Question about Miele W1926A Front Load Washer
How to unstack w1926 and T1526
Putting top back on
How to use stackable washer and dryer if unstacked
stacking was just a gimmick to save space
put the drier on a suitable stand , table or it is possible that there are holes in the back section for a mounting bracket to hang it on a wall
Sep 30, 2016 | Washing Machines
How to put top back on miele w1926
1 Remove stacking kit from top of unit.
2 Reatach the two plastic clips to the back of washer.
3 engage the two slots on the washer top into the clips , pull forward drop lid down on top of washer then secure with two screws on either side of lid.
Dec 29, 2013 | Miele W1926A Front Load Washer
Thanks I thought it might be the inlet valve, but to get access to it behind the top panel, Is there a trick to removing the panel? I have removed the three screws behind the detergent drawer but the panel...
Hi, you will need to unstack the dryer unfortunately, then remove the three screws at the back of the top washer panel and it will slide back about 2 or 3cm and up away from the unit. Then you will see how to remove the valve. Hope that answers your question. Thanks for visiting "fixya". Let me know if you require any further assistance and good luck. Macmarkus :)
Jun 17, 2010 | Asko W6021 Front Load Washer
Unstacking the dryer
it just slide on and off and is help by two screws on the back of the lid
Apr 10, 2010 | Frigidaire GLTF2940ES Front Load Washer
The gasket is torn
Hello. The seal swap isn't too difficult. You may have to unstack. If the washer is on the bottom, you may be able to scoot the dryer back enough to make the repair, but the washer case is like a cabinet; each part depends on the other parts for rigidity. For this reason alone, it would be much safer without several hundred pounds above your head. I'd unstack. That said: You can certainly diy. Unplug the washer. With the door open, look at the bottom of the seal. You'll see a ring clamp. Loosen the screw and remove the clamp. Peel the seal inward. It is easier to complete the seal swap with the front off. Remove the door and set aside. Locate the screws for the front of the machine and remove them, gaining access to the seal. Youcan either set the door to the side with the door lock wires still attached, or unclip them, which is easier. With the seal folded inward, you will likely find another clamp at the bottom. Loosen this as well. Remove the seal and replace with the new one, making sure to orient it like the old one was, and fold it to the inside like you had the old one for removal. Replace the front panel. Complete the seal installation, being careful to make sure that the clamp removed earlier gets put back in the groove and seats well. Reinstall the door. Best Regards, --W/D--
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Miele W1926 washer makes a banging sound when it spins
if i were you fist of all open door then you will see the silver drum on the inside lift the silver drum upwards from the top of it and if you feel a knocking sound then the bearings have worn out expencive to replace them,as sometimes you have to have a complete new drum.rgrds,paul
Jul 07, 2009 | Washing Machines
Remove front of LG DLE3777 Dryer
The dryer front is usually held on by two screws in the cabinet just under the top of the dryer. Yes, they'll have to be unstacked and the top on the dryer popped loose to access these screws.
Apr 04, 2009 | LG DLE3777 Electric Dryer
How to unstack a dryer
I have a Kenmore 417.69042990 stackable dryer and had a similar problem. To unstack it, in the front of the dryer there are two screws that are covered by round caps. They are easy to miss unless you look for them. Remove the caps, and the screws underneath it. Now, voila, you can lift the front of the dryer and pull as to unlock it from the two brackets in the rear of the dryer. Hope this helps... I took me and my husband over an hour to figure this out...
Nov 11, 2007 | Dryers
HOW TO UNSTACK A WASHER AND DRYER
Chainsaw, no seriously the dryer is bolted to the washer and not all of them can be unstacked. Remove the front panel of the dryer to expose the bolts holding it down. this only works if your washer is of the front loading type. if it is a top loader there should be some sort of frame the dryer is bolted to. after removing the dryer from a front load stack washer, the washer may or may not have a top panel on it
Sep 02, 2007 | Dryers
Miele W1926A Front Load Washer Logo
35 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
