Question about DeLonghi EC155 Espresso Machine
My Delonghi Ec155 will not pump water
The steam function works and there is The standard vibrating when I turn it to pump Espresso but nothing comes out.
    Habit-Forming:
  • DeLonghi Expert
  • 147 Answers
Your machine need to be decalcifying!
Posted on Dec 30, 2013
  • Andie Kae
    Andie Kae May 19, 2014
    I have same problem but it is brand new and my 1st time using it.
  • ken hays
    ken hays Jun 01, 2014
    I have the same problem itwill make steam thru the steamer but will not anything thru the coffee filter. the filter is clean and that is not the problem.
3 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: I have a 6 moth old Delonghi EC155 espresso maker.
The problem is that the steam thermostat is not working right and leave the boiler overheat enough to start burning the boiler pastic seal and also the overheated steam blow out some boiler dirt gather by previus use which was liying in the boiler and it was gather from water, soil is brown color.
So now if you are lucky first dont switch it on again since it might be on the starting of the problem and you can avoid it by just replacing the steam themostat. Howevr you must work it then without the top cover with extra safety of course in order to visual check if you have any other damage from the overheating like gasket burned out and or water leaking or else.
Good luck
Posted on Aug 21, 2010
SOURCE: Steam knob won't turn on brand new DeLonghi EC155
Try turning it COUNTER-CLOCKWISE. This is was got it "unstuck" for me.
Posted on Mar 23, 2010
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Tip
DeLonghi EC155 Doesn't Release Water
When I bought my EC155, I heated it up for 30 minutes and tried multiple times to run water through. After multiple attempts the water level remained unchanged. <br /> I was able to fix the problem by opening the bottom of the machine (4 star screws). After opening the bottom, I immediately noticed that one of the plastic pipes was not in the channel in which it was supposed to be and as a result was kinked and sealed off. I simply pushed it into the channel and that fixed the problem.
on Sep 14, 2011 | DeLonghi EC155 Espresso Machine
Ec155 delonghi
if you have an ohmmeter, disconnect the cables that feed the resistance and connects the ends of the meter should give a value of element 5 to 30 ohm, if you give infinite that is very high due replacement it, there are also two thermostats one limit and a control, if you use this meter their connections resistance removing the cables connecting them, the measurement should be 0, if it gives you another value or infinite must change.
Feb 09, 2014 | DeLonghi EC155 Espresso Machine
Will not water
hi as you turn the machine on turn the steam knob fully ..this will bleed your system ... if it dont bleed through replace your pump or check filter inline right side of machine ... [turn machine off befor removing main covers } 07779933829
Jan 03, 2014 | DeLonghi EAM3400 Espresso Machine
Coffee stops flowing
Run a 50/ 50 vinegar & distilled water solution through it. Only use distilled or bottled, purified drinking water from now on.
Feb 17, 2013 | DeLonghi EC155 Espresso Machine
Delonghi EC 155 does not make coffee even after I put new filter
DeLonghi EC155 Espresso Machine so what does it do?Possible nothing,and do you know your last time you ran vingar though it to CLean it out?Normally solution is Vingar depend on size put 1-cup Vingar,half cup water,run it though.then run only water then next step in full pot,do this twice.Should work fine.
Aug 08, 2010 | DeLonghi EC155 Espresso Machine
Feb 21, 2010 | DeLonghi EC155 Espresso Machine
Installed new ulka vibrating pump in my Rocket E61 (Giotto) but the pump won't prime.
If when you installed the new pump and turned it on and made loud vibrating sound but not pumping any water through what you need to do is when you turn the pump on open up your steam valve turning the steam knob. Usually it is just an air lock and this should allow the air out and water to flow through. When water comes out of the steam arm, close it off and water should then come out the group head as normal. If you try this and nothing happens you either have a build up of scale which you just need to try to flush a good descaler (Puly Baby Powder) through your machine or the pump you got is faulty.
All the best
LaPavoniBoy
Jun 10, 2009 | ECM Giotto Espresso Machine
Delonghi EC 155 general help
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Feb 02, 2009 | DeLonghi EC155 Espresso Machine
DeLonghi EC155 Espresso Machine Logo
1,580 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
