Question about Toshiba 19HLV87 19 in. LCD HDTV
Using a computer monitor - Toshiba 19HLV87 19 in. LCD HDTV
We use it as a computer monitor, but screen turns blue after about 3-4 min if that...you can still see the screen it's just blue and very blurry bc it moves like the screen is goin out on it?
What monitor you used before? If this is first monitor for your computer - you must look computer settings, if computer worked with another monitor - you must look monitor settings.
Jun 03, 2015 | Computers & Internet
Dell E2009W Monitor has no signal with my computer
It could be that the monitor is defective. Try using it in a different computer. All monitors are compatible on any computer.
David
Apr 24, 2013 | Dell E2009W 20 FlatPanel Widescreen...
My monitor comes on for a few seconds then goes off how can i fix that
Check to make sure that the power cable and computer cable are secure. Im not sure how many options your monitor has, but here are some troubleshooting tips:
  • Try plugging a different computer into the monitor using the same connector
  • Try plugging a different device into the monitor using a different connector (TV, Etc)
  • Try plugging the same computer into the monitor using a different kind of cable (if option is available)
If another computer works then it is the computer and not the monitor, if a different connector works (HDMI or RGB instead of VGA) then it is the connector. If another computer or another connector results in the same problem then the monitor is likely faulty and will need to be repaired by a professional or replaced.
Mar 14, 2011 | ViewSonic Computers & Internet
I am using a new computer and I have lost the disc for my monitor to use on this computer. Is there a Samsung site that I can go to do download the drivers I need for this computer. it is SyncMaster...
There are no drivers on the Samsung site that I could find.
That said, you don't need drivers for your monitor. If your monitor isn't displaying anything with your new computer, try turning your computer completely off, make sure your monitor is turned on and plugged in to the computer, then turning the computer back on. Windows should automatically detect what resolutions the monitor supports and your monitor should start working.
Mar 07, 2011 | Samsung SyncMaster 512N 15" Flat Panel LCD...
I have an Acer Monitor X223w - is it capable of hooking up as a douple monitor to one computer?
Any monitor can be used as the second monitor for a computer. However, your computer's graphics card must have two outputs. Some simpler graphics cards, most on-board video chipsets and all laptops *do not have* two outputs. Please check the back of your computer for two VGA outputs, or one VGA and one DVI output (you can use it by connecting a DVI cable to your monitor, or by plugging in a DVI to VGA adapter).
If your graphics card does not have two outputs, or if your computer uses an on-board video chipset, you can buy another graphics card to replace the one you're using.
Mar 03, 2011 | Acer 22" X223w LCD Monitor
Turns off automatically within 4-5 seconds after I started
First attempt to use a different monitor on your computer, or use this monitor on another computer. If it appears that monitors only shut off when attached to your computer then it's safe to assume that you have a graphics card issue, not a monitor issue. If your monitor shuts off on another computer then your monitor is basically broke. To try to troubleshoot the graphics card, unplug your monitor from the computer and the wall. Now unplug your computer from the wall, open up your computer case and remove the graphics card. Using a can of compressed air, blow out all of the dust in the computer. Reinsert the graphics card, close the case, plug the monitor back into your computer and the wall and start the computer again. Hope this helps.
Dec 14, 2010 | LG Flatron L1751S-SN 17" Flat Panel LCD...
Monitor will not respond to computer.
TRY UNPLUGGING MONITOR FOR APROX10 MINS AND RETRY
Dec 12, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
Replacement AC/DC cord to power up my 1730B comp monitor
You cannot use a VGA cord to power a monitor. That is the cord that connects the monitor to the computer and is not the power cord. Almost all monitors use the exact same 3 prong power cord. Any computer shop will have a used one on hand.
Sep 06, 2009 | Solarism LM-1730 (Black) 17 in. Flat Panel...
HP desktop monitor problem
hi try this ,,,
  1. Ensure the video cable is connected (and connected to the correct video port).
  2. Turn off the monitor using the monitor's power button and then restart the monitor.
  3. Cycle the power on the monitor as follows:
  4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
  5. Unplug the power cord.
  6. Wait 5 seconds.
  7. Plug in the power cord.
  8. Press the power button on the monitor to turn on the monitor. One of two things happens:
    1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
    2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
    3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
      • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
      • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
      hope it will work for u .. little_angel
Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Toshiba 19HLV87 19 in. LCD HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
