Question about Air Ride Management 1983-1993 Opel Vauxhall, Corsa A Plug and Play Air Suspension Kit
I have Opel Corsa A 1989.Turning lights,emergensy lights and rear break do not work,I havent find broke fuse yet.Are they all in gabin left steering wheel?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Not sure what your trying to say in that last line but sounds like a possible turn signal switch/hazard switch issue. A good wiring diagram will help
Posted on Dec 30, 2013
Opel corsa baklie 1.6 sport 2007di engine light dont com on and dont haf sperk
the signal from the crank angle sensor thats mounted against the block pointing to the crank pulley is what tells the ecu that the engine is turning and to provide spark and injector pulse
so your possible problem area is the ecu
also check the ecu harness plug wires and pins
make sure the crank angle sensor is plugged in
Oct 02, 2016 | 2007 Opel Corsa Utility
Opel corsa 2006 utility 1.7dti. The roof light,
check the fuses lower dash cover should have list or look in the owners manual
Sep 28, 2014 | 2006 Opel Corsa Utility
I have a 2007 opel corsa hatchback, the indicator lights dont work, i already replaced the indicator switch and solenoid. now it still doesnt work. all the bulbs is still fine!
Check your ground points .. Check for 12V and ground at the light fixture (load) and work your way back to the relay.. Is your relay clicking when you turn on the indicator. Check your fuse.
Jan 15, 2013 | 2007 Opel Corsa 1.4
Opel corsa ac relay problem
I had the same problem with my Corsa Lite Sport. Try turning the ignition key slightly counter-clockwise when you hear the clicking.
Jul 13, 2012 | 2005 Opel Corsa 1.4
Fuse box for vauxhall corsa 1.4 S reg
Opel/ Vauxhall Corsa D fuse box diagram and descroption
Version 1
http://www.autogenius.info/en/vauxhall-corsa-d-fuse-box/
Version 2
http://www.autogenius.info/en/vauxhall-corsa-d-2009-fuse-box/
Feb 12, 2012 | Opel Corsa Cars & Trucks
The bulbs in my rear brakes keep blowing. Vauxhall Corsa
Make sure its the correct bulbs.Then you have to back probe the circuit to determine where the short is. If its not the correct bulbs issue, then I recommend you test the brake switch on the brake pedal before going any further with this diagnosis.
Apr 08, 2010 | 2005 Volkswagen New Beetle Convertible
Air Ride Management 1983-1993 Opel Vauxhall, Corsa A Plug and Play Air Suspension Kit Logo
102 people viewed this question
Top Air Ride Management Air Tools & Compressors Experts
Timllfixit
Andrew Taylor
Andrew Taylor
Are you an Air Ride Management Air Tool and Compressor Expert? Answer questions, earn points and help others
