Question about Total Gym Exercise & Fitness
Black pin is stuck - Total Gym Exercise & Fitness
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
Feb 16, 2017 | Chevrolet Express Cars & Trucks
My treadmill has gotten stuck in the highest incline position??
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 21, 2016 | Tempo Fitness Model No. 632T
07 chevy suburnan wiring diagram color
Item12 VoltsSecond 12 VoltsStarterSecond StarterIgnitionSecond IgnitionThird IgnitionAccessorySecond AccessoryThird AccessoryKeysenseData BusCan Bus HighCan Bus LowCan Bus SwPower LockPower UnlockLock MotorDriver Unlock MotorPassenger Unlock MotorParking Lights (-)Parking Lights (+)HazardsTurn Signal (Left)Turn Signal (Right)HeadlightAutoLightsReverse LightLeft Front Door TriggerRight Front Door TriggerLeft Rear Door TriggerRight Rear Door TriggerDome SupervisionTrunk/Hatch PinRear Glass PinHood PinTrunk/Hatch ReleaseTrunk Release MotorFuel Door ReleasePower Sliding Door (Left)Power Sliding Door (Right)Factory Alarm ArmFactory Alarm DisarmDisarm No UnlockTrunk Alarm ShuntTachometerWait to StartNeutral SafetyClutch PedalFuel PumpRear DefrosterMirror DefrosterLeft Front Heated SeatRight Front Heated SeatSpeed SenseBrake WireParking BrakeHorn TriggerWipersLeft Front Window (Up/Down)Right Front Window (Up/Down)Left Rear Window (Up/Down)Right Rear Window (Up/Down)Sun Roof (Open/Close)Sun Roof (Limit/Close)Memory Seat 1Memory Seat 2Memory Seat 3Radio 12VRadio GroundRadio IgnitionRadio IlluminationFactory Amp Turn-onPower AntennaLeft Front Speaker (+/-)Right Front Speaker (+/-)Left Rear Speaker (+/-)Right Rear Speaker (+/-)Center Channel (+/-)Subwoofer (+/-)Aux. Audio Input Left (+/-)Aux. Audio Input Right (+/-)RSE Video (+/-)RSE Audio Left (+/-)RSE Audio Right (+/-)Satellite Radio 12 VoltsSatellite Radio GroundSatellite Radio IgnitionSatellite Radio AntennaSatellite Audio Left (+/-)Satellite Audio Right (+/-)HeadunitLeft Front SpeakerLeft Front TweeterRight Front SpeakerRight Front TweeterLeft Rear SpeakerLeft Rear TweeterRight Rear SpeakerRight Rear TweeterCenter ChannelSubwooferLeft Front HeadrestRight Front HeadrestLeft Rear HeadrestRight Rear HeadrestSatellite Radio Tunerspacer.gifspacer.gifWire Colorred/black (60A), red/black (60A)red/white (x4) (15A each)purple (for starter kill only)pink/black (resistor code), white (5V reference)pinkN/AN/Abrown or yellowsame as second starterN/Asame as second starterdk. green (low speed GMLAN)tan/black (high speed GMLAN)tan (high speed GMLAN)dk. green (low speed GMLAN)use Directed interface modulesee power lockgraypurpletanlt. bluebrown (L), brown (R)whitelt. blue/white (F); yellow or yellow/black (R)dk. blue/white (F); dk. green or dk. green/wht (R)whitedk. green (ground to turn off autolights)dk. bluegray/black (ajar), tan (open)black/white or tan/whitelt. blue/blacklt. green/blackgraypink/blacksame as trunk/hatch pinpink/blackgray (liftgate), pink (liftglass) (rear handle sw)lt. blue (liftgate)N/AN/AN/Aarms on lock with door openlt. green (driver door key cylinder)Passkey and ignitionN/ANOT pinkN/AN/AN/Adk. green/whitepurpleorange or black (L), orange or black (R)dk. blue (back and cushion)dk. blue (back and cushion)dk. green/white (some models only)lt. blue/white (functions with ignition on only)lt. bluetangraydk. blue - browndk. blue - browndk. blue - browndk. blue - brownbrown - org or lt. blu (function with ign on only)N/Aorangesame as memory seat 1N/Ared/whiteblack(low speed GMLAN)yellow (dimmer)same as power antenna (some models only)whitetan - gray or tan - dk. greenlt. green - dk. green or lt. green/white - org/blkbrown - yellow or brown/white - browndk. blue - lt. blue or dk. blue - tandk. blue - orange (with surround)white - pink (with surround)yellow - (bare wire)white - (bare wire)dk. green - white/blacklt. blue - purplewhite - purplered/whiteblack(low speed GMLAN)(coaxial cable)brown/white - tan/whitedk. green/white - graydouble DIN6.56.55.255.25spacer.gifspacer.gifPolarity++++9.6K ohms+++6.3K ohmsdatadatadatadata5 wire5 wire5 wire-+-++--+----+---+-ac+reverse+ latched--ac+--+AAAA-+2.26Kohms+4.26Kohms+-+++,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+-+,-+,-spacer.gifspacer.gifWire Locationdash fuse box, black 40 pin plug (X1), pins F1 and E3BCM, black plug, pins 1, 2, 3, and 4starter or underhood fuse box, blk 50 pin plug (X2), pin F1 or F5ignition switch or BCM, lt. green plug, pins 2 and 4ignition switch or BCM, lt. green plug, pin 14ignition switch or BCM, lt. green plug, pin 21PASS-Key III+ Module, black 5 pin plug, pin 4data link connector, black 16 pin plug, pin 6data link connector, black 16 pin plug, pin 14data link conn, black 16 pin plug, pin 1 or BCM, lt. blue plug, pin 10driver kick or dash fuse box, black 14 pin plug (X3), pin B4driver window switch, brown 16 pin plug, pin 8driver kick or dash fuse