Question about GE Dryers
How to get to the rear drum bearing on a ge dbsr453
3 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: ge electric dryer dbsr453 heater element
hi thanks for the question if you have the drum out the heater should be at the back you should be able to see the element
Posted on Sep 27, 2008
  • 864 Answers
SOURCE: How do I remove the drum??
From the diagram at:
http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00013300/00013301.p03.pdf
It appears that you get access to the drum by removing the front panel.
Posted on May 28, 2009
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
The drum inside my ge wbvh6240fww washer is loose. I can move it around with my hands. During spin cycles it sounds like a tornado, and the room fills with smoke from where the drum rubs. The belt is fine,...
There is one bearing in rear tub/bearing is part of rear tub...To repair that unit you will need a rear tub/inner basket with spindal and possible a front tub if it damaged..If i was you I would price the parts b/c you may not want to repair it as it can be costly .....Good luck
Jan 31, 2011 | GE WBVH6240F Front Load Washer
Constant squeaking when running model # DNSR473EWOWW
You will need to replace the rear drum bearing,a fairly common concern on these models. you should also inspect the front bearing surface the drum rides on for wear since replacement of the rear bearing requires removal of the drum anyway, when ordering the rear bearing kit make sure it comes with the special high temp grease that is used on the rear bearing. Good Luck
Aug 14, 2010 | GE Dryers
My electric clothes dryer has started to occasionally make noise. could it be a bearing or a belt this is slipping. It's a GE machine about 12 years old.
could be the belt,drum glides,rear drum bearing or the idler pulley is weakening and letting the glazed belt slip on the drum
Sep 13, 2009 | GE DCL333EA Dryer
My dryer squeaks when it's on? It's a G E. How do I get inside to look around?
Check Idler pulley and rear drum bearing first. One of those is likely to cause squeaking when it fails. Idler pulley can be checked by removing lower rear panel. It's located right next to Motor.
Rear drum bearing is replaced by raising top and removing front and drum. Often just the bearing sleeve needs replacing unless the support shaft or housing is deformed.
Aug 21, 2009 | GE Dryers
Ge electric dryer dbsr453 heater element
Jul 17, 2008 | GE DBXR463EBWW Electric Dryer
DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
Apr 07, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
14 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
