Question about SES Trims Pillar Posts Lexus GX470 2004 2005 2006 2007 2008 2009
Glove box light and DVD changer power
No power to glove box light and dvdbchanger
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 99 Answers
Look in owners manual and locate fuse box location and fuse number and amps to lighter. I'm pretty sure this is a blown fuse problem. Remember there may be more than 1 fuse box, the lighter fuse is usally in the fuse box inside the car.
Posted on Feb 12, 2014
How to remove glove box from audi A5
After opening the glove box there should be some screws that hold it in place that can be seen. Often there are some screws holding the hinge for the door to the glove box. If there is a light inside the glove box there will also be a wire attached to the light fixture.
Jul 05, 2014 | Vehicle Parts & Accessories
2010 Subaru Outback - Glove box removal
Remove glove box damper.
Release the stoppers and remove the glove box lid assembly by pulling it toward you.
Release the clips and remove the right side instrument panel side cover.
Remove the glove box panel.
Release the clips and remove the glove box under cover.
Release the clips and claws and remove the ornament panel assembly.
Remove the screws and release the claws and then detach the glove box back panel.
Disconnect the glove box light LED connector.
Oct 04, 2013 | Vehicle Parts & Accessories
How to change air cond. filter lexus gs300 2000, has 6 disc cd changer where everyone says filter is.
It should be behind the glove box which you have to remove to get access to the filter door.
Is the CD changer directly behind the glove box ? Because in my car the changer is above the main part of the box, not behind it.
Sep 14, 2012 | Lexus GS 300 Cars & Trucks
In my lexus gs300 my cd changer is stuck and I need to know how to remove it
i had the same problem with my 99 lexus ,took front cover of frame around glove box,3 srews across the top,1 screw bottom left corner,pull entire cover comes off ,now you r looking at your cd player held in by 2 bolts 1 on each side,but i felt around the cd player found no place to push cd cartridge box out ,i got 2 dent pullers out og my tool box,DENT PULLER HAS A T HANDLE WITH A STRONG WIRE COMING OUT OF IT WITH A SMALL HOOK AT END,put one on each side and pulled came right out,turns out i didnt need to take anything apart just use the dent pullers,the problem was one of the cd wasnt in place right causing the box to exspand once it slid in the outer edge was hung on the mouth of the box,ps my cd changer is in glove box,but same scenario for trunk hope this helps GO COWBOYS
Oct 23, 2010 | Car Audio & Video
Hi i have a RX300 and need to remove the radio/CD changer as it needs to be repaired. How do I remove it?
Go to Lexus and ask for stereo removal tool. Most cars you need a special tool and once you use that it should just slide out
Aug 17, 2010 | Lexus RX 300 Cars & Trucks
Where is the blend door actuator loacted?
The actuator is on top of the heater box behind the glovebox area
Jun 13, 2010 | 2000 Lincoln LS
Well on my 300m the heater and a/c dont turn off even if i press the off button
If you have the automatic controls you'll need to replace the blower power module behind the glove box.
1) Disconnect and isolate the battery negative
cable.
(2) Open the glove box.
(3) Flex both sides of the glove box bin inward near the top far enough for the rubber glove box stop bumpers to clear the sides of the glove box opening then roll the glove box downward.
(4) Reach through the glove box opening to access and disconnect the instrument panel wire harness connector for the power module from the module con-nector receptacle.
(5) Reach through the glove box opening to access and disconnect the blower motor pigtail wire connec-tor from the power module connector receptacle.
(6) Remove the two screws that secure the power module to the evaporator housing.
(7) Remove the power module from the evaporator
housing.
Jan 15, 2010 | 1999 Chrysler 300M
Lower Glove Box Won't Close
I fixed this in a 2010 Rav4 by lowering the glovebox all the way and finding that the cover to the cabin air filter had fallen off and was jamming the hinge of the glove box. To lower the glove box, pull the glove box side walls inward until the lock tabs clear the sides of the opening and you can rotate it all the way down. Clear whatever is jamming the hinge and rotate the glove box back into position. Be sure the hinge is pushed all the way forward onto the corresponding pin before closing the glove box, otherwise there will be misalignment. There is also a plastic air piston on the right side of the glove box assembly that damps the movement of the glove box. Be sure the piston assembly is secured into the two corresponding locking pins (one on the glove box, the other on the glove box opening) before closing the glove box.
Jul 08, 2009 | 2007 Toyota RAV4
Stock radio stopped working
Have you checked the fuses. Usually under the dash or in the glove box.
Aug 14, 2008 | 2001 Dodge Neon
Cd changer
I'm not quite sure, but my expy has a cd changer in it.  The changer itself lives in the arm rest storage area (not in the back or the glove box). first step would be to see if your radio would support a changer, then I suspect you'd have to wire it up.
Aug 02, 2008 | 2000 Ford Expedition
SES Trims Pillar Posts Lexus GX470 2004 2005 2006 2007 2008 2009 Logo
71 people viewed this question
Top SES Trims Computers & Internet Experts
john h
David Hoff
Andrew Taylor
Andrew Taylor
Are you a SES Trims Computer and Internet Expert? Answer questions, earn points and help others
