Question about Toshiba 72HM195 72" HDTV
No blue light after boot
The original problem was continuous flashing blue light. Replaced the projector lamp bulb opened the unit up to check for other physical damage and found none. Now when I power the unit, the blue power light will not come on after boot. Only item apparently operating is the fan for the PC boards. Does anyone have any ideas?
  • 38 Answers
Yes, I've seen the ballast bad after a lamp shorts out. It takes out a 1K resistor out in ballast. If original lamp blew up this could be your issue
Posted on Jan 01, 2014
SOURCE: green light flashes 3 times, tv won't come on
If its not the bulb, I have the same problem
Posted on Nov 22, 2007
SOURCE: Toshiba 52HM95 Light Engine
this is the worst investment I have ever mede after replacing the bulb for every six months the color wheel goes out and its 750 to repair
basically after the initial arm and a leg the TV came back for the other ones And the customer service from Toshiba is even wors than the TV I guarantee you will end up cursing at them before you hang up in there face after the smart *** remarks If you buy this TV your as stupid as I was
Toshiba is the worst brand to buy
Posted on Nov 07, 2009
  • 1039 Answers
SOURCE: I recently replaced the lamp bulb...it worked for
You could have gotten a defective lamp. Try another lamp. Since you have a Toshiba youll be using it even if you don't need it now. Toshibas have short lamp life. If lamp does not fix then the light engine will have to be removed and sent to Toshiba to be rebuilt. They are no longer available.
Posted on Dec 05, 2009
axeist
SOURCE: 52HM84 Toshiba DLP with apparent failed lamp (replaced ballast)
I found R3 on the original board to be open, along with reading an open on CR1, D5 and D6. All the other transistors and the transformer check out. The only thing I have to do now is find out the specs of the diodes. The replacement board also had CR1, D5 and D6 open (R3 was OK). There had been some threads on various locations where remanufactured boards had bad components (the transistors were changed but not some of the other components).
Posted on Jan 18, 2010
  • 280 Answers
SOURCE: I suspect the cooling fan is burning/wearing out.
the fan has (maybe - check it) a filter screen between it and the outside air... cleaning this filter will increase airflow. cooling fans are really cheap and its a good idea to replace a fan that has had a hard job in a hot environment BEFORE it fails...
sorry, I dont know how to open the door though... maybe you'll have to take the entire case off... then you'll see how the door comes off for next time anyway - if you're "servicing" the set you could do worse than get the case off and clear the dust out.
Posted on Jan 25, 2010
Projector tdp s9 lamp indicator turns yellow light, even when new bulb is replaced correctly
Once you replace the lamp you need to go into settings and reset the bulb hours back to zero. That will take care of your problem
Feb 14, 2015 | Toshiba TDP-S9 Multimedia Projector
Optoma HD80 flashing blue lights
Sound like the original color wheel for Optoma HD80 is bad.
If the unit has been moved when hot.
If not, try un-plugging the unit for a few minutes and re-connect.
Hope this helps
Mar 23, 2014 | Optoma HD80 Projector
Blue light flashes, lamp doesn't light
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Lim
Mar 04, 2014 | Epson ELPLP69 - V13H010L69 Projector...
Origional Epson 3010 bulb burned out after 2 years. New bulb died in a month
our company supply the Original lamp ,unit price is USD200
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Dec 08, 2013 | LC EPSON ELPLP68 / V13H010L68 Projector...
All the lights flash the fan runs continuously and it has trouble powering up and down
NHSA275W
1,check the lamp or lamp ballast
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Jan 18, 2013 | Christie LX505 OEM Projector Lamp
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
I had a bulb burn replaced both bulbs worked for a couple of days but now it wont power up only lamp1 light blinking. I have tried taking bulbs out and putting them back in still nothing, also the lamp...
the lamp units should be properly aligned with the 2 very tiny switches
between them. If not lamp led will blink.
If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
Original lamp modules are AH-45001 and AH-45002, two different
units needen for 1 projector, reset procedure is different for each lamp !!
Dec 21, 2010 | Eiki EIP-4500 DLP Projector Multimedia...
Sharp xvz-10000 projector.\r\nI replaced the lamp and RESET the timer and projector worked fine. Now about 2 months later I have to unplug to reset the unit and when turning on the first blue light stays...
Have a nice day!
Jerry
Lampdeng Limited
Nov 18, 2010 | Sharp BQCXVZ100001 Projector Lamp for...
WHY DOES A BLUE LIGHT CONTINUE TO FLASH ON TOP AFTER THE SCREEN HAS WENT OUT AND WANT COME BACK ON DOES THIS MEAN THE BULB NEEDS TO BE REPLACED
how many times does it flash? could be lamp, fans or overheating. clean it out with canned air. if the lamp has bulges, black spots, or fogging, replace the lamp.
Dec 08, 2009 | LG RD-JT91 Multimedia Projector
Epson ELP 3000 clicking noise and all lights flashing
1,Check the fans ,whether each fan is running,when you turn on the projector
Have a nice day!
Jerry
Lampdeng Limited
Mar 26, 2009 | Epson (1023661) Projector Lamp for...
Toshiba 72HM195 72" HDTV Logo
49 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
