Question about Coleman Mach III Air Conditioner
Fan is blowing but not cooling? - Coleman Mach III Air Conditioner
    Genius:
  • Coleman Master
  • 1,363 Answers
Capacitors, relay, bad compressor all possible.
Posted on Sep 18, 2015
1998 Saturn sl1 keeps blowing 30amp cooling fan fuses. it runs for maybe 20 seconds then fuse blows
The cooling fan motor is likely drawing to much current because it is worn out.
May 18, 2016 | Saturn Cars & Trucks
Fuse for cooling fan keeps blowing
check to see if the fan spins freely if it is sluggish or stuck replace the fan motor as it is drawing excessive current and blowing the fuse.
Dec 29, 2013 | Chrysler Pacifica Cars & Trucks
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
Mini Cooper 2002 overheated, fan fuse keeps blowing
The most common cause for the cooling fan fuse to blow is a bad cooling fan motor. The failng motor will draw an excessive amount of current which actually heats up the fuse and melts it. Now if your fuse is blowing the instant the cooling fan(s) turn on, then that could be a "dead short". either inside the cooling fan motor or in the wiring going to it. Follow and inspect the wiring leading to the cooling fan motor. Check for any broken, cracked or burnt wires. If you don't see any of that, then you'll probably need a new motor. If you think you can tackle the job, most auto parts stores sell generic replacement cooling fan motors much less than you would pay at the dealership.
WARNING! - some cooling fan motors are easy to get to, and others are very difficult. Study yours carefully and then decide if you want to tackle the job before you start tearing it apart.
Sep 30, 2011 | 2002 Mini Cooper
My saturn l300 keeps blowing the #2 cooling fan fuse 30a
wiring may be shorting to a ground somewhere check wiring harness and connectors for a ground fault!!swampratt200!!AAAEE!!!
Jul 21, 2009 | 2002 Saturn Sl
Cooling fan fuse
most likely the cooling fan has a short in it. disconnect the connector on the fan. If it doesn't blow now its the fan motor. If it still blows you have a short from the fuse to the motor. What this means is the hot wire is touching bare metal somewhere
Jul 17, 2009 | 2002 Pontiac Sunfire
My fan isn't working
well there not enough data here to make a fairly good solution. but if all the fans are running! and no cool air then it is the compressor.
Jul 14, 2009 | Heating & Cooling
Radiator cooling fan 30 amp. fuse keep blowing
The fan may run with jumper wires but if it''s blowing the 30 Amp Maxifuse it's needs a new or used fan motor.It's pulling too many amps.I have almost never seen a fan relay concern.Only other thing you may check is the wiring down near the fan shoud I have seen the 2 wires get loose from the conduit & melt onto exhaust manifold.Hope tHis Helps
Apr 26, 2009 | 2002 Saturn Sl
Sunpentown SF-609 Evaporative Air Cooler - no cool air
Sometimes there is a separate switch to turn on the water pump. No water=no cooling. Check to make sure the cooling pads are wet! If they are completely wet and the fan is blowing it should cool.
Jul 06, 2008 | Sunpentown SF-609 Air Cooler Fan
Coleman Mach III Air Conditioner Logo
218 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
