Question about LG 42LH30 42 in. LCD TV
No power lg 32lh2000 - LG 42LH30 42 in. LCD TV
Hi, i got LG LCD.32LH2000. The screen blink two times and the screen go off again
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 30, 2012 | Televison & Video
Having same problem where TV standby light comes on and logo appears momentarily then TV does not come on fully (backlight it on slightly).
Hello
You have to troubleshoot from its backlight inverter board itself. That is the first possible cause tho this fault to LCD TVs. If backlight inverter board have shorted inverter transormer [wnding short], the inverter board will take tremendous current from power supply, and this can lead to a momentory logo display and then shut down. The second possiblility is with its main digital board. In both cases, the respective board should be replaced as card basis, as there is no repair to these boards.
Feb 23, 2012 | LG 32LH2000 32 in. HDTV-Ready LCD TV
My lg 32lh2000 switches on shows logo then turns of please help
That problem is on main board if you don't have sounds but if you have sounds the T-Con board is faulty not main board..
LG 32LH2000 My TV was turned of last night in the usual way, the power turned off on the remote control, then the power supply switched off and the plug removed. This morning I attached the power...
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Apr 16, 2011 | LG 32LH20 32 in. LCD HDTV
I want service manual for lcd lg 32 lh 200
Hello
There is no such model number you specifies here. 32LH2000 is there. I've the service manual of the said model. If you wants it, send me a mail and get it by return mail as an adobe acrobat document. gopakumarg43@ymail.com
OK.
Feb 04, 2011 | Televison & Video
What screws do i need to fit into back of my 32lg
I found a link to LG.Since I can't see where you are from and the site has the country all broke up,you can call the appropriate center.If you still have one of the screws that were removed,a local hardware store can easily match it up if you bring it in.Good luck!
http://www.lg.com/us/support/parts/support-find-parts.jsp
Jul 25, 2010 | LG 42PG20 42 in. Plasma HDTV
Need remotec remote control code to LG 32LH2000
Well first you can try - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
if none of the code works for you then please follow the below link to know how to search your sky remote code -
sky.com/portal/site/skycom/skyhelpcentre/producthelp
also check the below link -
skyuser.co.uk/tools/remotecodes/index.php
Good Luck!!
May 26, 2010 | Televison & Video
Need Sky Remote control code for LG 32LH2000 TV
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
http://www.skyuser.co.uk/tools/remotecodes/index.php
Please post comments if you need further help or information......
Good Luck!!
Mar 08, 2010 | LG 32LH20 32 in. LCD HDTV
LG 42LH30 42 in. LCD TV Logo
23 people viewed this question
Computer Repairing
Computer Repairing
