Question about Karcher 2500 PSI Pressure Washer
7HP Honda G300 Starting Problem
I have a G300 7 HP honda engine that will not start unless you remove the air cleaner. I have put a new carb on it, new plug, and new air cleaner. Air cleaner is an oil bath type with a foam rubber insert along with oil in the bottom of the filter housing. This problem existed before replacing the air cleaner. Any help with this issue will be appreciated.
  • 18 Answers
SOURCE: Karcher 2400R
You have a poor signal to the spark plug usually caused by a rusty fly wheel found underneath the pullcord casing. clean it with releasing ajent such as wd 40. common when not in use for a while.
Posted on Sep 19, 2008
  • 92 Answers
SOURCE: % hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Regards,
MG.
Posted on Nov 05, 2008
  • 10865 Answers
SOURCE: i have a preesure washer with a honda motor. will
The air cleaner filter may need to be replaced. Also, it sounds like the carbeurator needs to be cleaned. Get a can of aerosol carbeurator cleaner and spray four or five quick bursts into the air cleaner while the filter is off. Run the pressure washer for 30 seconds to get the cleaner into the carberator. Then let it sit for a couple of hours and repeat the process.
Posted on May 07, 2009
  • 174 Answers
SOURCE: Pressure washer with 5hp Honda will ONLY run with choke on
It sounds like it has been tipped or too much oil has been put in. This would explain the oil in the air filter. First check the oil level. Then you need to clean the oil out of the carburetor. It is dirty or plugged and that is why it only runs when choked. You can try a spray-in carb cleaner but the best thing is to remove it (if you are handy enough) and soak it in varsol for 24 hours. Good luck
Posted on Aug 11, 2009
SOURCE: honda engine will not start,,,new plug, new gas,
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Posted on Jul 16, 2010
My 1987 honda helix wasn't starting and i discovered a blown fuse for the ignition. after replacing the fuse it cranks but will not turn over. the battery is fully charged and there is 1/4 tank of gas in...
Lets see is it fuel or spark? Pull a plug wire remove plug. Now clean plug with clean wire bush. Now put wire back on plug ground to engine crank and see if you have spark.
So you have spark it is now time to check fuel. Start by removing hose from petcock on tank and see if fuel comes out you could have a bad vale / switch got fuel. Remove air cleaner and give carb a shot of starting fluid see if it starts now.
Aug 10, 2010 | Honda CB 250 Motorcycles
Have a honda crf100f 4cycle got spark wont start,
CLEAN THE CARB AGAIN IF IT RUNS ON STARTING FLUID ITS NOT GETTING FUEL YOU WILL NEED TO REMOVE THE JETS AND MAKE SURE THEY ARE CLEAR
Jan 23, 2010 | 2002 Honda CR 125 R
Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Sep 14, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
Won't start, small engine guy said carburator needed to be flushe
Hi lackeyapda:
Fire Air Fuel
Remove the spark plug, plug it back into its wire. Hold it close to the metal frame WITH INSULATED PLIERS. Pull the cord and see if you get a spark. If no it is the coil, plug wire or a safety switch. If yes
put it back together. Take the air filter off. Spray some "easy start" or "carb cleaner " into the carburetor. Try starting. If it starts for a moment then dies, you do need to clean your carb.
Jun 30, 2009 | Honda Karcher G2400HH-R Pressure Washer
I have a honda g300 7hp engine that has no spark engine was going but has sat for a few years have changed plug but no differnce
Does this G300 have an oil alert switch??? If so, make sure it is on and verify engine oil level is full. Other wise, the switch will prevent the coil from sparking. If you find that the switch is faulty, you can by-pass it.
Jun 10, 2009 | Honda Garden
Honda powered gx160 model pressure washer wont start
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
Apr 12, 2009 | Honda 8 HP Engine
13HP honda engine
Try running without filter if ok clean filter and put back. This is and air/fuel mix problem,did you adjust idle screw??
Please rate. Thanks
Mar 31, 2009 | Northstar Garden
Karcher 2500 PSI Pressure Washer Logo
1,110 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
