Question about HP LaserJet 4 plus Printer
50 service problem
 HP LaserJet 4 plus Printer Problem
How can I solve the Problem of (50 service)?
When I power the printer up it goes into warmup and then issues message '50 service' with the 50 flashing. The cartridge toner is fine as it hasn't been used much. I do not have a manual to tell me what this message means.
Thank you in advance
Matti
E-mail: matty_gliana@yahoo.com
    Novelist:
  • 69 Answers
Please try below solution.
ERROR 50 - Service
A 50 service error can be either a temporary error or a permanent problem requiring service.
Temporary Error: Power off for 20 minutes to allow the capacitor on the DC controller to fully discharge. If you don't allow this capacitor to discharge, you will still get a Error 50 even if you have fixed the problem.  This may clear the error - either temporarily or permanently. If it clears the error it was most likely caused by a low power problem  i.e. low line voltage causing the power supply circuits to drop out of regulation. Low/unstable power (low line voltage, brownout condition).  If it doesn't clear the error you may have one of the problems listed below
On the HP LaserJet 4L/4ML, errors are indicated by a series of indicator lights.  This printer has four lights, Paper Jam, Paper Out, Data, and Online.
If all four lights are on, press and hold the blue panel button to display a secondary light pattern.
An error 50 is indicated by the ready and error lights with the blue panel button pressed.
Turn the printer off for 15 minutes to see if the error clears.  If not, you will need to remove the fuser assembly to perform further checks.  This requires removal of the cover, an unpleasant task, and measurement of the fuser terminals.
Note: THERE ARE FURTHER STEPS TO CHECK THE ISSUE, HOWEVER IT IS NOT RECOMMENED TO CHECK USING YOU  ARE A USER, FURTHER STEPS NEED TO BE DONE ONLY IF YOU ARE COMFORTABLE AND INVOLVES MECHNICAL ISSUES OF PRINTER.
For your convienience, I will would like to provide the web link that shows the picture of the scene
link is:
http://www.fixyourownprinter.com/reference/guides/fuser/ex
try the things that are mentioned in web link. If the issue persists, then Printer needs to serviced.
I hope that this should resolve the issue for you.
If you need any further assistance, please let me know. I'll be glad to help you.
Bye.
Posted on Oct 18, 2007
SOURCE:
WHAT IS CODE 50
Hi there!The error code 50 means bad fuser lamp.The fuser is the part of the printer that is fusing the toner to the paper.If you open you back door of the printer you will see two rollers.One pressure and one fusing.Inside the fusing roller is the lamp.When you start up your printer keep the back door open and look if the lamp goes ON.If nothing happens you need to call a service help and to replace the lamp with a new one.If the lamp goes ON but the error is there, that means your heat senor has broken and need replacing.If you have any other questions please replay!!!
Feb 03, 2011 | HP LaserJet 4 plus Printer
My printer says "50 Service"
That is telling you that you need a maintenance kit installed. The Kit includes a Fuser, and rollers. It is not cheap.
Jan 06, 2011 | HP LaserJet 4 plus Printer
Printer hp laser jet 4plus
you need a new fuser Its easy to change Just a screwdriver. I have a fuser for 60.00 and can tell you anything you will need to know. It should take about 4 minutes to complete. 805-520-3003
Feb 13, 2010 | HP LaserJet 4 plus Printer
Shows 50 service in printer window
ok its either going to be your psu unit or your fuser.... if its showing the 50 service and doesn't print anything I would definitely replace the fuser... here is a link with some more information on the matter... http://www.fixyourownprinter.com/kits/hp/K05
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Jan 06, 2010 | HP LaserJet 4 plus Printer
Error code: 50 service. What does this mean??
Blown quartz fuser lamp. Replacement kit available here for about $40.
Oct 21, 2009 | HP LaserJet 4 plus Printer
Cannot reset code 50 for service
50 error is the fusing assm. You need to replace the fuser then the error will go away.
hope this helps.
Mar 23, 2009 | HP LaserJet 4 plus Printer
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
50 service flashing on display screen
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 17, 2008 | HP LaserJet 4 plus Printer
Error message on startup
The fuser unit could be the causes. But you can try this, power off the printer & unplug the power cord for 15 to 20 minutes. Power on after 20 minutes and se whether the problem resolves, if it ok, monitor it for a while just to make sure the problem resolves
Nov 20, 2006 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
588 people viewed this question
Clive
Clive
Thomas F. Schneider
