Question about HP Compaq 6710b Notebook
No lights on system board
Cheked voltage o k on power supply no lights where is the fuse if it has one
    Champion:
  • 200 Answers
Take out the battery and reinstall it be sure to disconnect the power supply first
sounds like it may be the power button sorry,no fuses
Posted on Jan 02, 2014
Power supply board not working, what section i have to cheke...?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 03, 2016 | Televison & Video
Getting 120 v to white plug where it first plugs into board should i have power reading at fuse?
yes after to the fuse you must have a reading of 120vac if none the fuse get busted. if the 120v is present then it will goes through the rectifier bridge diode and primary capacitor of the power supply board to have an stand by voltage at the power supply board. when you press the power button it will send signal voltage coming from the main board to turn on the power supply board. the you will need to get an output voltage at the power supply board of 5v dc, 12v-16vdc and 24v to turn on the all the circuit, the main board sound amplifier and the inverter board for screen back light.if you can get those supply the tv unit will not turn on.
Nov 09, 2012 | Vizio L37 Television
Virea tv has just stopped working. Whilst watching it has switched itself off and there is no standby light or anything. All power cords and supplies are fine but it won't switch back on.
Good day!Follow this D.I.Y procedures to find the exact problem of your TV.
  1. Remove the back cover of your TV.
  2. After that,find the power supply board.
  3. If you already found the power supply,plug-in your TV and power it ON.Check the input voltage of it,using multimeter (AC range).If the power supply have no input voltage the problem could be the power cord.Replace it.
  4. If the power supply have the input voltage,try to test the output voltage if have 5vdc for the system and logic supply,12vdc for the sounds and 24vdc for the back-light inverter.Use your multimeter tester (DC range) to test that.
  5. If the power supply have a voltage outputs such as 5vdc,12vdc and 24vdc and the problem is still there.The problem could be the main board.Replace it with the same type and model # because the main board is no very difficult to fix and its very sensitive.
  6. If the power supply have no output voltage or the voltage is too low,just ignore the step # 5 because the problem is not on the main board,its on the power supply board.
Check the following to fix the power supply board:
  • Fuse: Check the fuse if it is busted or blown.
  • Power transistor (regulator): Check the regulator if it is shorted or leak.
  • Resistor: Check the resistors specially the one that have a low resistance that near the power regulator.
  • Capacitor: Also check the capacitors if it is leak or bulging top.
NOTE: If you found any defective parts or components that mention above replace it with the same value,type and ratings.
I hope this solution will be helpful.Thank you and good luck.
May 29, 2011 | Televison & Video
Hallo, Onday power supply was out,that time TV also switched off.From next day my TV is not working.The power indicator not giving light.What is the problem?.Where I can give the TV for repair?Where is...
May 29, 2011 | LG 26LX2R 26 in. HD-Ready LCD TV
TV won't turn on. Is there a fuse that needs replacing?
Good day!
When the TV is not turning ON it doesn't mean that there's a busted fuse inside although it have a possibility.There are a lot of causes to be considered.Like shorted transistors,leak capacitors open resistors and shorted diode.
Thank you and good luck.Please don't forget to vote and rate my answer.
May 08, 2011 | Televison & Video
HAVE A PHILIPS 15" WITHOUT
Good day!
Actually if your TV have problem like that it is not on the inverter.That problem could be on the power supply or the system board.
Apr 28, 2011 | Televison & Video
I have no pitcher on my mag flat csreen tv .the red light is on in the front of the t6v .no sound also..i also cheked the fuse. what can i do to fix this problem?
Your power supply board is dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem......
Feb 17, 2011 | Televison & Video
Rca tv model L32WD14 continually turns on and off. What is going on?
You may have failing power supply module or failing main board, you need to do some voltage cheking at the outut terminals of the power supply to see if the voltages come and go.
Parts:
http://www.shopjimmy.com/catalogsearch/result/?q=RCA+L32WD14+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 12, 2010 | RCA L32WD14 32 in. LCD Television
I have a sony kp-65w600 i have changed boyh ics and cheked all resisors and fuses still have bow and i am not getting voltage to the ics
There are 2 protection fuses on the +/- 19v supply line. On the G board, check PS6503, PS6504. These are 5 amp IC fuse links, PN: 1-533-597-31. I hope this helps, best wishes.
Apr 23, 2010 | Televison & Video
I need a repair - one of the amps had smoke coming out of it. Where do I start?
first you have to start by taking out the voltage out from the transistor boards,check the power supply voltage if its ok,the connect one borard at a time.if one bolw the fuse thats the sort circuit.begeing by cheking the transistors and go on.
Jul 08, 2009 | Rockford Fosgate FAA 1000.5 5-Channel...
HP Compaq 6710b Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
