Question about Apple iPod nano 5th Generation
Backlight on nano5 not working
The backlight on nano5 is not working. Music plays and its behaving normal otherwise.
The LED might have run out, you can head over to apple to get that fixed.
Posted on Jan 01, 2014
What do I do to Eclipse fix mp3 when it diplays "Disk Error!" upon attempting to play music?
Presumably the error is caused by a hard disk drive? In which case the hard disk will need to be checked. If there are options to do this use them. Otherwise the drive might need to be replaced.
If you bypassed the normal way of putting music onto the drive, then it might have corrupted the drive.
If there is an option to reformat the drive that might work. Or if there is a factory reset, that might correct it.
If you have music stored on the drive, which is not found anywhere else, then I think it will have been lost for good.
May 27, 2017 | Eclipse Audio Players & Recorders
C150 as not working what's solution?
Check the orange "Hold" switch on the left side of the Sansa C150, if you cannot turn on the MP3 player or if none of the buttons is working. When the "Hold" switch is up, the buttons are disabled. Slide the "Hold" switch down to activate the buttons again.
Press and hold the "Power" button until the LCD screen lights up when turning on the MP3 player. Pressing the button quickly does not turn on the device. The "Power" button is located on the front of the device, under all the other control buttons.
Replace the AAA battery, if you cannot power on your MP3 player. To replace the battery, remove the battery cover from the back of the device by pressing in on its tab and pulling it off. Remove the old battery, insert the new battery and replace the cover. One AAA battery provides approximately 15 hours of power for your Sansa C150.
Change the backlight settings to conserve battery life. This is useful if you find the battery loses power quickly during normal use of your Sansa C150. To change the backlight settings, choose "Settings" to bring up the "Settings" menu. Select "Display," "Backlight" and then a shorter backlight time. The backlight will shut off after a period of inactivity that matches your backlight setting.
5
Review your music purchases to understand what rights you've purchased to the content, if you are unable to play a track back on your Sansa C150. When you purchase music, it comes with certain rules for how you can store and play it. You may not have paid for the right to transfer the song to a portable media player.
6
Reset the Sansa C150 if it acts erratically or if you have other problems. To reset the device, open the "Settings" menu and choose "Reset All." Choose "Save" to finish restoring the MP3 player to its factory default settings. If you decide not to reset the device during this process, select "Cancel" instead of "Save."
~KenjiFox
Jan 07, 2011 | SanDisk Sansa c150 MP3 Player
Hi,the ringtone is not audible,neither any music plays,the speaker is working though,the cancel button(x)on the top right of the screen also does not work..can u help me out,thanks..Derrick
For the cancel (x) problem, try re-calibrating the screen. If this does not work that area of the screen may be faulty. A trick to get around the problem is to program one of the keys to behave like the (x). Go to Start->Settings->Personal->Buttons and assign one of the buttons to the <OK/Close> action. Then every time you press and hold the button it will behave as if you pressed (x)
Feb 17, 2010 | HTC Touch Dual Slider Smartphone
My backlight on my ipod touch turned off. how do i turn it back on?
To turn the Backlight on, move to the Main menu, select Backlight, and click the Select button. The Backlight will come on and your iPod's world will be a lot brighter.
After the current backlight time passes, the Backlight will turn off automatically.
Jun 30, 2009 | Apple iPod touch
My mp3 player turns on but goes blank as soon as the music comes on.
Change the backlight settings in the Settings menu of the GoGear if the music continues to play when the screen goes dark.
Otherwise, if the music also goes off when the screen goes blank, run a Repair in the Philips Device Manager.
Mar 31, 2009 | Philips GoGear SA3125/37 MP3 Player
Sansa clip 4 gb wont turn on
You probably already did this, but here is the proper method to change the backlight timer:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
-Tha mp3 Doctor
Feb 26, 2009 | SanDisk Sansa Clip MP3 Player
Screen wont turn on but can navigate blindly through the phone??
It sounds like the backlight has died. Screens with replacement backlights are around $100-200. Is this a 3G? If so take it to Apple to get a replacement, they are still under warranty.
Feb 09, 2009 | Apple iPhone Smartphone
Is my Zune 30gb behaving normally?
The 30 Gb Zunes unfortunately suffer from a bug that caused all of them to do this just before the new year. Keep checking the Zune website for them to address the issue. They will hopefully issue a fix soon.
Jan 09, 2009 | Microsoft Zune JS8-00001 Digital Media...
My iPod nano 2gb silver is showing a blank white screen.i've had it for close to a year and it freezes sometimes but that fixes itself when i drain the battery and then sinc it. but this time it just went...
Go throught this page
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Your ipod might need to be repaired, the apple service assistant is on the bottom.
Might be a loose connection or other failing component I don't think there is no quick fix for this.
If the problem is solved dont forget to rate as fixya otherwise there is no need to rate it. As there is noting else we could do about it.
May 15, 2008 | Apple iPod nano
Apple iPod nano 5th Generation Logo
49 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
