Question about Garmin Nuvi 5000 GPS Receiver
Can not charge only works plugged in
Garmin 5000 cannot charge only operates plugged in?
    President:
  • 1,111 Answers
HI rromeo49,
Sunbury is 100% correct ...the garmin 5000 doesnt have a battery and will only work while plugged in to the home or car charger...disregard any advice tell you to change the battery..IT DONT HAVE ONE!
bill
Posted on Nov 01, 2010
  • 18 Answers
Your Garmin nuvi 5000 will never charge because it has NO internal battery. The only time it will operate is when it is plugged into a 12 volt power source. I have one and it really doesn't bother me at all. I bought a second cradle and a 12 volt adapter for use in the home.
Posted on Aug 01, 2009
  • Ben Dover Nov 01, 2010
    Hey Sudbury,
    you should come back and keep answering Garmin GPS questions to help rid this site of these GURUs (i use that term lightly) that BS there way through this site answering stuff they have no experience in .....the top Garmin gurus on this site still insist the garmin 5000 has a battery...lol
  • Geoff Southern
    Geoff Southern Nov 04, 2010
    Thank you for your kind comments. The reason I stopped answering questions was because of the b.s. from the so-called experts.
  • 728 Answers
You will most likely need a new battery as yours has most likely died completely so that it can not hold a charge. This is why you have to leave the charger in the unit for it to work. All you need is a replacement battery.
Posted on May 19, 2009
    hey jazzyboy, find an AOE you know something about, because Garmin GPS isnt it....the garmin 5000 doesnt even have a battery and if you had any first hand experience with them, you would know that...i dont know how you got that badge, but you should be stripped of it.
    Bill
    EX Expert Moderator
    Standing Member of G.O.T.
Fully charged with car charger. Reset to factory. Wont come on when connected to PC. Just flickers.
try not turning it on just connect to pc and see if the system finds a new device as a removable storage device . if it does find it , download the maps to it . LUCK and CHEERS
Sep 01, 2015 | Garmin nuvi® 5000 Car GPS Receiver
I just got my garmin... plugged in to charge... it was working... turned it on.... said it was downloading maps... then 20 seconds later.... blank screen, and it will not come on any more??
Probably your device was NOT FULLY CHARGED. It happens sometimes, when you try to download something, to be out of resources because of the operation.
Try this case to connect it again to recharge it and do a HARD RESET of the device. And keep it plugged over night - just to make sure in the morning it will be fully charged.
Mar 04, 2011 | Garmin GPS
Garnub Nuvi 500 power source
I have checked around but can't find anything smaller than 12 volt booster pack, the type used for boosting car batteries. They have a cigarette lighter outlet. They are quite heavy to carry around after a while but they can come in handy depending on the circumstances.
Aug 02, 2009 | Garmin Nuvi 5000 GPS Receiver
Garmin 205W doesn't work while charging in car
I have a 205w and have been very frustrated with this same issue, but I just so happened to find the following fix on another site today and it works great.
Follow these steps:
Turn on the unit on battery, press the battery icon and hold for about ten seconds, and the unit will switch to the diagnostic mode. Now plug in the USB cable and it will give you a loud bleep. Exit the diagnostic mode and it will operate normally while charging. This was handy to enter favorites while it was charging.
Jun 15, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 5000 wont turn on. I can plug up the usb up to the computer and the screen shows garmin logo with a gps connected to a computer like its charging. But when i press the power button weather it...
Your nuvi 5000 does NOT have a internal battery and that means that you cannot operate it unless it is connected to a 12 volt power source. Connecting it to your computer via USB allows you to install map updates, check for firmware updates, etc, but you will not be able to use it as a gps while it is connected to the computer. There is nothing wrong with your gps.
To use your gps in the home you need to purchase a 12 volt adapter, there are several types, plug the adapter into your wall outlet and connect your gps to it. If you can sit near a window it will help in picking up the satellite signal. Just keep in mind that you cannot connect the 12 volt power supply and use the usb cable at the same time. Enjoy your gps.
Jun 11, 2009 | Garmin nuvi® 5000 Car GPS Receiver
Cant turn on garmin 5000
I had the same problem so i went to the local best buy store and I found out that the Garmin 5000 doesn't have a built in baterry pack therefore it must be plugged into an external power source, such as the car jack or wall ac in order to use it. I exchanged my 5000 for the Garmin 880 which i find much better. Hope this helps...
Aug 20, 2008 | Garmin nuvi 5000 GPS
Garmin nuvi 260w not operating while plugged in
If you are trying to use your unit in the car via the USB port and not the supplied cable, it will not work. You must use the bracket that came with the unit or the specific charger that came with the unit. The pins in the Garmin USB charger only use two pins whereas a regular charge cable uses 4.
Aug 14, 2008 | Garmin nuvi 200W GPS Receiver
Problem when receiver is plugged in to charge.
Are you using the charger that came with the unit? If you do not use the one that came with it, the unit may be reading this as though it were plugged into the computer. It will charge then, but will not operate unless unplugged - just as you are describing.
Aug 12, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 5000 GPS Receiver Logo
171 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
