & Beauty Logo
A
Anonymous Posted on Dec 29, 2013
Crazy fit massage rc-cfm-002 instruction manual
4 Related Answers
Anonymous
  • Posted on Aug 04, 2009
SOURCE: cant find manual for crazy fit machine power plate
Here's the manual: http://www.pycfitness.com/New_Product/instruction-manual.pdf
Anonymous
  • Posted on May 18, 2011
SOURCE: manual for crazy fit massage
I have a Crazy Fitmassage but I dont know how to program the machine,help me
ka4iup
ka4iup
  • 4062 Answers
  • Posted on Mar 23, 2015
SOURCE: Burning smell and cutting off use when using the crazy fit massage by prestige. Any advise?
Stop using immediately. There is a problem that can cause fire or electrical shock if used. Have this unit checked by a service technician.
99rannellis
R.A. Ellis
  • 12731 Answers
  • Posted on Nov 03, 2016
SOURCE: how do I take the plate of my crazy fit massage machine
And what does this have to do with a sewing machine?
Who can replace the belt on my crazy fit massage machine as hit broke. Lives in Gauteng
So you live in South Africa. Find the maker of the massage machine and look them up. There should be a name somewhere on the machine.
I have a crazy fit power massage machine and it cuts off when u turn up to level 6 .
Why not try the contact at the web page for the machine. They may have an answer.
Crazy Fit Vibration Plate for Home Crazy Fit Massage
I noticed the following article as I was Googling information about this machine. It probably predates this machine. Just something to think about.
Shake your way to skinny Experts fear risks
The motor of crazy fit vibration massage does not work, only the panel lights light up
Without knowing what vehicle you have it is not likely anyone can advise you.
Why does my crazy fit massage vibrates violently as soon as you turn it on
It would be helpful to have more detailed info, but I;ll take a stab
at it... Usually, when a motorized device vibrates voilently (more
than designed to), it is due to missing parts or being out of
balance in the recriprocating mechanism. Try going over the
machine, again, with this in mind. If you can find another working
machine, make a comparison (perhaps in a local gym?)
Good luck !
2answers
Crazy fit won't stop vibrating when it has power to it
1) You must test the switch stop.
see the diagram for to fix it.
I have a crazy fit machine 2010 model, however the belt keeps removing itself, does anyone know how to adjust this please?
Just make sure that the belt is inside of the grooves on the white wheel. That should do the trick. Or ask prestige they will sort it out for you,they are a excellent firm.
22helpful
2answers
Manual for crazy fit massage by action fitness
Instruction manual
Hi SJ, I don't think you need to worry too much about using the massager; you pretty much just plug it in and go from there (assuming you're in the US). Don't use it more than 20 minutes and don't use it while bathing. Additionally, should not use the massager on
  1. sensitive or inflamed skin
  2. varicose veins
  3. the front of your neck
  4. **** areas
  5. sleeping people
You can also check out their attachments and see what they're used for at their website: http://consumer.wahl.com/product.cfm?sid=13&ID=30. If you still would like the booklet, message me at jjones at thesexsite dot com and I'll scan it for you. Hope this helps, Johnathan
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
