Need instruction for all-in-one adaptor plug voltage convertor
Need instruction
    Champion:
    New Friend:
  • 219 Answers
What is the make and model number?
Posted on Jun 09, 2014
Do I need to replace the battery and buy a converter, or buy a completely new one? Is it completely broken?
Normal the high input voltage should influence the output voltage. The120V AC to 9V DC will be blown, but with a bit of luck, your Crosley cruiser will be ok. Only if the power convertor is poorly made, the high voltage could have gone through the convertor and then it damaged everything in the cruiser. Try a new 9V power supply and see what it does.
Jan 19, 2015 | Crosley Audio Players & Recorders
I know there is a difference in voltage between here and Europe. What I can't find on my photive is which voltage it uses so I don't know whether I should use a transformer or just an adaptor when I p
Your device takes a standard Micro USB that charges at a voltage of 5 Volts, any plug from a charger or computer that has a USB port will provide the correct voltage for charging this device.
When going to Europe you can use this product Travel Adaptor Plug Worldwide European Visitor To Uk or to change
Pack of 5 UK to EU Travel Adaptors Amazon co uk Electronics to change the plug for you USB plug, depending if you are from the UK or US.
Sep 09, 2014 | Cameras
Step up convertor
VT 2300F Step Up Down Transformer with American Grounded Plug 2300 Watts
The wattage rating for the router is just under 2000 watts. You'll want a converter with a wattage rating more than the rating of the router.
VT3000 Step Up Down Voltage Transformer 3000 Watts
I would personally go for the 3000 watt converter.
May 19, 2014 | Skil RAS800 Router Table
Lost Power 120VAC cable, Am Now in Peru with 220VAC
1. Read the voltage info. on the razor. Their should be a label on the razor or info. in the instruction manual that came with the razor. 2. If the label doesn't say 120/220 input voltage you will not be able to use your razor. 3. If you use a adapter but the razor is rated for only 120volts input & you plug it into a 220volt socket you may burn your razor up & it may even cause death. 4. Remember find out the input voltage on the razor label & make sure it's the same as the output voltage as your wall socket. If it doesn't match, don't plug it up!
Jan 08, 2013 | Health & Beauty
My son has been given a PS2, it's the original type not the slimline. He also has a PS3, but still has many PS2 games, his old PS2 broke a long time ago and was thrown out. My question = The PS2 he...
There is no need for a special adapter. The cord that plugs into the wall is all that is needed for your PS2 to be used. Just make sure you have the rca plugs for audio and video in the correct sockets on your tv, plug in your controller, slide in a game, and awaaaay you go! :)
Hope that cleared it up.
Cheers from NZ
Jun 05, 2011 | Video Game Consoles & Games
Hi, i just got Loudbox100 from US,do i need a power converter or it is fine to use it just with the adaptor?I am from Europe.
If the adapter does NOT show it handles your voltage and frequency of your mains then you need to get an adapter designed for for the Loudbox and the mains you have.
DO NOT try to use a "convertor" driving the adapter you have.
Oct 06, 2010 | Fishman Loudbox 100
What do ineed to watch this tv now that we have digital services
Yes you do. Not only do you need a convertor box but an antenna to connect to the convertor box. The convertor box will have to be plugged in and depending on the antenna it might have to be plugged in. This tv does allow and external antenna to be connected to it. This is where you will attach the convertor box with whatever adaptor you may need. The tv will need to remain on channel 3 at all times.
May 05, 2010 | Coby CX-TV1 5 in. Portable Television
Where i find ac dc adaptor durabrand portable pdv 705
You should go to a local electronics shop with the old adaptor.
They merely need to match: Voltage in Voltage out Current requirements Plug size Plug polarity (center positive or negative) There is nothing "magic" about the original vendors power adapter.
Oct 06, 2009 | Durabrand PDV-705 Portable DVD Player
Vmx
looks like you need to replace the AC adaptor , test the AC adaptor with a multimeter to check Voltage , if there is Voltage reading?? then you need to replace the battery. hope this helps & please rate, AJ
Jul 02, 2008 | Nintendo DS Lite Console
Adaptor not working?
You need a transformer-type adapter that takes an input of 220-240V and steps it down to 120V output. If you bought the unit in the USA, you may have a problem if it is NTSC-only and doesn't have a NTSC-PAL switch to select the correct video format for India.
Dec 21, 2017 | Durabrand DUR7 Portable DVD Player
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
