My air conditioner doesnt blow cold air turns on and blows but the air flow seems to be only a little house gets hotter and muggy
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    More information is needed if you would like to share. Size of unit in BTU's, how old? Window or Central? If window, when was it last taken out and cleaned?
    Problem Solver:
  • 4 Answers
This is most commonly cause by a lack of freon in the system. Unfortunately, the only solution to that is to call your local A/C company and have a certified technician come and charge your system. The reason you need to call a professional is because you need a special license to handle the type of freon your system runs on.
This could also be cause by a dirty air filter.
Check the air filter to see if that's it. If it isn't, you need to call a service tech.
Posted on May 19, 2009
Air Conditioner isn't blowing cold air
There are a few thing's that can cause this, if the evaporator coil in the a/c is blocked a little, you could get a little cool air, it's like having a dirty filter. If the condenser coil is blocked, you won't get cold air. If the refrigerant is low, you won't get cold, cold air.
Jul 19, 2013 | Amcor Heating & Cooling
Filter dirty and blowing warm air
If your filter is dirty,the fan inside the house cannot push the cold air thru the evaporator, cool air cannot circulate, this will cause the compressor outside to over heat and even damage it and possible trip some fuses or circuit breakers, with these hotter days you want to change out your filters more often, changing out your filters more often will keep the evaporator cleaner and allow the cool air to flow, easier.good luck!
Aug 08, 2011 | Goodman CLJ36AR42 Air Conditioner
The air conditioner blows cold when temperature is below 75degrees F, when it is hotter than that it blows hot air.
check the condensor fan make sure its working and also see if anything might be restricting ais flow through the condensor
Jun 07, 2011 | Lexus LS 430 Cars & Trucks
PART # 7330B730 SERIAL # 109734610 1997-TIMBERCREEK R.V.
most of the time the condenser coil is dirty and needs to be washed out. with it dirty the pressures are elevated and causes compressor to kick out on overload. try washing cond. coil first
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
Air Con Unit Not cooling the room
Alright, I'm obviously not there, but you could be low on refrigerant/Freon, and what is more likely, your AC is suffering from some sort of obstruction or debris, as noted in this handy diagnostic article that explains how it could cause your AC not to blow as cold air as you would like:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Hope this helps.
Brad
P.S. As to the loss of your operating manual, try to see if you can get another one directly from the manufacturer by contacting it.
Jun 04, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
150 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
