Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Temperature set at 65, temp does not go higher, does not go lower but never stops running no matter what it is set at?? pls help
Toyo laser 56
toyotech
  • 8 Answers
SOURCE: EE2 code for toyo LASER 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Posted on Jan 28, 2008
  • 126 Answers
SOURCE: I have a toyo laser 56 stove. It is starting to
Pilot,
You need to have a new mat put in the bottom of the burner. When this mat lifts, sometimes the flame will cause a moaning noise with a large yellow flame. A new mat and maybe a burner ring will fix ya.
Tom
Posted on Feb 08, 2010
  • 126 Answers
SOURCE: We have a Toyo Laser , when it kicks on we get
Tubearz,
You need to look at the igniter guide gasket. That is the gray fiber gasket just behind the igniter flange. When you remove the igniter you may see a black rubber gasket that could be cracked or completely gone. You will need to replace it with the new style ( #17185580). While you are looking, look at the draft tube, where it goes into the fuel sump. If it is cracked it will need to be replaced.
Good luck,
Tom
  • 674 Answers
SOURCE: i let my tank empty
You may have an air bubble in the fuel line or the filter (if you have one at the fuel barrel) may be clogged. The filter has a vent screw on top and you may need to vent the filter to get the fuel flowing. There is also a strainer in the fuel sump that may have gotten clogged.
Another thing is to push the red float reset button on the right side of the heater. If the float is latched up you will feel a little resistance and hear the float drop. Only press the reset button momentarily. It is not a primer button.
You can get a bowl and some rags to set under the line where it connects to the back of the heater and then loosen the line to make sure you are getting kerosene to the heater.
The fuel pump makes a loud ticking or thumping sound if it isn't getting any fuel.
Let me know if this helps or you need more advice.
Posted on Nov 20, 2010
  • 674 Answers
SOURCE: i let my tank empty before refueling and now my
You should check the filter at your oil barrel if you have one there and loosen the small vent screw to bleed the filter and line. You can also check the strainer in the fuel sump but remember to turn off the fuel at the barrel before removing the strainer from the sump. Also press the float reset button on the full sump. You can loosen but not remove the fuel line on the back of the heater if needed to get the fuel flowing. Be sure to place something under it to catch the kerosene and have some rags handy.
Posted on Jan 03, 2011
Whatis ideal r22 gas pressure required in 1 ton split ac of BlueStar.
Doesn't matter how big the unit is, pressures remain the same. On a satisfied temperature, approximately 75 degrees, r22 should be around 65 psi. The hotter the house, the higher the pressure. Head pressure varies on outdoor temperature. 90 degrees outdoor temp, approximately 200 to 225 psi on high side.
Jun 05, 2017 | Heating & Cooling
My Laser 30 went into power saver mode by itself and now I can't get it out of said mode, otherwise it's working well.
Rick,
Sorry to hear you're having issues with your Toyo, first off do you have a manual for your stove? If not, you can download one online, I've included the link for your convenience.
Your Toyo has a series of control buttons across the top and/or the front, the "On/Off" button for the "Power Saver Mode" is located in the middle. You can turn the mode On or Off, though you actually WANT to utilize the Power Saver Mode. It's intended to prevent unnecessary ignitions on the stove, thereby lowering your electrical consumption as well as wear & tear on the stove. All you need to do is set a maximum and a minimum temperature and whenever the temperature is not within the parameters you've established the stove will then either ignite to heat the area to your pre--determined setting or shut off until the temperature is within the parameters you've established. If there is NO error code(s) showing, and the stove is running fine, then I would not be concerned. Though I do suggest you immediately download the manual, read it thoroughly, and when necessary use it to troubleshoot future issues.
I hope this helps you, good luck and stay warm!
Regards,
Shekele
North Pole, Alaska http://www.toyotomiusa.com/OwnersManuals/Vented%20Heaters/Name%20begins%20with%20Laser/Laser%2030%20(Type%20D).pdf
Oct 09, 2014 | Rinnai Toyostove Direct Vent Heater: Laser...
Dyson hot and cold
Hi there, it's Jack at Dyson.
It sounds like your heater is shutting off because the ambient temperature is higher than or equal to the target temperature you've chosen (shown on the LED display on the front of the machine):
The heater's intelligent thermostat is engineered to turn the machine on only when needed when the ambient room temperature drops below the target temperature. However, we're happy to help you make sure your heater is working as intended. Please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 17, 2014 | Dyson AM04 Hot Cool Heater/Table Fan -...
How do i set the temperature of my dishwasker to 65 instead of 55-65 bosch grand prix
Setting yourdishwasher temperature is done by your hot water heater. If you need to lower the temp, turn down thehot water heater. If you need to raisethe temp, turn the hot water heater up.
May 11, 2011 | Bosch Dishwashers
My toyo L-30 reads the temp then Lo for instance it currently reads 70 Lo. What does this mean?
Lo is displayed when the room temperature is below 14F or the heater thinks the room is below 14F, which would be caused by a problem with the room temperature sensor or the sensor is unplugged. 70 is what you have the heater set to maintain. Check the white wire on back of the heater.
Dec 09, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Tubearz,
Good luck,
Tom
Dec 16, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo stove laser 30
EE22 means that your Toyo failed to ignite 3 times in a row. You need to unplug it for 30 minutes to reset the circuit board. Then plug it back in, push the red reset button on the right hand side in the little hole towards the back and push the Power button. Your Toyo should ignite after that barring some other problem caused by running out of fuel.
I am assuming that you ran out of fuel which caused the EE2 error code originally. Sometimes, when you run out of fuel you can get water, ice, debris in the fuel line causing an obstruction or limited fuel flow. You may also get an air lock. You may need to crack the fuel line at the back of the Toyo where there is 3/4 nut and bleed the line. If you see no fuel or a small quantity of fuel then you will need to thaw and/or purge the fuel line in order to get fuel to your Toyo's fuel pump.There is also a screen in the sump which can get plugged with rust, debris from the bottom of the fuel tank so you may need to clean the screen in order to get fuel to the pump.
Nov 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Default temperature settings
if it is anything like a monitor - look on the right side bottom for a slider - reset temperature adjust. just move the slider to a lower temperature. if you have a power outage, the display starts to flash 88:88
Dec 15, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo laser 56
Hi sammysamual,
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo 3
What Does EE2 Mean? Laser 30, 56, and 73 model Laser heaters cease operation and display
the EE2 code on the control panel (instead of the clock or temperature settings) when the primary
flame rod on the heater fails to sense a flame during the first 5 minutes of the Ignition and Pre-
Heat cycle. On the Laser 55 and 72 the heater will stop and the red Reset lamp will light rather
than the EE2 code. (Note: There may be other reasons for the reset lamp to come on but much of
this information will apply.)
What Can Cause An EE2 Error? The primary flame rod is the only sensor in the heater that
can cause the EE2 error. Thus, if it occurs, either there is (1) no flame to detect, or (2) the
sensor failed to detect the flame. The flame rod is located on the lower 1/3 of the burner. It is a
heavy wire with a ceramic insulator. A single white insulated wire connects this device to the
main circuit board.
Dec 12, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
