Question about Syntax Televison & Video
No signal on screen
Trying to hook up television to cable box, I have Comcast HDMI, the flat screen is multimedia model# LT42HVi
  • Syntax Master
  • 9,639 Answers
Make sure in the setup menu that "Cable" is selected instead of Antenna or off air. then do a channel search with the cable box connected and powered up.
Posted on Jan 06, 2014
SOURCE: No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Posted on Aug 27, 2008
SOURCE: says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Posted on Oct 13, 2008
mistersony
  • 320 Answers
SOURCE: Sony HDTV flat - no picture with HDMI cable and Verizon FIOS box
Probably a handshake problem with the cable box. It is common for cable boxes to have HDMI handshake problems. Hook the box up using the component cables and you should be fine
Posted on Oct 18, 2008
zlittell
  • 30 Answers
SOURCE: Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Posted on Aug 03, 2009
SOURCE: samsung 610 46'' lcd - hdmi input not working
why hdmi input wont show up
Posted on Dec 22, 2009
On my LT42HVi with HDMI input source, the image comes through with a lot of green then will change back to normal color. Switching cables or HDMI input port makes no difference. Using normal TV inpu
is the normal tv input for high definition? Don't understand that term. I have a dish receiver, when I use an hdmi cable I get a really nice picture even with Roku
Jan 02, 2015 | Olevia LT42HVi 42 in. LCD Television
Trying to hook up my panasonic tc-p50c2 to comcast hd digital cable box and cant get it to work with hdmi cord..nothing is showing
Use only the hdmi cord to hook it up and go to menu on the tv and select hdmi for hook up and you should get a picture. Make sure your cable cord is the only cord running to the cable box , you don't need any other cord.
Feb 09, 2011 | Panasonic TCP50C2 50 in. TV
Picture size doesn't fit the screen I tried to adjust the aspect ratio but the option is locked on the menu. What to do? (Olevia TV model lt42hvi
You cannot change aspect ratio when recieving HD signal. Try changing the cable box or satellite box format or aspect ratio.
Dec 30, 2009 | Televison & Video
Use Comcast and I cannot program my remote. the
The signal is comcast,U have a comcast box right use the comcast remote.Try this website 1-800-Rmotes Factory original.For replacement,less trouble than with the universal remote,cost less the the tv company trying to sell u a new remote.
Nov 18, 2009 | Olevia LT42HVi 42 in. LCD Television
I have my HDMI cord hooked up from the cable box to the tv and it still say "no signal" what do I do?
if you have more than one hdmi input try the other. if not try checking the menu setting be sure its on the right input lable i.e. hdmi1 hdmi2....etc
check the cable be sure its in working order, check the input device i.e. dvd, cable box, be sure there's an input signal too the tv.
If the problem is still there..... then the hdmi connector leads need re-soldering or hdmi circuit fuse has popped or hdmi buffer chip has a problem and needs replacing.
circuitworld@comcast.net
http://www.corkin.com/Profile/view.cfm?userid=77703
http://www.google.com/profiles/circuittvrepairs
http://circuitworldrepair.com/cwr.html
-Contact Us 443-802-7251
CWR-on_line Tech Rpt
Oct 29, 2009 | Olevia LT32HVM 32 in. LCD Television
While watching tv on our new 42in.lcd flat screen and hooked up to our new hd cable box from comcast there are intermitent total signal losses from 3-5 seconds . Tv says searching for signal for a few...
yes we have to do a process of elimination to fix or narrow the problem down. try another box and see the results.if box work on another tv then u have tv problem
Aug 17, 2009 | Polaroid FLM-2632 Television
LC32OEM9 says Not Supported Format on HDMI Input. It worked when we first hooked up the TV. Then it started working sporadically now it very very rarely works and when it does it only works for maybe 15...
I'm thinking the Comcast DVR box maybe putting out weird HDMI signals and the TV can't translate it. I would call the Comcast people on this one.
In the meantime, I would try finding another source the uses a HDMI cable to rule out the TV as the problem. Basically, testing the TV to see if the problem still happens when you use something else than the Comcast box. Try a Blueray player, Playstation 3, or Xbox. Just something that uses a HDMI cable.
Apr 30, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Green screen when pluged threw hdmi
TRY A NEW HDMI CABLE 1ST. ALSO TRY ANOTHER INPUT. IF IT IS GREEN ON BOTH YOU HAVE A SOFTWEAR PROBLEM WITH THE UNIT AND WILL NEED TO CONTACT AUTHORIZED SERVICER TO SEE IF THE IS A SOFTWEAR UPGRADE OR TECHNICAL MENU ADJUSTMENT THAT CAN BE MADE.
Feb 02, 2009 | Olevia LT42HVi 42 in. LCD Television
No Signal HDMI
Aug 04, 2008 | Insignia 42" LCD Flat-Panel HDTV
Televison & Video Logo
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Jaime Hernandez
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
