Question about Rancilio Epoca ST-1 Espresso Machine
Rancilio Epoca group head water temperature problem
The temperature of the water coming out of the group head is 184 degrees and after 15 seconds goes down to 165 degrees. The steam wand makes steam just fine. Is there and adjustment for the water temperature of the group head? If not, what could be the problem?
unclebuck521
SOURCE: water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Posted on Feb 03, 2009
  • 1089 Answers
SOURCE: no water through group head
Hi
More than likely your 3 way valve is stuck. It is located behind the front panel and when the 2 screws are removed it slides to the right. Unplug your machine before working on it. The 3 way valve is on the left and you can remove the dispersion tube on the bottom(unscrews) 14mm nut holds the solenoid on and you can slide the solenoid down the shaft. The big nut at the top of the shaft will unscrew and there you will fin the solenoid inside with a big spring. If its not stuck it will slide out and you probably need a new 3 way valve, but more than likely its stuck. Some times just tapping the nut on something hard will unstick the solenoid. Clean good and reinstall.
Posted on May 26, 2009
EsWorld
  • 1618 Answers
SOURCE: No steam from my rancilio silvia. unit about 2 yrs
Check the thermostats on the top of the boiler one of them tripped.
Posted on Feb 03, 2010
  • 100 Answers
SOURCE: Hi! I have a Rancilio epoca DE 2 group machine and
Your boiler is flooding because the water level probe is not behaving properly. The machine thinks it needs water.
Posted on Feb 04, 2011
EsWorld
  • 1618 Answers
SOURCE: I am using a two
Hold down right most button for 8 - 10 seconds, then press button to program when you get your volume press button to stop repeat for next buttons, when done press stop button to get out of program mode.
Posted on Apr 20, 2011
Rancilio coffee machine .no water coming out of the group head . steam coming of the group head
Hi Ewah,
If you are getting steam from the group and no water when you turn on the water button - then you may have a group blockage.
The fix depends on the type of machine you have.
If it is a commercial type - then call in a qualified coffee technician.
If it is a domestic type like rancilio sylvia, the you could try to descale - maybe too late, but worth a go.JURA descaling tablets
If when descaling, no water is coming from the group try leaving the steam tap open when asking for water.That way you may get the descaler liquid moving inside the boiler and it may clear the solenoid valve blockage.
If no joy with that you may need to replace solenoid valve.
230V 9W PARKER SOLENOID
Domestic machines need regular descaling to avoid group blockages.
Mar 18, 2017 | Rancilio Coffee Makers & Espresso Machines
What happens when my new rancilio epoca coffee machine the water doesn't flush out.. It's a 2 group, the left one works, but the right one it's like water dripping only
Solenoid valve OR dirty and blocked shower screen OR dirty and blocked jet OR crap in the line to the R/H group..
Simple fix if you are in Brisbane.
May 25, 2014 | Coffee Makers & Espresso Machines
I have rancilio epoca e2. One side is not pulling a high enough temperature thus not good crema. Other side works fine
The only thing that comes to mind is the metering jet on the group as well as the reducers on the tubes bringing water into the group.
Jun 21, 2011 | Rancilio Silvia Espresso Machine
I am using a two group Rancilio Epoca espresso machine and would like to know how to set the water levels for the semi-automated buttons.
Apr 19, 2011 | Rancilio Epoca ST-1 Espresso Machine
Hi! I have a Rancilio epoca DE 2 group machine and the antivacuum valve spurts water as the machine is heating up. ow can I fix this? Please advise
Jan 09, 2011 | Rancilio Epoca ST-1 Espresso Machine
I am trying to get the sight glass out of a two group epoca. It looks like the metal nipples extend into the glass at both ends with no way to move the glass up or down to free it up. I don't want to break...
If the epoca is the same as mine, the sight glass is made from a plastic material and if you pull it from the middle it will bend and come away from the nipples without much trouble..
Jun 17, 2010 | Rancilio Epoca ST
Water doesn't come out from showerhead once the button is pressed - can hear the water pump going, the top of machine is warm so boiler is functioning.
Does water flow without the portafilter in place, if yes then check grind, if no then remove screw,filter and diffuser and press brew button, if water flows clean filter, if no water then the micro jet in the group head is blocked or the solenoid is clogged.
Oct 06, 2009 | Rancilio Epoca ST-1 Espresso Machine
Rancilio epoca - heating element continue to stick on
It's the thermostat for certain.
Te release valve is put there it be sure the tank pressure doesn't get too high such as to cause a steam explosion/rupture of the tank.
Jan 30, 2009 | Rancilio Epoca ST
No water coming out of coffee dipense head on one side
The metering jet and or filter on the back of the group is clogged.
Dec 11, 2008 | Rancilio Silvia Espresso Machine
Rancilio Epoca ST-1 Espresso Machine Logo
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
