Question about GE WCVH6260FWW
Rubber seal, drainage seal on washer ruptured its about 3" thick.
Came home to find a big wet mess, it appears the big thick rubber seal that holds the drainage from our front loader is completely ruptured. Washer just had its 3rd birthday, am I covered under warranty or just parts and need to take care of labor costs. if I need to do it myself then so be it, but I need to know the part number which is not in my owners manual. A little help, please... washer is a GE wcvh 6260 fww
  • goldenbruin2 May 19, 2009
    its on the actual washer itself....the door is fine...as soon as you open the door, there is a grey gasket/seal where there are a few small holes for the water to go and get drained...that very gasket/seal or drainage which surrounds the entire opening is whats completely ruptured....no extended warranty so it appears that I will have to dish our for it....question is how to replace it myself then....hope the explanation of its location helps..
  • 245 Answers
Being 3 years old you will not be under any warranty. as far as the parts go any appliance shop with your model # will be able to get you the correct part. none of the appliance parts stores go by part number as these are constantly changing for better parts from the aftermarket then what the manufacturer used. so again just take your model # and call a few appliance parts company or even repair shops will sell parts as well.
Posted on May 19, 2009
  • jon fuller May 19, 2009
    yes i know what seal you are talking about. and to remove the front of the washer you will have to remove the door and then remove the front of the washer to get it out the seal runs from the outer tub to the front of the washer it is quite a job to get off and back on. and the part is quite pricey for the ge models plan on well over $100
    Sergeant:
    Champion:
  • 214 Answers
Where is the big seal on the outside of unit or inside?The part will not be covered 1 year on all parts or did you get extended warrenty?To order the part and do it yourself all you have to do is give the model number to your local parts depot and they can order part for you hope this helped:)
Where can I locate a 5"x 2" rubber donut for cast iron?
Old method was to tap thick rope/cord in and around the pipe finish with a seal of silicone
Apr 06, 2017 | Water Electrical Supplies
Tip
Washing Machine Hoses
When unhooking washer hoses from the washer or the wall supply, whether moving to a new home or working on your washing machine, always change the rubber seals where the hoses connect. The seals could have been overtightened causing them to tear slightly but could have sealed for years. Now that the hoses have been taken off they may not seal correctly and even a leaking drip from them can cause a big water problem in your home. ALSO, the rubber hoses that you can buy and the ones that come with your washer are usually labeled to change either within 3yrs. or 5yrs.. These hoses are prone to burst and I have customers that told me the horror stories of a faucet being turned on in their home. It is not pretty. Replace these hoses with either a nylon or steel braided hose for added assurance they do not burst before the time specified.
on Dec 13, 2009 | Washing Machines
Damp smell coming from inside machine and black thick slime inside rubber seal.
That thick black slime is called black mold. You need to do a major cleaning on your unit, including checking the water drainage hose to assure that the water is clearing all of the way out and is clean of builduo. Do not waste time in waiting to do this as it will only get worse. Disinfect, Disinfect, Disinfect. Good Luck.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Hotpoint Aquarius WD63 Front Load...
There are no instructions with the product. 1. Do I need Plumbers Putty to get a good seal on the sink drain hole? 2. There are 3 washers: 1 thick rubber washer; 1 thin rubber washer; and 1...
If you want to use the washers you place the thin rubber one on the top under the basket... then place the thick rubber one on the bottom first and then the paper washer...then turn tight...
If prefer either plumbers putty or clear silicone instead of the thin rubber one on the top...
heatman101
Jan 11, 2011 | Moen 22036 Stone Stainless Steel Sink...
There is water leaking down the electric wire at the bottom of the unit. What could cause this? the unit works just fine.
Once disposal rusts out, it needs replacement.
Usually if sink basket seal is broken or if dishwasher attachment is leaking, you can feel water near top of disposal.
Use paper towel at top to see if that area is wet.
If top area is dry, then water is coming from inside disposal, and disposal is rusted out.
If sink seal is still good, we used to buy same brand disposal and re-attach to same sink basket. That's the quick fix.
If this is inside your home, you probably want to install new sink basket that comes with disposal.
To install new disposal, also buy container of plumber's putty to seal sink basket.
Remove disposal.
Clean off old putty on sink. It will chip off easily.
Apply finger-thick amount of plumbers putty to sink opening.
Set disposal sink basket into putty and push down.
Tighten screws on bottom of sink basket.
Wipe away excess plumber's putty from sink so it looks nice and smooth.
Before lifting disposal into place, attach electric wires and attach dishwasher hose to disposal.
Use hammer and screwdriver to remove steel blocker located inside dishwasher stem ... the blocker is left in place if no dishwasher hose is attached.
Disposals can be different: But here's the usual sequence:
Lift disposal with one hand and hold level. Push up strong while rotating attachment ring until ring grabs bottom of sink basket.
If you cannot lift disposal with one hand while rotating attachment ring with other hand, use small bottle jack from auto-parts store. And put piece of wood between bottle jack and aluminum disposal so disposal doesn't break.
Here's how to handle tubular pipes below sink:
Any tubular pipe joint that moved while removing or installing disposal, has to be taken apart, cleaned and re-attached.
If washers are plastic, then clean and re-use.
If washers are rubber, then replace each washer with new rubber washer.
When reattaching tubular pipes, apply generous amount of rectorseal over each plastic or rubber washer for first-time seal of tubular pipes.
Nov 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Rubber washer for Model TSK-9368AP Blender
I just fixed mine with a rubber hose washer. I had to cut the washer in half because it was too thick, but it stopped the leak!
Mar 29, 2010 | Blenders
Washer squeals in rinse or spin
When the washer is in the final spin cycle and starts to sqeal, just pour a little water through the drawer about half of a glass full usually does the trick. What apparantly happens is that the connection/seal between the big grey rubber seal and the stainless steel drum has dried out due to the centrifugal effect of the spin cycle and it needs to be wetted to keep the sealed area lubricated and cool. The squealing is a result of the dry rubbing of these parts during the spin cycle.
Apr 17, 2009 | Washing Machines
Door seal wont drain
I would suggest using a blunt object to clear the drainage holes in the rubber seal. I'd advise against removing the seal for this problem. LG has special pliers to remove the spring loaded wire from around the front of the door seal and another for the larger size one where the rubber seal attaches to the outer drum. The second one is much harder to reattach, even somewhat difficult with the washer's front off if you do not have the special pliers.
Aug 23, 2008 | LG WM2487H Front Load Washer
Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Nov 30, 2007 | Hotpoint WMA64 Front Load Washer
GE WCVH6260FWW Logo
581 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
