Question about Electrical Supplies
Split a ssd10000 stephill generator - Electrical Supplies
2 Suggested Answers
  • 905 Answers
SOURCE: Faulty Generator
check for open armature (check continuity at slip rings). Also check that diodes are good (not opened). Engine RPMs should be at least 1800 or 3600 depending on alternator. Probably 3600 RPM (for 60hz).
Also check to see if you have a bad circuit breaker.
Posted on Jan 04, 2010
Pulley Yanks out of my hand when trying to start storm cat generator
Joseph,
It will be the reed valves need replacing. When they fail it can create a suction as the piston returns. This, in turn, pulls the recoil handle out of your hand (and can damage the recoil too.)
The Reed Valves are located behind the carb and are easy to replace. Be sure to replace the gaskets on the reed valves and the 2 gaskets on the carb, as they will split when you replace the reed valves. If you use a split gasket, it can allow extra air into the fuel mixture, and result in the engine running rough or not at all. So best to change them as you go.
Best of luck. Let us know if you need any more assistance.
Regards
Generator Guru Parts and Spares
BTW... We sell the reed valves and the gaskets! You can purchase them here: http://www.generatorguru.com/storm-cat/?sort=featured
Nov 24, 2016 | Electrical Supplies
Can I run a daikin mini split heat pump 3MXS24JVJU with a generaton
It depends on the SIZE of the generator. If your generator is designed to supply 240-volt A/C and handle the FLA (Full Load Amps) rating of your Indoor and Outdoor units, then, YES, of course you can run it with a generator.
Aug 26, 2014 | Cfm Daikin R410a Split System Air...
Taking apart
The internals of the generator have to be removed and you'll need a gear puller to seperate the engine from the generator housing because they're pressed together. It can be a pain in the neck. There's videos on you tube on how to do it
Nov 22, 2013 | Pramac Electrical Supplies
Aux battery not charging
For battery charging generator, let generators to produce electricity is through a belt connected to the generator split plate and automobile engine, the working principle of generator is magnetic power, that is part of a closed circuit conductor in a magnetic field will produce induced current for cutting the magnetic induction line exercise. (see the junior middle school physics: Faraday electromagnetic induction phenomenon)
auto diagnostic tool
Mar 23, 2013 | Cars & Trucks
General information on PM0545007.02
Not really, especially if thet start together, too much load for this unit.
Aug 30, 2012 | Coleman Powermate Premium Plus 6250W...
No spark on B&S industrial engine fitted ti Stephill generator
Always have a new spark plug handy to determine if faulty plug when no or weak spark. If your engine has an oil alert, disconnect sensor wire and re-test. If still no spark suspect spark plug boot or coil. New or used coils are available at small engine repair shop. If you have access to growler (used for testing armature), by placing coil on growler with one leg on each pad, you can test coil for signs of life. Good luck
Jul 02, 2011 | Briggs & Stratton Garden
Battery cable burned & split, what's the problem?
When a battery clamp is dirty and corroded it will generate more heat when cranking the engine. If it is slightly loose it will generate more heat. If the engine is hard to start requiring more cranking more heat will be generated. This can contribute to the deterioration of the cables causing the burn and splitting.
Mar 22, 2010 | 1999 Dodge Intrepid
Faulty Generator
Dec 07, 2009 | Electrical Supplies
Electrical Supplies Logo
26 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
