Question about Android Apps
Problem with speaker and headphone
I had a new 2Boom tab. sound came out each and every time I plug in the headphone. Sound plays both on speaker and headphone. I tried to fix it. But can't fix it
  • 1138 Answers
SOURCE: No sound coming out of the left speaker
It sounds like you have a break in your cord right where it joins the plug. You will either have to replace the plug or buy new headphones.
Posted on May 19, 2009
jovianstone
  • 7 Answers
SOURCE: headphone jack does not work, audio still plays from speakers
sound like the hardware supporting your headphones may have disconnected from its solder.This could have happened from dropping the notebook with the headphones plugged in and landing badly, or a strong or constant tug on the input. Otherwise, it could be a software configuration like you've tried
Posted on Jun 08, 2009
jeevan.m
  • 392 Answers
SOURCE: Unplugged speakers, plugged em in -- now I don't get ANY sound
check ur sound drivers.. check whether they are uninstalled, and try to check in the sound and audio devices in control panel...
Posted on Jul 25, 2009
  • 523 Answers
SOURCE: Headphone jack not working
Hi Friend,
The problem is with your head phone it may not correctly connected,kindly check it out or replace with the other headphone and check it.
Check and revert back
Thanks for using Fixya
Regards,
Ayyasam
Posted on Aug 02, 2009
  • 1138 Answers
SOURCE: sound will not play through headphones
Try here:http://www.computing.net/answers/windows- xp/headphones-amp-speakers-switching/55486.html Also:http://www.vistaheads.com/forums/microsoft-public-windows-vista-music-pictures-video/133605-sound-doesnt-switch-automatically-headphones-when-plugged.html Also:http://www.vistax64.com/sound-audio/198039-sound-doesnt-switch-speakers-headphones.html scroll down the page for the discussion.
Posted on Oct 21, 2009
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
My computer doesn't play any sound
When you plugged the headphones in, the computer automatically switched the default device to the headphones instead of the laptop speakers. Go to the control panel > Sound options. Look in the playback tab or window and highlight the speakers icon. Look for the button that says make this the default device and click on apply, click ok and exit out of the control panel.
Jan 21, 2010 | HP Pavilion dv6000z Notebook
Sound will not play through headphones
Oct 18, 2009 | Philips (33-01-031) Headphones
Headphone Jack Problem
Go to the icon tray and double click the speaker icon. Have a look in the Advanced controls to see if you have taken the mute off the pc speaker. There might also be an option to play sound on the pc speaker simultaneously with the headphones. If so, uncheck the dual play box so the sound will not play through the pc speaker when you have the headphones plugged in.
Aug 06, 2009 | Acer Aspire One D150-1587 Netbook
May 18, 2009 | Audio Players & Recorders
Sound still appear at speaker even when headphone was installed
Hello Again,
When you Plug in HeadPhones into the Laptop the Sound Playing should automatically Bi-Pass the Speakers and go Straight to the Headphones
-Unless there is a Faulty Input for the Speaker/ Headphone, Try Pushing in the Headphones More to see if the Speakers Turn Off
Hope this Works --P3NGYJ03
Jan 23, 2009 | Audio Players & Recorders
Laptop audio issues
Right click on the white speaker icon,by the clock ,Select Playback devices,when the sound box opens,select the play back tab,double click on speakers,click the enhancements tab,select disable all sound effects,click on the advance tab,select 24 bit 48000 Hz (studio quality) click test,if you hear sound,click apply and close the open boxes.Now double click on the red speaker by the clock,plug in the headphones,check the box at the bottom that says headphone virtualization,click ok.that should do it.
Please rate this solution
Jan 17, 2009 | Dell Inspiron 1420 Laptop
Sound
Check the control panel and see what your default sound device is set for.
Do you have a third party sound card like a sound blaster plugged into here?
Jun 10, 2008 | Dell Dimension 4600 PC Desktop
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
Toshiba satellite laptop
Before going to any shops, here is a suggestion that can't hurt anything.
Go to the Control Panel and click on Sounds and Audio Devices. On the Volume tab at the bottom, you will see "Speaker Settings". Click on the Advanced button. Change that setting to "Stereo headphones". You should hear the sound only through the headphones then.
Feb 14, 2008 | Toshiba Satellite A105 Notebook
Android Apps Logo
41 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
