Question about Canon imageRUNNER 400S Copier
I have IR 400 zerox machine..my machine problame is that right close the right side cover...but actully the door proper close..then why are dispaly shows close the right cover..i m geting confuse..please help me and sort out my probalme
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Right cover sensor switch is not pushed well, pls check well
Posted on Dec 30, 2013
  • 168 Answers
SOURCE: close the front door and second problem is E805
805 is a bad fan usually one of the three on the exit door
Posted on Dec 10, 2008
iservice
  • 318 Answers
SOURCE: Right-side cover will not close, springs are disconnected.
Normally the right cover hooks break off and causes the door not to close.There is square holes in front and back of the right cover that you can use to hook the spings again.
Posted on Apr 28, 2009
guru_dev
  • 315 Answers
SOURCE: error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Posted on Jun 01, 2009
  • 118 Answers
SOURCE: i have a canon ir 400 the machine shows close the
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Posted on Jul 06, 2009
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
Closed 1st side cover konica minolta bizhub 185
Check the 2 actuator at Right Door assy, may be broken, so while closing it is not blocking/hitting the sensors on body.
check properly - at Rear-Top & Front-Below on Right Door assy.
Dec 09, 2016 | Konica Minolta bizhub Office Equipment &...
Close section properly
Its not talking about the bypass tray. Its saying the right side door isn't closed. There is a cover above the fuser that may not be closed. Open the right side door and see if you see any broken parts. If everything is closed correctly and not broken, the message will go away.
Jan 24, 2014 | Konica Minolta bizhub C250 All-In-One...
I have ir 400 machine its front door is close but error is close the front door whats problem
Either you misunderstand this message or the switch which says the door is closed is not doing so.
Nov 15, 2013 | Canon imageRUNNER 400S Copier
Problem is canon ir 400 close the front cover?
its because of composit power supply(hvps) replace it...........
Aug 25, 2012 | Canon imageRUNNER 400S Copier
Canon xerox ir 400 error E805 the problame is machin display open the front door
This problem due to your composite power supply,you can see 3 blue capasitor has burned,change it with 4 amp fuse near that caps
Sep 07, 2011 | Canon imageRUNNER 400S Copier
I installed the Sharp ar-5220 and received an error message. CH keeps blinking and does not allow me to press any buttons.
Make sure your toner catridge is installed properly then open the side door and front door , and close it properly the code CH means your machine door interlock is open. Vote for this rate this
May 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have Canon IR 400 photocopier. My problem is -
This not really a problem. Canon Copiers have various counters that track the counts of Various sized papers. Long, short and the like. The only counter that really matters in the 101 or total counter. This the counter that tracks every piece of paper that goes through the copier. This is the counter used to track copy usage. If you have a service contract this the counter the dealership will use to track copies for billing. Ignore anything but the total counter.
Mar 22, 2010 | Canon imageRUNNER 400S Copier
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Jul 06, 2009 | Canon imageRUNNER 400S Copier
HP 3500 color printer
If you can see what is stopping the door from closing, and it appears to be on the right side of the printer near the top where the cartridge engaging pins are, and you remove all the cartridges and transfer belt and the door closes well, you may want to try this: There is a small silver screw at the top of the right corner of the case. When our front door would not close properly with the cartridges and transfer belt assembly installed, I took off the right side cover and took out that top corner screw. Then I slid the long white engaging rack that is on the lower right side of the printer toward the front door, which retracted those cartridge pins that are triangularly-shaped on their ends. Once the door would close properly with the cartridges and the transfer belt installed,and the pins engaged properly to open the cartridges as the door closed, I put the top corner screw back in and the side cover back on. I hope that helps you.
Sep 17, 2007 | HP Color LaserJet 3500 Printer
Canon imageRUNNER 400S Copier Logo
old marine
old marine