box, black 14 pin plug (X3), pin B1headlight switch or BCM, white plug, pin 8underhood fuse box, black 30 pin plug (X3), pins A7 and F7hazard switch or BCM, lt. green plug, pin 19BCM, brown plug, pins 4 and 1BCM, black plug, pin 5; brown plug, pin 2headlight switch or BCM, white plug, pin 12headlight switch or BCM, white plug, pin 17BCM, white plug, pin 22driver window switch, brown 16 pin plug, pins 13 and 11passenger window switch, brown 16 pin plug, pin 13BCM, pink plug, pin 15BCM, pink plug, pin 14BCM, white plug, pin 5BCM, pink plug, pin 12hood switch or BCM, black plug, pin 17BCM, pink plug, pins 13 and 24passenger kick, harness to reardriver window switch, brown 16 pin plug, pin 4any fuel injectorECM, black 73 pin plug (X1), pin 50driver kick, harness to reardriver and passenger window switch, black 10 pin plug, pin 7driver window switch, gray 14 pin plug, pin 6passenger window switch, gray 14 pin plug, pin 6EBCM, blk 38 pin plug, pin 11 or 32 or radio, brn 16 pin plug, pin 5brake switch or BCM, brown plug, pin 6parking brake switch or BCM, brown plug, pin 16horn switch or BCM, brown plug, pin 18BCM, brown plug, pin 20driver window switch, black 6 pin plug, pins 3 and 1passenger window switch, black 6 pin plug, pins 3 and 1left rear window switch, black 8 pin plug, pins E and Hright rear window switch, black 8 pin plug, pins E and Hsunroof switch, black 8 pin plug, pins 6 and 4driver window switch, gray 14 pin plug, pin 5radio, black 14 pin plug, pin 1radio, black 14 pin plug, pin 8radio, black 14 pin plug, pin 7radio, black 14 pin plug, pin 6radio, black 14 pin plug, pins 2 and 9radio, black 14 pin plug, pins 3 and 10radio, black 16 pin plug, pins 5 and 13radio, black 16 pin plug, pins 6 and 14radio, brown 16 pin plug, pins 3 and 11radio, brown 16 pin plug, pins 4 and 12radio, gray 16 pin plug, pins 1 and 9radio, gray 16 pin plug, pins 2 and 9radio, gray 16 pin plug, pins 7 and 15radio, gray 16 pin plug, pins 3 and 11radio, gray 16 pin plug, pins 4 and 11Digital Radio Receiver, black 16 pin plug, pin 16Digital Radio Receiver, black 16 pin plug, pin 9Digital Radio Receiver, blk 16 pin plug, pins 2, 1Digital Radio Receiver, blk 16 pin plug, pins 3, 4center of dashleft front doorleft front pillarright front doorright front pillarleft rear doorleft rear pillarright rear doorright rear pillartop center of dashunder front of center consoleunder passenger dash, behind glove boxspacer.gifspacer.gifPhotohas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifspacer.gifspacer.gifNotehas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifspacer.gif
Nov 03, 2012 | Cars & Trucks
My 1998 chevy truck ignition stuck I took the steering wheel off
You need a lock plate removal tool,napa sells them ,they are cheap,and the pin in the key cylinder? Use a punch to destroy the pin.
Jul 21, 2010 | 1998 Chevrolet K1500
The pin on the starting switch broke. Black and Decker CMM120
Same problem with ours. We used a bolt (cut to fit with dremmel tool) to replace the pin and the spring slipped over the bolt. I don't remember exactly where the two arms of the spring met the switch and handle, but it was obvious once the spring was on the bolt.
Aug 31, 2009 | Black & Decker 19" Electric Lawnhog...
BEEPS
just reseat the memory modules it will fix the issue
Jun 07, 2008 | EliteGroup P4VMM2 Motherboard
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
Intel heat sink installation pin problem
800-404-2284 / 916-377-7000
this is the number for the main tec support they might be able to help
May 02, 2008 | Intel Core 2 Duo E6600, 2.4 GHz E6600...
Kenmore 385 Series with drop in bobbin
it might be that a piece os the pin is still stuck in the bobbin race. try taking the screws out of the throat plate and lifting it up. use a little brush to make sure allthe lint and any pin pieces are out from around the feed dogs. put the black piece back in place before you replace the throat plate. If the black piece doesn't stay in place i doubt that it was in correctly. hope this works.
Apr 28, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Quinny zapp back wheels - help
Yeah the grey pin was stuck in. I noticed a small screw at the back of the hub which when removed releases a spring loaded black plug. Be careful when you undo the screw, otherwise you might lose the spring and the plug as they can fly out suddenly. Once you have got the black plug and spring removed you can stick a screwdriver in and pop out the grey pin on the opposite side of the hub. I then re-assembled the spring and black pin and job done the wheel didn't fall off again.
Jan 18, 2008 | Quinny ZAPP Stroller
Exercise & Fitness Logo
37 people viewed this question
Top Total Gym Exercise & Fitness Experts
Rick Massengale
Level 1 Expert
Tom Chichester
Are you a Total Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
