Question about Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Pop up saying 'hour' from game time.
In the bottom l hand corner the pop up says 30 mins, 2 hours, ect from game start. How do I remove/ stop this?
Starts and cuts off
serial number/keygen for registry reviver
Jan 28, 2014 | Cars & Trucks
Amount of labor involved in replacing water pump in dodge ram 1500
For the water pump at a pro shop 2.3-3 hours max.diy on waterpump factor in another hour or.two if u have to rig or go buy a tool for fan removal rusted or.broken bolts ect ect For the belt only 30 minutes for a diy with basic skills and hand tools.
Dec 04, 2013 | 1997 Dodge Ram 1500 Truck Serpentine Belt...
My Beaumark popcorn maker isn't working! I have the type that is a large domed electric pan, with a metal 'stick' that goes around to move the kernels (presumably to stop them from sticking?)....
your problem is in the instructions.. you need to make it a little hot, means run it on empty for a few min. stop the machine, and add 2 tablespoosn of veg. oil your fav. oil, not olive. add enough pop corn to fill the inner circle surface of the bottem plate, then run it again until the bowl is full.. maybe 5 min. You should have perfect bowl full of pop corn.
enjoy :-)
Sep 15, 2011 | Vacuums
My Coby mp3 player won't connect to my computer
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and photo folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF ! ! !
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player battery charging.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8-16 hour charge with the player turned OFF connected to the computer.
IT WILL NOT CHARGE WITH A COMPUTER UNLESS IT IS TURNED OFF WHEN YOU CONNECT IT.
f. Use the Coby Manager to disconnect the player
(Found HERE if you have had to format the player)
CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Go to the DEVICE TAB
2. CLICK on EJECT Button in lower right hand corner.
3. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
4. The second pop-up screen will tell you "The device can now be safely removed from the system."
5. The Coby will now show "Please Wait..."
6. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps
Apr 05, 2010 | Coby MP-610 MP3 Player
My ps3 will start up my modern warfare 2 game but right before the part to press start to select what mode i want to play in it will pop up a system error code. Also when i try to just sign in outside of...
There is a worldwide issue with PSN at the moment:
We're aware that many of you are having problems connecting to PSN, and , we're looking into it. Stay tuned for updates. about 1 hours ago via web SonyPlayStation
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
I have a red flashing light on my start button in the bottom right corner, on screen says system error E47. xbox 360
what you need to do is disconnect the xbox from your tv and wrap it in 2 towels turn it on and leave it for 30 to 45 min it should be very hot after you can feel the heat through the towels turn it off. DONT take off the towels let it sit and cool for an hour reconnect it and play. this may not work but it most likely will if it does not work you need to buy a new xbox
Nov 20, 2009 | Microsoft Xbox Console
My wii freezes in-game and won't respond at all
It almost sounds like the Wii is overheating. Make sure the unit is in a well ventilated area and that it isn't dusty (some canned air will help with that.) Also, change the orientation of the system. i.e. if it is on it's side, lay it down flat, if it is flat put it on its side.
Aug 30, 2007 | Nintendo Wii Console
Sharp Aquos LC-52SE94U 52 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
