Question about Pride Luxury Line Maxima Scooter - 4 Wheel - Forest Geen
Can I upgrade the headlamp bulbs for brighter ones
The headlights are not very bright Can I upgrade the bulbs to brighter ones without overloading the circuit?
  • Pride Master
  • 1,263 Answers
Hi, I do sell a light kit that fits into your charger socket,,, Look at www.rsrc.co.uk/cart or contact me on
www.gewizrepairs.co.uk
Posted on Dec 30, 2013
Poor headlights on rover 75
Yes you can. I bought led headlights for my 1948 fod. They are nice and bright. Before you replace your head lights check to make sure you have a good ground from the battery to the body.
Dec 22, 2012 | Cars & Trucks
How do i upgrade my honda anf 125 2005 headlight to a brighter one?
easiest method is to fit a brighter bulb in the headlight that you've got...
Oct 23, 2012 | Motorcycles
2000 GRAND CARAVAN: Extremely dim headlights, because headlights are so narrow. Installed 9007SU Silverstar Ultra bulbs 3 years ago. Age 77 so poor night vision + still DIM headlights is BAD at night! ...
The silverstar bulbs while brighter, have a considerably shorter life span than conventional bulbs. If the headlights are dim, it would mean a bad electrical connection most commonly a bad ground. If they are just too dim for your liking and burn at the normal brightness, you might want to consider having auxilliary headlamps installed.
Jun 23, 2011 | Dodge Grand Caravan Cars & Trucks
I just bought new headlight bulbs but one light is way brighter then the other, my left is brighter then the right and stays dim even when i turn on the night lights. whats the issue?
dear,
There is the issue with the wattage of bulb you have got for the vehcicle.
And also due to a new bulb it shines brighter then the old one.
get the old one also repaced to get the equal brightness
thanx
May 19, 2011 | Dodge Dakota Cars & Trucks
What kind of headlight bulbs are used for this type of vehicle? or what type?
2004 DODGE Durango
High & low beam headlamp
H13 (9008)
H13ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H13XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
Mar 10, 2011 | 2004 Dodge Durango
What is the part number of the headlight bulbs for an 05 Ford escape
This is from the osramSylvania web site.
Low beam headlamp
H11
H11SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
H11ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H11XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
High beam headlamp
H7
H7SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
H7ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H7EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
H7XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
H7CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Jan 21, 2011 | 2005 Ford Escape
When you turn the headlights on everything works but the headlights. If you hold the dimmer switch in the brights will come on. When you let it go the lights go out
Have you tried to change the headlights?
REMOVAL & INSTALLATION Sealed Beam NOTE: If vehicle is equipped with headlamp doors turn the headlight switch ON. Open the hood and locate the power distribution center. This center is located in the front of the left front strut tower. Remove the cover from the center and remove the Headlamp Close Relay. This will prevent the headlamp doors from closing to provide easier servicing. Turn the headlight switch to OFF, then perform this repair.
  1. Remove the headlight bezel.
  2. Unhook the spring from the headlight retaining ring if so equipped.
  3. Unscrew the retaining ring and remove it. NOTE: Do not disturb the two long aiming screws. Conventional and Halogen headlamp sealed beams units are interchangeable in pairs, but it is recommended that they not be mixed together (one halogen and one conventional). It is fine to upgrade from conventional bulbs to halogen, but do not change from halogen bulbs to conventional bulbs, especially if the vehicle came equipped with halogen bulbs.
  4. Unplug the old sealed beam from the engine electrical wiring harness.
  5. Extract the old bulb from its mounting bracket. To install:
  6. Connect the replacement bulb and install it into the receptacle (check operation of headlight before completing repair).
  7. Install the retaining ring and secure it in place with the retaining screws. Connect the spring.
  8. Install the headlight bezel.
Aero Headlamp Aero headlamp systems use replaceable halogen bulbs that are mounted in aerodynamic, molded plastic lens reflector assemblies. NOTE: Lens fogging is a normal condition and does not require service, as moisture will vent from tubes behind the lens on Aero headlamp-type system. EXCEPT PREMIER AND MONACO It may be necessary to remove the entire headlamp assembly if enough access cannot be gained otherwise.
  1. Locate and remove the wire connector behind the headlamp assembly in the engine compartment. It may be necessary to remove certain items in the engine compartment to gain access to the bulb wires.
  2. Rotate the bulb retaining ring counterclockwise 1?4 turn and remove the ring, bulb and bulb holder from the lens assembly. The bulb holder has alignment notches. NOTE: Do not touch the bulb with bare fingers or any possibly oily surface, since reduced bulb life may result! Fig. 1: To remove the light bulb, first unplug the headlight electrical connector, then . . . 86726p13.jpg
    Fig. 2: . . . remove the light bulb socket retaining ring 86726p14.jpg
    Fig. 3: Rotate the light bulb socket 1?4 turn counter-clockwise, then pull it straight out of the lens assembly 86726p15.jpg
    To install:
  3. Wearing gloves or holding the replacement bulb with a cloth rag to keep oil off of the bulb surface, insert the bulb into the rear hole of the headlamp assembly. Make certain that the alignment grooves and tabs line up, push the light bulb into the assembly until seated flush, then turn the bulb clockwise 1?4 turn.
