Question about Shure Beta 52A Professional Microphone
Shure beta 52 not working
How do I disassemble to get to PC board
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Unscrew the grill, pull out the element.
Posted on Jul 27, 2014
SOURCE:
SOURCE: new cable for my Shure Beta 58A Professional
I scored an old beta 58 but the 3 pin connector was missing. i bought another one but i don't know which wires to connect where. plus there are only two wires, is that right? I'm a bit of a noob but I like to try things myself :)
Posted on Sep 11, 2008
  • 417 Answers
SOURCE: I have a Shure Beta 87a very weak output signal
Possible cause...microphone dropped on the ground.
Or possibly the capsule is fried from too much spit getting to it thru the windscreen.
Or possibly a short in one of the 3 pins/wires located in the housing where the xlr connects.
Posted on Apr 02, 2010
  • 611 Answers
SOURCE: we have 3 shure ulx2 beta 87a mics and they shut off after 2 bars
That is quite odd. The ULX series should get about 8 hours of battery life. It is possible that you got a bad batch of batteries. I have seen whole cases that are bad. Trying getting another brand of battery from a different store to see if you still get the same problem. If you still have the same problem, return it to Shure for repair.
Posted on Apr 15, 2010
  • 611 Answers
SOURCE: Is my new Shure Beta 87A microphone a fake
Unfortunately, there are many types of counterfeits out there. So, differences that you see posted online might not apply to all counterfeits.That is, various factories in China produce the counterfeits differently. The best thing to do is to completely avoid unreliable sources, such as eBay and Craigslist. Be extremely suspicious of any products on the internet.
Posted on Sep 07, 2010
  • 611 Answers
SOURCE: how to solder a shure beta 52 mic.....which color
The wiring can be found on the Shure website at:
http://shure.custhelp.com/app/answers/detail/a_id/2591
Posted on Jan 19, 2011
How to open a shure beta 58 microphone?
To open a wired Shure Beta 58, unscrew the handle at the mid point. A new cartridge from Shure includes the upper part of the handle.
The Beta 58A is different.
Jun 19, 2014 | Shure SM58 Professional Microphone
Can you tell me how to remove the mic head off a shure ut2 beta 58a wireless and is it compatible with any other shure wireless thanks
The Beta 58A head simply unscrews from the handle (just below the grill). It will fit all Shure handheld transmitters.
Feb 16, 2010 | Shure Beta 58A Professional Microphone
What do I need to provide phantom power to Shure Beta 87A microphone? All I have is a fender acoustasonic combo amp...
You will need a Shure PS1A phantom power supply if you want to use the manufacturers recommended part although any phantom power supply that puts out 11 to 52 volts D.C. positive at both pins 2 and 3 with a current drain of 1 to 1.2ma should work. Behringer makes good affordable ones. Check out this link:http://www.behringer.com/EN/Products/PS400.aspx Hope this helps.
Nov 24, 2009 | Shure Beta 87A Professional Microphone
Beta 52 not working, need wiring solution
I'm not positive that this is correct as the internal connection diagram isn't included in the manual but Blk= pin1, Blu= pin2, Red= pin3. Hope thats right. Shure gas lots of info on their website www.shure.com
May 22, 2009 | Shure Beta 52A Professional Microphone
Normally the the black wire is connected to pin 1, the white wire is connected to pin 3 and the red is connected to pin 2. Sometimes the wires on pin 2 and 3 are reversed so try it both ways.
May 22, 2009 | Shure SM57-LC Professional Microphone
Access switches
I assume you have a wireless mic. Disassembly is dependent on the model of the wireless. However, typically, you would pop off the switches and then remove the C ring that is under the cartridge.
Jan 12, 2009 | Shure Beta 87A Professional Microphone
I need to take apart a beta 52 kick drum mic but i can't work it out further than unscrewing the wind shield could anybody help?
Hi matt
The capsule can be released from its mounts for replacement by popping back the clips that retain it. 9f4b878.jpg
Is this what you were intending to do.
regards
robotek
Oct 31, 2008 | Shure Audio Players & Recorders
Shure Beta 52A Professional Microphone Logo
105 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
