Question about Masterbuilt 40" Electric Smoker with Window
Heat light is on but not heating. New out of the box.
  • Masterbuilt Master
  • 16,043 Answers
Take it back
Posted on May 30, 2014
No heat while driving
many of cars heat water by motor working
Feb 19, 2015 | 2003 Ford Explorer
What kind of heat source should I use to properly heat a tank for a box turtle?
There are two good heat sources that can be used for box turtles:
Overhead incandescent heat lights
Under tank heating pads
Or, you could use a combination of the two to provide your box turtle with great day/night heat areas.
Sep 04, 2012 | Aqueon Reptile
Frigidaire dishwasher stuck on heat dry
That happened to me also. The button dance did not work for me. I turned the switch on the fuse box off and waited for two minutes. When I turned the switch to fuse box on again my son two light were blinking and I told him to press the start button on the washer and it worked.
May 14, 2012 | Frigidaire 24 in. FDB635RF Built-in...
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
1998 Ford Explorer: No heat. Checked everything and can't find the problem. New thermostat was installed. still no heat.
take out the glove box, you will see a white box about 3 inchs square with wires pulged into it, this is the diverter control,take the screws out, and remove it, then see if you cand move the diverter by hand too get heat, if you can then you need too replace the control or just lock the diverter in the heat position, i had this same problem last week in a 98 explorer and liked too never found it , ive got heat now!!!
Feb 09, 2010 | 1998 Ford Explorer
When I turn on air or heat the brake lights and 4
Check the main fuse box under the hood on the drivers side. You should do it with an ohmmeter. good luck. The cruise control is probably the door lock module. Are your interior lights stuck on?
Feb 22, 2009 | 2004 Chevrolet TrailBlazer
No heat
HEATER CONTROL VALVE IS NEXT.ARE YOU SURE THE ANTI FREEZE IS UP TO LEVEL WHEN THE TRUCK IS WARM.
Jan 24, 2009 | 1998 Ford F150 Regular Cab
Red lights on xbox
3 Red lighs means a hardware failure. If you've opened up the console you have void the warranty so you can't get it replaced. It would have been a quick fix in a certified repair shop with one ring and your warranty would still be valid. Unfortunately, you will have to attempt to fix the console yourself or get a new one. I recommend you get it replaced though.
Jan 23, 2009 | Microsoft Xbox 360 Console
Dead Battery After 2 days
Check things like glove box ,boot or centre console lights. Also while recharging battery with engine cold feel alternator for any heat. Does alternator charge?
Jun 15, 2008 | 1992 Cadillac DeVille
Brand new rowenta professional won't heat
The mostly problem in that case is the internal terminal from cord to iron is loose ,open it and fix the the terminal cord to iron,or go to the nearest shop to repair that.
Thanks & good day,
Edgz
Feb 12, 2008 | Rowenta DZ1700 Iron
Masterbuilt 40" Electric Smoker with Window Logo
46 people viewed this question
Top Masterbuilt Home Experts
Donni Steen
Tom Chichester
Are you a Masterbuilt Home Expert? Answer questions, earn points and help others
