Question about Dell Photo 964 All-In-One InkJet Printer
My Dell Photo 964 All In One's output is not centered on the page
When I print, the output on the page is not centered. It comes out slightly crooked or uneven. Not sure why this is occurring but it is posing a problem with my homebased business. I cannot passout paper work that is uneven, very unprofessional. Please Help!!
  • angelawillia May 19, 2009
    Thank you for taking the time to help me. I followed your steps and this still did not work. I am becoming discouraged, as I do not have the funds to get a professional to look at it. If you think of anything else, I am open to try it.
    Shalom
    Angela
  • angelawillia May 22, 2009
    Hello Ed
    tried these steps too, but they didn't solve my problem. Is my case hopless or what! Thanks for the try.
    Angela
  • 469 Answers
Remove the paper supply, and check the paper path for debris, (bits of paper, staples, paper clips) as these can cause jamming and skewing of the copy paper. clean the paper rollers with alcohol, make sure the paper is a good quality, and non of the sheets are folded over in the tray, Fan the paper to break any cuttung bonds. lastly make sure the paper guides are firmly against the paper in the tray.
Hope this is of some help.
Ed
Posted on May 19, 2009
  • Ed
    Ed May 20, 2009
    Did you check the rear access door.
    If you have some Compressed air, (Computer Duster) open all the covers, remove all the paper, and blow out machine, this may dislodge debris you were unable to see, Check the paper cassette, is it seated completely in place and edge guides are firmly against the paper.
    If you have a heavy weight paper pass a couple of sheets through, to see if it clears anything.
    Try different paper, odd as it may sound, paper that is too damp or too dry can have performance effects on the machine.
    If you have some alcohol put a couple of drops on a piece of paper about dead center(Just a stain, not soaking), then feed this through the machine with a copy or print job, the alcohol will pass by the feed and separate rollers, and clean them up. try this a couple of times with different pages. this also works well if you have miss-feed problems with your document feeder..
    Try these keep in touch,
    Ed
Dell photo 964 all in one ink jet drivers for vista business sp2
That's because you don't get them from Microsoft; you get them from Dell. Since you didn't specify if it was 32bit or 64 bit I attached the link to the page that has access to both. Dell 964 Photo All In One Printer owners thread W7
Mar 09, 2015 | Dell 962 Photo All-In-One InkJet Printer
Printer Dell 964
There are some peculiar printers. These need alignment prior to first printing. If u havn't done it, reinstall the printer, during setup one stage it will ask for alignment, the place a plain paper on the feeder. A printed page will come out, place it on the scan tray (be sure of placing it properly with correct directions). It will be scaned and a success signal will appear. thats all.
Sep 04, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell Photo 964 All in One Printer
first u see cartridge is ok or u can install a new cartridge then aling from both the side first u give print of aling page and then scan the aling page i think this well solve the problem
Aug 19, 2009 | Dell Photo 964 All-In-One InkJet Printer
Printer won't finish 2-sided document
Uninstall Dell All in One Center. Download the laters drivers form http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_PHT_964&os=WW1&osl=en&catid=&impid=
it will fix your problem.
remember to choose the correct Operating System.
Jul 17, 2009 | Dell Photo 964 All-In-One InkJet Printer
I can't print in color on dell photo 964
try to uninstall ur driver and install it again
Jun 07, 2009 | Dell Photo 964 All-In-One InkJet Printer
How to get the all in one fax / copier /printer to stop printing a report after each incoming and out going fax. It waistes ink and paper.
1 Click Start Programs or All ProgramsDell PrintersDell Photo AIO Printer
964
Dell All-In-One Center.
2 From the Dell All-In-One Center, click the Maintain/Troubleshoot tab, and then click
Display the Printer Setup Utility.
Printer Setup Utility Tabs
On this tab: You can:
Send • Enter your name and fax number.
• Select a maximum send speed and a print quality for outgoing faxes.
• Choose whether to scan the entire document before dialing the number.
• Choose whether to use error correction.
• Select when to print a fax usage report.
• Select when to print a fax activity report.
this information is from the manual found here
http://support.dell.com/support/edocs/systems/PRN964/en/om/om_en.pdf
I hope this helps
Mar 12, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell 964 printer is only printing grey bars
My printer has stopped printing anything but grey bars. I got a message saying that something was wrong with the alignment. could you help me?
Aug 23, 2008 | Dell Photo 964 All-In-One InkJet Printer
Dell Photo 964
run a print head clean and alignment from computer print manager
Aug 14, 2008 | Dell Photo 964 All-In-One InkJet Printer
Dell Photo All in One Printer 964
Try printing a windows test page from the driver software, START-SETTINGS_PRINTERS-DELL964- properties,,etc. If the test page prints with color then I believe that your driver is set to print in greyscale. If you can't find that option in the driver you might try to re-install the driver from your original cd.
Aug 28, 2007 | Dell Photo 964 All-In-One InkJet Printer
Dell Photo 964 All-In-One InkJet Printer Logo
91 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