  4. Plug the electrical light bulb wiring harness into the new light bulb. Install any items removed from the engine compartment.
PREMIER AND MONACO Unlike the other vehicles covered by this manual, the removal and installation of the headlamp bulbs in the Premier and Monaco models requires the extraction of the entire headlamp lens assembly.
  1. Remove the grille-to-headlamp assembly attaching screws.
  2. Disconnect the headlamp aiming cable from the aiming screw end.
  3. Remove the headlamp assembly attaching bolts from above and behind the lamp assembly and separate the lamp assembly from the vehicle.
  4. Unplug the headlamp wire connector. NOTE: Do not touch the bulb with bare fingers or any possibly oily surface, since reduced bulb life may result!
  5. Rotate the socket counterclockwise 1?4 turn and pull the socket from the back of the lens assembly. Fig. 4: Remove the bezel retaining screws to loosen the headlamp assembly - Premier and Monaco 86726g91.gif
    Fig. 5: Detach the headlamp wire connector - Premier and Monaco 86726g92.gif
    Fig. 6: Once the headlamp assembly has been removed from the vehicle, the various light bulbs can easily be removed - Premier and Monaco 86726g93.gif
    To install:
  6. Wearing gloves or holding the replacement bulb with a cloth rag to keep oil off of the bulb surface, insert the bulb into the rear hole of the headlamp assembly. Make certain that the alignment grooves and tabs line up, push the light bulb into the assembly until seated flush, then turn the bulb clockwise 1?4 turn.
  7. Plug the headlamp wire connector back into the headlamp bulb.
  8. Install the assembly into the vehicle and secure in place with the mounting bolts.
  9. Connect the headlamp aiming cable to the aiming screw end.
  10. Install the grille-to-headlamp assembly attaching screws.
Oct 15, 2010 | 1991 Chrysler New Yorker
Only brights work, dimly lit headlamps, no fog lamps
Recheck the bulb number. This happens when the wrong bulb number is installed. Otherwise it could be a bad headlight ground.
May 17, 2009 | 2000 Pontiac Grand Prix
How to improve safety on night riding?
# Wear bright clothing. Those black leather jackets look good in the day, but for the night, you might want to consider wearing something that reflects light. Consider adding a fluorescent highlights on the back of your jacket, a smart message maybe. Your helmet is also a nice place for the same. # Motorcycle Lighting: Good lighting is a crucial factor in your safety. In the quest for stylish lighting, many manufacturers use undersized brake lighting and most will aim the headlight lower to the street than the legal angle allows. Your first step is to examine your front and rear lighting. If you have a tiny brake light, consider replacing the light with a larger model. If this is not possible, J.C. Whitney sells a halogen brake lamp for about $10.00 that is 30% brighter than stock bulbs. You can also buy super bright LED lighting that is much brighter than the typical automotive bulb. However, this lighting should be purchased from a specialty company and not the "garden variety" LED arrays you can find at some stores for $15.00 or less. UltraBright LED's are expensive when using true Ultrabight LED (light emitting diodes). Expect to pay more if you want a truly bright LED system. Custom Dynamics is one such supplier of premium LED lighting. # Check your headlight aiming angle. Check your state regulation on aiming. Raise the beam to the maximum angle allowed by your state. You can do this without special tools by uprighting your bike and casting the headlight on the wall of your garage. Measure from the ground to the exact center of your headlight, then adjust the beam projected on the wall (high beam). A rule of thumb is to drop 2" for every 10 feet (5 cm every 3 metres), but you should check with your state to conform with their regulations. # Ride with your high beam on always during the day! # Add dual running headlights to your motorcycle. Three properly aimed headlights are much more noticeable than a single headlight. # Consider replacing your headlamp bulb with a super bright DOT approved model. Some bikers have been known to replace their headlight bulb with a non-DOT approved off-road lamp which is 40-50% brighter than the brightest legal lamp. # Add reflective tape to your bike. You can also purchase reflective decals and add reflective flame decals to your helmet.
Nov 20, 2008 | 2005 Harley Davidson FXST - FXSTI Softail...
Headlamps too dim
I cant find you any dissasembly instructions but i know that if you go to your local wallmart they have headlight polishing kits for the lens. http://www.myheadlight.com/ thats the products websight. I hope this helped you choose what to use. Im sorry I couldnt help you get them apart.
Jul 04, 2008 | 1994 BMW 5 Series
Pride Luxury Line Maxima Scooter - 4 Wheel - Forest Geen Logo
59 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
