Question about Rite Aid Brand Rite Aid Blood Pressure Cuff Monitor, 1 Ea
Inflates to 175 and then immediately deflates
How to use the machine once the cuff inflates. The number quickly gets very high. Do I stop it at say 78? Or will it stop automatically??
it will stop automatically ans slowly deflate until it has the readings then deflate all the way
Feb 21, 2018 | The Health & Beauty
Just got my full sized intex air mattress. The pump makes a lot of noise but doesn't seem to be doing anything. How do I get it to inflate?
have yo got it connected to the mattress the right way as it inflates or deflates the mattress depending on how it is connected
Jul 20, 2017 | Intex Pool & Spa
My sphygmomanometers arrow inflates to 160 but won't come back down during deflation, what do I do?
Take it back where you bought it. Either something is broken or you need to learn how to operate the device. The druggists are good at demonstrating their paraphernalia. sphygmomanometers-arrow-inflates-160-but-xrysbksmd4oe40lchygmaasz-4-0.jpgdont forget to take your drugs.
Dec 21, 2014 | Cars & Trucks
How do I deflate spa
To deflate the portable Therapure spa 050006 is easy. The trick is to realize that the black valve used to inflate is in fact a double valve. Remove the square threaded cap to inflate it.
1. To deflate the spa leave the black square threaded cap and below that you should find a round or winged coupler.
2. Unscrew this coupler off and immediately the air will start to escape. It shouldn't take more than about 2 minutes to deflate and you are ready to pack it away.
3. Return the valve (before doing so you could use a vacuum to suck out as much air as possible.)
4. Lay out the spa floor in a circle
5. Fold the three sides to the centre
6. Then lay the power unit on the folded sides.
7. Remove the coupler one more time to squeeze out any remaining air and then return it.
8. Roll the up the side to the original size of the spa before you opened it the first time.
Sep 18, 2014 | TheraPureSpa New 2 - 4 Person TheraPure...
Suspension deflates in cold weather
air compressors do not operate below 28 degrees you have to get them warm first I assume that your compressor is under your hood as long as you allow your truck to get cold or keep the air suspension your going to have this problem
Dec 09, 2013 | 2006 GMC Envoy XL Denali
Range Rover l322 My front air supension is iactice/inflates then deflates whilst the back remains stable
They have problems with the air bag shocks leaking. The shocks typically have a large bladder bulit into them that will over time develop leaks causing the problem you describe. could be a damaged line to the shock but most often the shock. Start the car and run until it inflates. Stop the vehicle somewhere quiet then put your head by the top of the wheel that deflates. Listen and you should head an air leak. It usually requires replacement of the shock to fix.
Dec 06, 2013 | Cars & Trucks
Centrios wrist BP monitor, model 10A03. When pu...
centrios wrist monitor works to inflate and deflate monitor but displays "1" instead of blood pressure reading
May 21, 2010 | Health & Beauty
Our bottom dish drawer won't open...Help!
the air gasket is still inflated. There is a small air pump that inflates the seal, and another valve that opens to relase the air. if you can pull the machine out, there is an acess door on the back that you can get to the release valve. disconnect the small hose and it should deflate. the valve and air pump come a a two piece replacement kit
Jul 10, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Rite Aid Brand Rite Aid Blood Pressure Cuff Monitor, 1 Ea Logo
47 people viewed this question
Top Rite Aid Brand Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Rite Aid Brand Health and Beauty Expert? Answer questions, earn points and help others
