Question about Philips Magnavox PR1906C 19" TV
Philips magnavox tv volume control
The buttons activate on the screen and in the menu but will not turn up the volume for some reason, please help if you can
  • 93 Answers
If your are using a remote control,your volume button is shorted,and of you are using your manual control,your tact switch in volume is defective try to replaced  another one.
Posted on Oct 18, 2007
Ihave a philips dvd/tv remote, but i can't get it to operate my magnavox tv except on/off and volume, can you help?
There are a number of different codes for each TV, pick the one that works best for example these are for magnavox, but since I don't know the model no of your remote they might not be correct for yours! 0441, 0442, 0447, 0599, 0799, 0699, 0247, 0193, 0093, 0598
Jul 21, 2014 | Philips Televison & Video
Magnavox Demo TV
Could you please provide the model number of your TV?
It appears that the TV demo was activated by accident.
Jul 23, 2008 | Philips Magnavox 27MS343S 27" TV
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
No remote, channels locked on smart tv
On this set, the volume buttons are the same as the menu button on your remote. The two channel buttons work the same as the scrolling arrows on your remote. It will take some practice, but to turn on the menu, press both volume buttons at once. Then practice using the volume controls to scroll. Once you have the hang of it, you can simply use these four buttons the same way you would have used your remote. If you cannot figure it out on your own, come back here, let me know, and I will sit down and map it out completely for you.
Hope this helps in some small way!
Jan 30, 2009 | Philips TP2784C TV
Can not manually turn off or turn on.model number 4534900 . serial number 32850100aa. Continues to scroll menu on screen and can not be altered.
I had the same problem all I did was depress the volume buttons on the TV at the same time and the menu dissappeared.......
I hope this helps you
Dec 28, 2008 | Philips Magnavox 27MS343S 27" TV
Remote and caption problems
have you programmed the remote? or you can go into the menu button on the front of the tv, use the up down (either the volume or channel may move the selection) to locate the caption on/off control and turn it off that way. if you need the manual try here
http://tv.manualsonline.com/manuals/mfg/philips/19_inch_color_tv_cover_l9_pr1903c1.html
Dec 02, 2008 | Philips Magnavox Learning Universal Remote
Black screen covering most of tv screen at a few channels; a code appears at upper left corner. The black screen disapears for a few seconds if I turn the volume up or down at the remote control but it...
Turn off your closed caption and or text mode using the closed cation button on the Magnavox remote or through the TV's menu there wil be an option to do so.
May 24, 2008 | Philips Magnavox MS2530C 25" TV
Child Lock issue
Unfortunately the Child Lock facility disables the buttons on the TV.
You should be able to get a replacement remote control from an authorised Philips dealer, or you could try a universal remote control form most electrical retailers. Philips make a range of universal remote controls.
Instructions for activating and de-activating the child lock are in the manual. If you don't have the manual, download it here:
https://www.p4c.philips.com/files/2/27ms343s/27ms343s_dfu_aen.pdf
Mar 12, 2008 | Philips Magnavox 27MS343S 27" TV
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox PR1906C 19" TV Logo
264 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
