Bios passwords enter password for phoenix BIOS CMOS setup utility
  • Computers & ... Master
  • 27,725 Answers
Locate Phoenix BIOS Passwords
The basic input/output system, or BIOS, is a program that acts as a digital liaison, managing communications between peripherals and the operating system.
Because the BIOS is critical to the operation of a PC, some computer manufacturers and workplaces employ a password for security.
If the password is lost or has been reset through electrostatic discharge, it would be impossible to guess without the aid of computer forensics.
Sometimes you can gain access to the BIOS through the keyboard, depending on the computer, but typically the solution is mechanical.
Contact your computer manufacturer.
All computer manufacturers have websites with technical support available.
Have your computer model number and serial number ready.
If the manufacturer is unable to help locate a password, standard back-door passwords may help.
So-called back-door passwords may help you access the BIOS. Try using the following back-door passwords to access the BIOS: phoenix, PHOENIX, CMOS, BIOS. BIOS passwords are case sensitive.
3 Contact the motherboard's manufacturer if the back-door passwords failed.
Find the motherboard's website for technical support.
You will need to open the computer case if you do not know the motherboard brand.
Electrostatic discharge can reset a BIOS password.
Shutdown and unplug the computer.
Unplug the monitor and all peripherals from the PC, including speakers and USB devices.
Ground yourself by wearing an antistatic wristband clipped to the metal case, or touch something metal before you open the case.
Use the screwdriver to loosen and remove the screws from the case. Look for the motherboard, the largest circuit board inside, attached to one side of the case.
5
Printing on a motherboard can be hard to see without a magnifying glass. Examine the motherboard for a brand name.
A good place to start searching is near the processor, the large square box on the motherboard. A flashlight and magnifying glass are especially useful for a clear view of the motherboard.
The brand name could be printed anywhere or, sometimes, not at all.
6
The motherboard battery is round and fairly flat. Locate the CMOS battery while you have the case open.
If contacting the motherboard manufacturer failed, you will have to remove the battery.
The battery is circular, about the size of a dime, but as thick as two to three stacked dimes.
Do not disconnect or remove anything yet. Removing the CMOS Battery
7
Note the location of any cables that need to be disconnected. Use the digital camera to take pictures of the motherboard, or sketch the location of cables and connectors.
f any components or cables need to be moved or unplugged to reach the battery, you want to remember their exact location.
8
Leave the battery out for at least 20 minutes. Remove the CMOS battery carefully so as not to snap or break the clamps.
Leave the battery out for 20 to 25 minutes to allow the capacitors to completely discharge any memory. Avoid touching anything else in the computer.
9
Tighten the case screws when done. Return the battery to the motherboard, and reconnect any cables that were disconnected in the case. Close the computer case and tighten the screws.
10
Look for the setup message on the monitor. Turn on the computer and closely watch the monitor for the "Entering Setup" message that appears before Windows starts.
The message will tell you which key to press to enter the BIOS setup.
You may need to reboot a few times to see the message, as it appears on the screen for just a few seconds.
11
Carefully read the settings information on the monitor. Follow the directions on the monitor for changing the date, boot sequence, and any other settings.
Work slowly and read the screen directions thoroughly.
Be alert and cautious.
Once the settings are saved, the system will start, and the password will have been removed.
http://www.computerhope.com/help/phoenix.htm
Phoenix BIOS help and simulation
Reset a Phoenix BIOS Password
The Phoenix BIOS (Basic Input/Output System) is a simple program that resides on the CMOS ROM (Read Only Memory) chip on a computer system's motherboard.
There are a couple of major BIOS manufacturers, including Phoenix. Each BIOS contains a set of initial parameters that can be set using a simple text interface.
A security feature is built into the program that allows the computer user to set a password for the BIOS.
When activated, the computer will not complete the booting up process until the password is entered. If the password is unknown, then it must be reset in order to gain access to the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Turn off the computer and unplug all cables from the back of the case, labeling each one if it isn't color coded. This must include the power cable, which should also be unplugged from the wall or power strip.
·2
Open the computer case by removing the screws on the back that hold the side panel on the frame.
