The computer runs fine but when I touch the screen it responds great, but when I tilt my screen to adjust for brightness the whole screen goes white and I have to tilt back and forth to get screen back on.
SOURCE: Laptop HP Compaq nx9420 Screen goes Blank
looose wires maby on screen under top side clip out that pice on top to see if cables looose dwas it pluged in when u droped it maby power going bad cant get enfh power to screen try that 1st new power cheak fn button make sure not defulte dto crt over onbord lcd thx nick im open for chat
SOURCE: Hp laptop screen blinks during use
You could have a faulty inverter but
You most likely have a defective CCFL backlight, it may have the following symptom:
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
SOURCE: my hp dv2700 won't turn on
the video chip on the motherboard are defectouse, you need to reemplace it or empace all the motherboard but some times it ares some expensive
SOURCE: the lightning bolt on my hp touchsmart tx2 flashes
that means your laptop has no power so your battery is dead which would explain why it shut down on you, and that means its not charging so it would either be the adapter or the port on your laptop
SOURCE: How do I adjust the screen brightness on a HP
Hi, Actually, the problem here is you don?t have any options in windows XP to increase the brightness without using keyboard. HP does not provide any utility with the OS as it is OEM. Try this · Click on start > Click on control panel..... · Click on power options.... · Click on " Change settings plan "..... · Adjust the brightness and save the plan..... And exit... that should work.... OR Replace the keyboard and get the all things working
