TV WILL NOT TURN ON DO TO A POWER SURGE
IS THERE A RESET BUTTON ON THE INSIDE OF THE TV OR A WAY TO GET POWER BACK TO THE TV?
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
There is no reset button outside. The main power supply regulator section [SMPS] should troubleshoot. Contact any service technician. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Dec 30, 2013
4 Suggested Answers
SOURCE: proscan 36 inch tv
Good day.
The spark the you see means that your wall socket is loose. Have it fixed by a qualified technician. With regards to your unit, it has an internal problem. In my experience, the power supply is not dissipating power to the circuitry. The problem is contained in the power supply, have it checked by a technician.
chris
Posted on Mar 23, 2008
  • 1694 Answers
SOURCE: JVC TV AV-32260 power surge now power button flashing
Check for swollen top on power supply capacitor ......check
all caps with ESR meter....all with C900 series location #'s..
also check C523 in horiz drive circuit..............T.
  • 17 Answers
SOURCE: 27 inch Panasonic TAU tv won't turn on, then sparks when you unplug and replug it in
do you get extension corn in Iowa?
Posted on Jul 15, 2009
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
Today my power went out for a split second and came back on I turn my TV back on it makes a high pitched whining noise and the screen wont turn on. Cant add picture but model number is MW30G71.
unplug your tv. let it sit for a good bit. 1/2 hour did your power just go out or did you have a power surge then no power. surges cause the grid to go down for a second too and that causes problems too. surge protectors are good for everything. also are you on cable? if so have the cable company check they're filters into the house may be an issue but check the tv after a half hour unplgged and then plug in and turn on normally? sometimes it needs a reset time period before the fuses inside will reset themselves.
Nov 17, 2015 | Televison & Video
Will not turn on after power outage. Is there a reset button?
No, no reset button. Some sircuit of your TV was victim of poser surge, typical to power outaget events. Flat TVs are paerticularly sensible to power issues.
You'll have to take it to repair
To protect your TV buy a surge protector
Top Rated in Surge Protectors
Jun 19, 2015 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Due to power surge tv will not turn on but stand by light is still on is it possible to reset or is it likley fried?
    Try unplugging the power then hit the power button on the tv then plug it back in the wall and try to turn it on
    Jun 21, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
    I was watching my tv when my son hit the reset button on my surge protector..now my tv will not turn on. Any ideas?
    Turn everything off, the tv the power and make sure the button is not active at the moment. Some surge protectors do come with a fuse but when you turn the surge protector back on itself make sure it is recieving power, there is usually a red light on the switch while recieving power. Then try again once you know there is power to it.
    Feb 06, 2011 | Vizio E370VL 37 in. LCD HDTV
    I have a Mitsubishi projection model WS-B55 that is plugged into a surge protector. The power went off for about an hour or an hour and a half this morning, and the power light is flashing. I called...
    First, to answer your last question, not all power outages and subsequent surges are created equally nor are all surge protectors. Also, after a power outage where the subsequent surge is so strong that it got past your surge protector and knocks out your TV and it's never done that before... REPLACE YOUR SURGE PROTECTOR.
    However, that being said, in my experience it is unlikely that the TV is going to require a technician. Understand that the person that you spoke with in tech Support is not a technician and is reading off of a list of troubleshooting pages that are more extensive then what's in the manual. What the technician is probably not aware of is that your TV, like most home electronics, has a safety failsafe that requires the device to be separated from power completely before doing a system reset
    First, after pressing the button it's supposed to flash for about a minute anyway but I'm assuming that after it's done pressing that the TV is still not firing up.
    Unplug the TV, let it sit for an hour, plug it back in (to the wall, not the suspect surge protector). If the light is still flashing, press the reset button again and wait for it to stop flashing and attempt to turn it on again. If it doesn't work, unplug the TV, follow the same steps however, let it sit for 24 hours before plugging it back in. That length of time is not common but some sets do require it.
    If none of this works, then I would say that it's time to call a technician.
    Nov 22, 2010 | Mitsubishi WS-55819 55" Rear Projection...
    TV Zoom mode
    Change the batteries on the remote, point the remote at the Sony, and hold in the power button for 5-7 seconds. Then depress and re-press the power button - see if you can get the tv remote to respond again.
    Then, always try the quick reset:
    How to perform a power reset on a Sony® television.
    1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
    2. Unplug the television power cord from the electrical outlet.
    3. Let the television remain without power for 60 seconds.
    4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    May 16, 2008 | Sony KV-32FS13 TV
    No Power.
    You might have blown a fuse inside the TV. Lots off volts can go into those TVs. Make sure you are under warrinity and return the thing. Maybe also a malfunction.
    Nov 10, 2006 | Mitsubishi WD-65000 65" Rear Projection...
    Televison & Video Logo
    20 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
