Question about Mitsubishi WD-60737 60 in. HDTV
Clean mirrors. picture has a fuzzy halo around the edges of the tv.
Need to be able to clean the mirrors. How do I get access to the mirrors. Thank you.
4 Suggested Answers
  • 150 Answers
SOURCE: Location of MIrrors in projection tv
wd-52525 This is a DLP, I dont suggest taking it apart to clean anything, this is what we call a MICRO display, the imaging device is about 1" square and blown up 50X to the size of the pix you watch, anytime anyone I know has taken stuff appart where the mirror is at has ended up worse off, you say that there is dust on the mirror, what does it look like in your picture? If the spots are quarter size or so and fuzzy edges the dust is inside the lightengine and you want a factory cleanroom to service the LE, the one thing I think you can safely do is pull the lamp and check for dust on it as it can cause issues in pix, other than that I dunno what to tell you, hope this info helps.
Posted on Jul 09, 2007
SOURCE: Cleaning the bulbs and mirror on my Mitsubishi 55" WS-55313 TV.
You should re-consider having a tech do that for you. The access is by removing the screen assmbly which are somewhat fragile. If you want to give it a try, pull the speaker grill off, it comes off just from pulling it, there should be five screws across the bottom of the screen assy, remove those, there is also an access door on the front of the set with four screws, that has to be removed to unplug the cable that goes to the screen sensors. The screen assy has to be lifted straight up an inch or two and then you can pull it forward away from the set.
As far as cleaning the mirror and lenses, you can't get to the face of the tubes so it's the top of the lenses that you clean, just use a soft lint free cloth (cloth baby diaper) and wipe the dust off the lenses, you can slightly dampen the cloth with water if necessary, same type of cloth on the mirror and you can use a glass cleaner on it just don't press too hard on the mirror.
Posted on Feb 05, 2009
hardrocko
  • 1476 Answers
SOURCE: Picture has color separation and halos. Picture distorted.
Your convergence is bad and you need to replace the convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Posted on Apr 27, 2010
Fuzzy picture...direct cable says its in the tv itself...unplugged ,plugged back in removed coaxial and replaced checked all plug ins to no avail..
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV by removing lots of screws at back to clean it inside.
Thanks.
Apr 18, 2011 | Televison & Video
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
Fuzzy picture
have you taken off the screen and tried to clean the lens as well as the mirrors inside the set?
May 04, 2010 | Sony KP-53XBR200 53" Rear Projection...
My panasonic big screen screen has shadows and fuzzy picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 31, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Fuzzy picture
Oct 24, 2008 | Philips 55P8241 55" Rear Projection...
Philps 60P8341A
I have a 60 in. Philip Magnavox tv that it haveing sound problems.It,s sounds when is in dvd ,but not when is in tv the model no.is 9p6040 c104. Does anyone have any ideas to fix this problem? Thank you........Lucy
May 03, 2008 | Philips Magnavox 27MS343S 27" TV
Hitachi 50UX22B
Look inside the lens while the set is on. If you see things floating around inside the glass, the fluid will need to be changed inside of each tube. I will post a link on how this is done if this is a Magnavox TV set. Good luck
Feb 14, 2008 | Philips Magnavox 51MP392H Rear Projection...
Foggy HD projection TV
I think your refering to the CRT colant needing to be changed if it has a halo effect on the blue and green colors Also some times your picture can get dingy because the mirror gets dull. Try cleaning the mirror and tube lenses. Use a damp soft cloth on the mirror and lenses not windex.
Jan 20, 2008 | Televison & Video
Jul 09, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-60737 60 in. HDTV Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
