Question about Umbra Otto Automatic Soap Dispenser, Nickel
Umbra Otto Automatic Soap Dispenser, Nickel not working
Just bought the Umbra Automatic soap dispenser and it does not work
-Return for refund, and get new one.
Good luck
Mai
Mar 24, 2017 | Dishwashers
Just bought new Otto sensor soap pump & Soap is not dispensing
Same with me! And with all the postings there is not ?ONE answer., tells me something!
Apr 05, 2014 | Umbra Otto Automatic Soap Dispenser,...
Soap no longer dispenses automatically.
Mine would not work with the Costco brand (Kirkland) batteries. The light indicator came on but the pump did not work. Once I replaced them with Durcell, the pump started working. I'm guessing Energizer brand would work just as good.
Nov 22, 2013 | Umbra Otto Automatic Soap Dispenser,...
My umbra soap dispenser sensor does not work
I had the same problem come to find out if the pump doesn't turn then there is no complete circuit thus the sensor lights don't work that doesn't mean the sensor isn't working so more than likely your pump is gummed up with old soap residue.
Mar 08, 2013 | Dishwashers
Can a brushed nickel soap dish cause green spots to form on white soap
if the finish is scratched and it is brass underneath, yes. Otherwise, no.
Oct 03, 2010 | Grohe Satin Nickel Soap Dispenser...
I have a Grohe soap dispenser and it has quit working for me. It is as if it gets stuck after you push it down and it seems to leak the soap out of the bottom part of the dispenser getting soap all over...
Sounds like there might simply be old soap caked on the inside of the dispenser head and feed tube. Best thing to do is have a sink filled with HOT water and just put the head portion in there to soak for a while. This should loosen the old soap enough to either dissolve or at least get it moving again. You can also take what soap is still in the dispenser out and put in another container, taking time to rinse the container with hot water as well and then filling it with hot water as well to test the pump action of the head, again using this action to help clean the insides of the pump. Short of this doing the trick, it may just be time for a new one. Good luck.
Aug 26, 2010 | Grohe Satin Nickel Soap Dispenser...
We have the single handle Pegasus 190 571 Brushed Nickel bathroom faucet. The soap dispenser got knocked and broke off and I cannot find a replacement for it.
The booklet that comes with that unit has the following part numbers: nut set (A66D111); soap dispenser sleeve (A665597); soap pump (A605230); soap dispenser nozzle (A66596). Those are all the parts (less plastic tube and soap reservoir bottle) for the dispenser- you probably only need one (the broken one!).
Jun 17, 2010 | Home
My grohe soap dispenser won't pump out any soap.
If the soap dispenser is not pumping the soap then the soap is to thick. You need to then the soap down some so it will pump.
Apr 01, 2010 | Grohe Satin Nickel Soap Dispenser...
Soap Dispenser leaks soap onto counter
maby minor crack between the the treds on the bottle that screws in to the pump or a crack in the bottom of the pump and you may not see it because the pressure of the pump isint in the bottle when you un screw it tot look at it
May 17, 2009 | Grohe Satin Nickel Soap Dispenser...
Umbra Otto Automatic Soap Dispenser, Nickel Logo
380 people viewed this question
Top Umbra Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Umbra Health and Beauty Expert? Answer questions, earn points and help others
