Question about Boating
Yamaha c50tlry stalls (2000)
My 2000 Yamaha c50 tlry stalls. It will run for about 3 minutes then stalls. Carburetors have been cleaned by a boat mechanic and even he is stumped as to why it keeps stalling. Electrothermal switch has been tested, it is working.
  • 451 Answers
If the thermal switch is working it could indicate the motor is overheating check to make sure the water pump is operating correctly and the intake is not clogged. Hope this helps.
Posted on Dec 29, 2013
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: cant get choke to operate on C50TLRY 2000 50 hp 2
Check choke itself to make sure it moves freely. Adjust the cable and spring if necessary. If the choke is controlled by a vacuum controlled actuator, make sure it is not leaking or loose pressure
Posted on Sep 09, 2009
My 1985 4-winns mercruiser 4 cylinder boat runs great for twenty minutes to a half hour then the motor misses and stalls out. After about thirty minutes the boat starts back up and runs great for anot
Check the torque on the head bolts. I can't tell you what it is, been a long time. If they are good, run it till it dies. Then check for spark at the plugs or coil/s. No spark replace the coil/s. My guess would be coils. But I have seen the head loosen up.
Sep 28, 2014 | Seloc Tune Up Repair Manuals Type...
Where is the yamaha v star idle jet
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Where is the yamaha star idle jet Google Search
Yamaha Star Carburator Cleaning
98 00 Yamaha XV650 Star Service Manual XVS650 Moto Data Project
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Jun 30, 2014 | 2004 Yamaha V Star Classic
Why does my r1 start but shut off?
Hi, Anonymous and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
07 R1 starts but doesnt stay running
2007 2008 Yamaha R1 Stalling Problem Fix How to
2000 2001 Yamaha YZF R1 Service Manual R1 Moto Data Project
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 03, 2014 | 2000 Yamaha YZF-R1
My rc51 1000 starts fine, idles fine,but occasionally when switching gears it will stall, when i pull back on throttle between gears, thats when it stalls, but every time it starts right back up on the...
The problem is most likely clogged idle jets. The solution would be to mix some additive, like B12 or Sea Foam, with your gasoline and go for a ride. You want to make sure you ride enough to get the gas into your carburetors. While riding, the additive will clean your carbs, but when you park the bike with the engine off is when it will start soaking into your idle jets. Depending on how clogged they are, it may take a while. The alternative is to remove the carbs, and clean the idle jets. I would try a couple of ounces of cleaner per gallon of gas and then ride it around and see how it works. It has worked for me 3 out of 4 times. Good luck!
Aug 20, 2013 | 2000 Yamaha YZF Thunder ace 1000 R
XVS 1700 Silverado stalling issues
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
The At witt End Backfire Cure
http://wemakeitsafer.com/vehicle-recall/Yamaha-Xv1700-Recall-2468518
http://www.rswarriordocs.com/manuals/WarriorServiceManual-WO3646.pdf
Yamaha XV17ATMV Road Star Owner Manual
Jul 06, 2013 | 2006 Yamaha Road Star Silverado
Yamaha sr125 shudders then stalls when accelerating
Hi, Tybeale and the usual suspects are:
13. Multi carburetors not in sync.
Yamaha SR125 cutting out HELP
2002 50cc Yamaha Vino Stalling on Acceleration 49ccScoot com Scooter Forums
Yamaha SR125 1997 Service Manual
YAMAHA SR125 Owner Manual
Feb 12, 2013 | Yamaha Motorcycles
2000 Yamaha YZ 80 poor idling
Hi, Shaundavies6 and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yz 80 2001 model Carburetor tunning Trouble
Life On 2 Wheels
Yamaha YZ80 service manual repair 2001 YZ 80 YZ80LW Download Manuals... $8 cheap
Oct 24, 2010 | Yamaha Motorcycles
Cant get choke to operate on C50TLRY 2000 50 hp 2
Sep 09, 2009 | Boating
Hesitation
if it sat for 4 years with gas in the carburetors you will have to clean them--that goo in them will keep breaking up and stop up everything.
Nov 10, 2008 | 1990 Yamaha FZ 750 KS (Europe)
Boating Logo
71 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
