Question about Electronics - Others
Duracell cef21 When I put mt batteries in, the lights started flashing in a blinking pattern?
3 Suggested Answers
SOURCE: My 15 min. Duracell charger keeps blinking-won't work...
When the duracell lights blink during charging, AT YOUR OWN RISK, try a reverse charge. Instead charging positive to positive and negative to negative, try positive to negative and negative to positive. I did this for 2 minutes. This solved the problem. After the 2 minutes, I gave the batteries a normal charge. You will have to force the battery and charger contacts to touch.
Posted on Jan 29, 2011
SOURCE: flashing lights
I had the same problem. 1 of four way's can fix it. #1 Put a batt. that has a little charge in that flashing spot 1st. and see if that works. #2 put the batt. in that flashing slot first and then in the 1st slot, If that did'nt work, #3 Put Batt. in backwards for 1 sec. in and out fast. and I do say very fast, In that flashing spot. #4 buy a new one. The one that fixed mine was #1 and it stoppppped flashing, The order I put them in was - 3-1-2-4 I put in #3 batt. first, it was the one flashing And it worked, You may have a bad batt. or it's on it's way out, but try It. worked for me!
Posted on Mar 31, 2011
My washing machine is only beeping and all lights flashing
I don't know the make or model number of the unit, but most likely the beeping and/or lights flashing is a digital error code being displayed. I need more info to better help you with your issue. If the lights are blinking in a pattern(ex 2 blinks followed by 4 blinks) or certain functions are blinking in a pattern over and over, that is an error code display which must be interpreted. The machine is trying to tell you where the problem is.
Aug 19, 2015 | Washing Machines
How long to take it completely AA batteries in a Duracell CEF21 charger?
Hello there,
According to this sheet.
4-6 hours Charge rate and time is dependent on cell capacity, discharge state, and operating temperature.
http://www.scribd.com/doc/18655474/06074L4-ChargersEU-CEF21
Sep 14, 2014 | Electronics - Others
How long it to take completely charged a AA batteriesbin the duracell CEF21 charger?
The most important is not the charger, the time is depending from the accumulators capacity
Duracell charger wont charge..
The blinking indicator is telling you that the batteries have been inserted incorrectly. Otherwise, the charger probably no longer works
Jan 20, 2013 | Duracell AAA NiMH Battery Charger with 4...
My Duracell battery charger has a blinking red light.Use to be a constant red then green when it was charged. Now, just red..then blinking red..then not at all.
I had the same problem with flashing red lights. Both sides on a four battery charger. I swapped the batteries to another charger and the batteries were fine. They charged normally. I put some different batteries in the charger and the same flashing light situation. Those batteries also charged normally in a different charger. I looked closely at the back of the charger and, low and behold, "made in China". Why does that not surprise me. The bottom line, it may not be a battery issue.
May 08, 2010 | Duracell NiMH AA/AAA Battery Charger with...
Replaced batteries, fires once, red light stays on. Turn off, restart, same pattern.
Hi Larry,
Change all four batteries, I think one or more were not 1.25 or more voltages.
atdlee@netzero.com
Jan 11, 2010 | Vivitar 285HV Flash
When I insert some batteries the red light begins blinking. I also have some Duracells that appear to be charging but when I place them in the appliance they are dead.
All chargers cannot charge all types of batteries. Are your Duracell batteries NiMH or Alkaline? These indications generally happen when you insert a battery type that is not rechargeable.
Dec 13, 2009 | Duracell AA/AAA NiMH Battery Charger with...
Jul 08, 2009 | Duracell AAA NiMH Battery Charger with 4...
Flashing lights
Mar 30, 2008 | Duracell AAA NiMH Battery Charger with 4...
Electronics - Others Logo
125 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
