SA-CT60 SOUND BAR REMOTE WON'T WORK
SONY remote stopped working for a SA-CT60 sound bar. Changed battery. No avail.
SOURCE: JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
Posted on Mar 11, 2009
ta_mcguire
  • 125 Answers
SOURCE: sony vaio sound stopped working
on your key pad there are also volume controls they will be the fn keys hold down the fn key and press the fn key with the little speaker on it
Posted on Jul 27, 2009
JULIANFIX
  • 975 Answers
SOURCE: my Sony handycam optical zoom stopped working
needs to be check by an authorized SONY DEALER.
theres a ribbon connector that needs to be replaced ,or If you drop the camcorder by accident it could be that the ribbon is misplaced, hope it helps , AJ
Posted on Oct 23, 2009
SOURCE: Panasonic SA-HT820V need universal remote that can control radio
I had a similar problem. I disassembled my remote (flat screwdriver and pulling, cleaned the circuit board and rubber buttons thoroughly with rubbing alcohol, then reassembled.
For some reason, the remote didn't work properly until I started pressing the channel buttons immediately followed by the volume buttons. It worked normally, after that. It was most likely due to the not yet dry rubbing alcohol interfering. My remote now works, normally.
Posted on Sep 05, 2010
  • 13 Answers
SOURCE: I have a Sony sound bar mod# sa-32se1 connected to
I had the same problem. I found that my sound bar can't be too close to the TV. I have my samsung TV on a platform ( not mounted) and the sound bar in front of it. In this configuration, the sound bar kept shutting off. I returned it as a faulty unit and the second one did the same thing. By chance I happened to move the sound bar off of the tv platform and the problem ceased.
Posted on Dec 18, 2011
Remote won,t work all functions for yamaha 70cu sound bar
Set-up the remote control with an other set-up code said for your device.
Sep 24, 2015 | Yamaha Televison & Video
My sony hc ct60 home theater sound system stopped
Your speaker's internal circuitry might be damaged, take it to your nearest Sony vendor and have it examines. Do not attempt repairs yourself, as that is generally dangerous and might damage it further.
Sep 14, 2014 | Audio Players & Recorders
Vizio sound bar 2.0 remote control not working
After only three days I would take it back, or at least take the remote back and try it on a different sound bar.
Jun 14, 2014 | Vizio VO47L 47 in. LCD TV
Sony sa ct60
My sound bar, just stopped working - when I push the power button on. It makes the red light go on for a mili second and then goes off again.
Any Ideas?
Jan 04, 2014 | Sony Audio Players & Recorders
Hook up a sony ht ct60 to a samsung flat screen
Your sound source comes from you cable/dish box. There should be an audio out (L/R) on the back. You can take the audio off the TV from those audio outputs if you have them available. Not all the box store tvs have these.
Jan 19, 2013 | Audio Players & Recorders
How to get my Sony HT-CT60 Sound Bar Home Theater programmed to my GCI Cable remote?
This worked for me, but I have a Comcast Motorola DVD-R:
These are the codes for your SONY SA-CT60 Audio Device. Follow the instructions below to program your remote.
silver_with_red_ok_button-lg.gif Most likely code: 30158
Others to try: 31758, 31759
To program your Comcast remote:
  1. Turn on the TV or other device that you would like to program.
  2. Press the TV button on your remote control.
    NOTE: If you would like to program your remote control to work with a DVD Player, VCR or Audio device press the AUX button.
  3. Press and hold Setup until the red light blinks twice, then release Setup.
  4. Enter the first code for your device listed above. If you perform this procedure correctly, the red light will blink twice.
    NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 4 with a valid code.
  5. Aim the remote control at your device and press Power once (press the Play key for devices that don't have a POWER button). If the TV turns off, make sure that the VOL+/- and Mute buttons also work. If so, you're all set!
  6. If not, repeat these steps using the next manufacturer's code (you may need to try several codes to find the one that works).
Nov 24, 2012 | Sony Audio Players & Recorders
I Have a 5.3 IR Remote and a vizio VSB200 Sound Bar. The remote will not program to the Sound Bar. The Optical Audio is connected to the TV. What do I need to do.
lojr,
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE buttons at the top of the remote light up.
filestream.ashx?id=435
2. Press the RECEIVER POWER button on the remote.
filestream.ashx?id=436
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the sound bar turns off. This process may take several minutes.
filestream.ashx?id=438
4. Press POUND (#) on the remote. The VCR MODE button will flash three times.
filestream.ashx?id=440(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press VOLUME on the remote to confirm the remote controls the sound bar. If this does not work, return to Step 1.
filestream.ashx?id=442
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
Jan 13, 2011 | DISH Network IR Remote Control
498 people viewed this question
 Grubhead
Grubhead
