Question about Alpine MRP-M500 Car Audio Amplifier
No power but have 12.8 volts to the radio. It powers up when I hook it direct
I have a new system in my boat. It was working fine and then stopped coming on. I have checked the wires all is good. I am getting 12.8 volts but when I plug it in nothing. I took it out and hooked it direct to my jeep batt and in worked. Any thoughts?
bumpinjls
  • 13 Answers
SOURCE: amp problem
Make sure the amplifier setting "disable" is off then turn off remote power and turn back on.
Posted on Dec 24, 2007
simard2
  • 124 Answers
SOURCE: Alpine MRP-M500
You need to check the Fuse on the Power Wire and check the ground wire to see if has loosened up. Also check Power Wire as well.
Hope you see what you are your looking for! Good Luck!
If you have any more problems let me know.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this answer!
Posted on Jan 30, 2009
  • 150 Answers
SOURCE: can't get my amplifier to work.
My homie had the same problem with his escalade they adapted an rca line adapter from the factory wiring to geta signal to his amplifier and it just wasnt hitting like it should so we installed a new deck and plugged the rca cords right into it and boomboom pow it was hittin like a champ-we figured that the stock premium system that was incoprporated into the truck had some sort of an onboard amp that was filtering the bass from the door speakers and which was limiting the bass output to the rca adapter and thus on down the line to the amplifier- so maybe ya might want to look into getting an aftermarket deck and see if that helps your cause-good luck
Posted on May 21, 2009
  • 150 Answers
SOURCE: Amplifier wont move subs
I dont know if this will help you but start at the deck and make sure that the outputs(RCA) arent crossed over to highpass and do the same at the amp make sure that its set for lowpass- set half gain -bass boost half gain- subsonic minimum - If that doesnt help try using an i pod with an adaptor that you can play it right into the amp this is to see if you are getting signal from the deck to the amp if it doesnt work with an i pod or mp3 plugged directly into it then you may have got you a blown amp going on- good luck with that
Posted on May 30, 2009
  • 5 Answers
SOURCE: Amp light on but no sound
either something in your amp burned up, or the audio wires going from your cd player to your amp are bad
Posted on Jul 12, 2009
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
I have two amps one for my speakers and the other for my subs it was working fine but recently one of them turned off. I thought was a short circuit and bought a new one but still doesn't work. Its looped...
When running multiple amps you need a relay most of the time for the remote wire off the radio this is because the radio was built to power one not multiples. one 12 volt relay may help .check local car audio store. also when hooking up relay it has to have a 12 volt power wire connected to it usually the center pin on the relay is your connection for the power wire the you connect your remote wire from the radio to the relay then connect each amp independently to the relay. Hope this helps write back if not . and if so leave feedback
May 09, 2010 | Stingpro ST444 1850 Watts Complete...
Wanting to install motorguide 24v trolling motor in boat, will it work on just 12 v system
No. you can put in extra batteries and use it, but you must remove you charging system from them to use it that way. Not really practical.
Mar 21, 2010 | Electrical Supplies
My radio stopped working after hooking up the amplifier
Did you double check your work? Did you check the resistance of the fuses? Just because the fuse appears to be good, it can still be blown. Do you have access to a multimeter? You need to check and see if the head unit is receiving 12 Volts continuous which you put the multimeter probes to the black wire and the yellow wire. Then connect the probes to the black wire and the red wire. This wire should only have power when the car is cut on. If you are not getting 12 volts to these points, the problem is your wiring system somewhere...probably a fuse. If you are getting 12 volts, your head unit is garbage. I want to say it is the fuse.
Oct 01, 2009 | Lanzar HTG244 Car Audio Amplifier
My son and his buddy recently installed an amphlified stereo system on our center console and there is something strange going on that I can't figure out. It is a Clarion stereo with a JBL amp. The boat...
If a boat is anything like a car, the amp's negative post should not be connected to the battery, but to the ground of the boat. In a car, the entire chassis is grounded to the negative terminal, so when you run a line from the positive terminal of the battery to the positive post on the amp, and a line from the negative post on the amp to the chassis it is a complete circuit. I highly recommend placing a fuse on the positive line from the battery to the amp. Wiring this way prevents the amp from blowing up your battery, as well as prevents the battery from blowing your amp. Hope it works.
Jun 25, 2009 | JBL Boating
Clarion M5675 won't turn on
Take the stereo all the way out and hook the black wire to the negative terminal and the yellow and the red wire to the positive terminal on a charged car battey. If it still does not turn on you may have fuse in the back of the deck. If not it's probably fried.
Apr 19, 2009 | Clarion M5675-RET CD Player
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Yaesu radio transmitter receiver
Theirs no reason why you cannot plug in the 110 adapter to the 110 wall plug to power the radio.
You may also want to add a surge protector inline.
Oct 07, 2008 | Yaesu NABC NABC LMR NICD BATTERY FNB-29...
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Aug 18, 2007 | JVC KT-SR1000 SIRIUS Radio Receiver
Installing tv in boat
You can But I would not connect it directly unless I had a regulator or isolation device between the set and the boats power. if your boat has 110 volt capability just be safe and use the adaptor.
Sep 15, 2006 | Sharp Aquos LC-15S1U-S 15 in. EDTV-Ready...
Alpine MRP-M500 Car Audio Amplifier Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