Some systems will use thumb screws and no tools will be required.
However, most computer systems will require the use of a Phillips head screwdriver.
·3
Locate the CMOS battery.
It will be located near the CMOS chip and looks like a large watch battery (see the link below).
http://www.dewassoc.com/support/bios/bios_password.htm
Check to see if there is a three-pin jumper switch near the CMOS battery as well.
It is only present on some motherboards and will be used in step 4 if it is there.
·4
Remove the CMOS battery.
Leave the battery out for 30 minutes to allow any residual electricity in the CMOS ROM to discharge.
This will effectively reset all settings in the CMOS to default values and clear the password.
If the three-pin jumper is present, leave the CMOS battery in place.
Move the jumper on the pins from the side it is on to the opposite pins.
Then attach the power cord and reboot the system.
It will not boot up but actually clear the CMOS settings.
Remove the power cord and move the jumper back to its original pins. ·5
Re-attach the computer system cover and replace the screws holding it in place.
Re-attach all of the cables to the back of the computer and reboot.
Your Phoenix BIOS password is now reset and you will be able to boot into your operating system.
You may need to re-enter the CMOS settings if it doesn't recognize all of your components such as expanded memory or DVD drives, etc.
Posted on Dec 30, 2013
StuartB
  • 807 Answers
SOURCE: bios password for phoenix bios
Try these:
http://www.uktsupport.co.uk/reference/biosp.htm
Posted on Mar 28, 2008
rahul26485
  • 611 Answers
SOURCE: phoenix bios setup utility page,
do one thing go for the othr key board and try if working fine then you key board problem after that is not working then go for the install the new o/s.
Posted on Jun 07, 2008
leecom72
  • 4806 Answers
SOURCE: Reset BIOS password
ok, this time try to reset the bios using the jumper (small bit of coloured plastic near the battery) move the position of the jumper and hit the on/off button, the computer should not start if you have done this right, move the jumper back to its position and start the pc, go straight back into the bios and set the date and time, hit F10 and ok or yes and you should have full control of the bios.
if there is no jumper, remove the battery again for 10 mins and make sure the power cord is removed from the back, hit the on/off button a few times to drain any residual power, after 10 mins replace the battery and do what i told you to with the bios
good luck
Posted on Nov 17, 2008
  • 21 Answers
SOURCE: can´t reset BIOS/CMOS on MPC T2200 laptop
reseat the jumper inside the mother board
Posted on May 01, 2009
SOURCE: pc "bios"problem
this looks like you have kept the bios password and you forgot it. just do one thing open the cpu case to access the inside of the system and then just remove the battery in it. wait for 5 min and again plug in the battery. thats it your bios memory password will be reset.
2nd solution without removing battery. just reset the bios as shorting the jumper pins. consult your motherboard book to know where to find the bios reset. it will be written as CLEAR CMOS.
Posted on Dec 21, 2009
Whaat is phoenix bios setup utilitiie and whats the password
You may be able to access the bios using one of these backdoor passwords for the phoenix bios
BIOS
CMOS
phoenix
PHOENIX
Or you may be able to reset the bio password using this utility.
http://www.cgsecurity.org/wiki/CmosPwd
Mar 30, 2015 | Toshiba Satellite Computers & Internet
I forget my bios password for Acer Travelmate 5330 Labtop and i need the backdoor password to enter to the bios and reset the password
Award BIOS backdoor passwords:
ALFAROME ALLy aLLy aLLY ALLY aPAf _award AWARD_SW AWARD?SW AWARD SW AWARD PW AWKWARD awkward BIOSTAR CONCAT CONDO Condo d8on djonet HLT J64 J256 J262 j332 j322 KDD Lkwpeter LKWPETER PINT pint SER SKY_FOX SYXZ syxz shift + syxz TTPTHA ZAAADA ZBAAACA ZJAAADC 01322222
589589 589721 595595 598598
AMI BIOS backdoor passwords:
AMI AAAMMMIII BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER A.M.I. CONDO
PHOENIX BIOS backdoor passwords:
MISC. COMMON PASSWORDS
ALFAROME BIOSTAR biostar biosstar CMOS cmos LKWPETER lkwpeter setup SETUP Syxz Wodj
OTHER BIOS PASSWORDS BY MANUFACTURER
Manufacturer Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
Dec 12, 2010 | Acer Aspire 5330-2339 Notebook
HOW DO I RESET THE BIOS PASS WORD ON A TOSHIBA LAPTOP L355
Hi if you want reset bios password ( asume you forget it) You need reset bios find reset CMOS jumper or take out battery for few sec. All settings in BIOS will be reset. Let me know if you need more help
Aug 25, 2010 | Toshiba Satellite L355-S7811 Notebook
Forgot the password for phoenixbios setup
You need to contact your pc manufacturer.
Tell them to provide you with the steps to remove and reseat the CMOS battery.
Then remove and reseat the CMOS battery which holds the BIOS password.
This step will remove the password.
Issue is resolved :)
Jun 18, 2010 | Advent Netbook
My Acer some how got locked up in the CMOS. Need Password.
Hi there!
AMI BIOS
A.M.I.
AMI
AMI_SW
AMI?SW
BIOS
HEWLITT RAND
LKWPETER
PASSWORD
Oder
AWARD BIOS
01322222
589589
589721
595595
598598
aLLy
aLLY
ALLY
ALFAROME
aPAf
_award
AWARD SW
AWARD PW
AWARD_SW
AWARD?SW
AWKWARD
BIOSTAR
CONCAT
Condo
d8on
djonet
HLT
J64
J256
J262
j332
j322
KDD
LKWPETER
lkwpeter
PINT
pint
SER
SKY_FOX
SYXZ
TTPTHA
ZAAADA
ZBAAACA
ZJAAADC
Russian Award Passwords:
% p%
% p%
IBM APTIVA BIOS
Press both mouse buttons repeatedly during the boot
PHOENIX BIOS
phoenix
OTHER BIOS
ALFAROME
BIOSTAR
biostar
biosstar
CMOS
cmos
LKWPETER
lkwpeter
setup
SETUP
Syxz
Wodj
SOME COMPUTERS WITH TOSHIBA BIOS
Hold down the Shift key as the computer is booting.
I hope i helped you with this list i entered as much i could research by some of my books.
Please rate my answer! =)
Sincerelly
Aleksandar Adzic
Apr 16, 2010 | Acer Aspire 7720 Notebook
Phoenix bios setup utility is requesting a password
Actually, if you do not know the password it is best not to guess because 3 wrong guesses would result to losing the data on your hard drive forever.
the simplest way to remove a bios setup utility password is by removing the cmos battery. computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
1. open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. please refer to the picture below. Some computers have this part standing upright.
Once you have located it, observe how the latches are holding it. There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
2. Make sure to power down the computer, unplug the power cables and unplug any USB devices if they are powered. The computer must not be able to get power from anywhere for this to work. Take out the CMOS battery and wait 10 – 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
3. Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto “Load BIOS Defaults” in BIOS and save the changes to fix them.
Apr 13, 2010 | Computers & Internet
Acer aspire 2920 bios password removing
The password to by-pass bios password are these, hope they will hope you, once you enter BIOS using these passwords you can reset it to normal
Phoenix Backdoor BIOS Passwords:
  • BIOS
  • CMOS
  • phoenix
  • PHOENIX
Mar 18, 2010 | Acer Aspire 4720 Notebook
Phoenix bios password
The thing is that somebody set bios password. On phoenix bios based on intel platform? like yours normally if you will enter bios password incorrectly 3 times bios will lock the computer and it will generate 12 digit lock code. You will need to contact Toshiba technical support to get bios unlock password. (Normally this is generated by them within couple of hours.)
I would recommend you to check with toshiba support before locking bios (entering password incorrectly 3 times)
May 28, 2009 | HP Pavilion dv1000 Notebook
Ibm thinkpad r51
What is the default password for my R51 Thinkpad by IBM Model # 2888?
Feb 04, 2009 | IBM ThinkPad R51 Notebook
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
