Question about Kettler Exercise & Fitness
Kettler 07881-300 Error 10
Can run for 30 sec, then the Kettler Track Motion, stop suddenly. Can you help me
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If yours is a different model number, please reply back.
Posted on May 26, 2009
dontbother10
  • 2220 Answers
SOURCE: My saw runs for 10 secs then stops, out of fuel.
On the bottom of a hose in the fuel tank. Did you replace or disconnect the fuel lines? I think improperly plumbed. It should be similar to this.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 05, 2010
Testimonial: "It sur is nice to rumn into someone who know what they are talking about."
ma_malai
  • 96 Answers
SOURCE: can not get this to stop skipping (playing 30 sec ...
what you need to do is play a song and hit the MODE button on the side of the player Click Play Mode and select Normal. What's happening is that your device is playing in INTRO mode.
Posted on Jun 05, 2010
  • 130 Answers
SOURCE: my 60,000 btu kerosene heater runs for several
There may be a safety thermal cutout switch that is out of whack.
Posted on Jan 15, 2011
2005 Wrangler Unlimited. Why does it die suddenly?
Please Help! 2005 Jeep Wrangler Engine Suddenly Stops While ...
www.wranglerforum.com/.../please-help-2005-jeep-wrangler-engine-sud...
Oct 11, 2009 - 30 posts - ‎17 authors ... suddenly stopped on my 2005 Jeep Wrangler TJ while I was driving. ... 20 seconds later, engine suddenly died exactly as it did last week. electrical problem? shuts off while driving
Sep 29, 2012
Sudden loss of power
Mar 9, 2012
Speedo not working and dies randomly
Dec 4, 2011
won't start, won't crank
Nov 20, 2011
More results from www.wranglerforum.com
Aug 11, 2015 | Jeep Wrangler Cars & Trucks
Error code e11 I have kettler track motion , treadmill stopped working what do I do
Reset the treadmills, disconnect the power for 30 seg. or reset the small switch to the side of power button. and try again.
However you must RUN the software calibration for e11. and fix it
go to the HOOD cover motor, and follow the steps .
God bless you
Sep 30, 2013 | Exercise & Fitness
Error 51 Treadmill Kettler Track Performance
this a problem with the elevation motor. You are working with the treadmill without put in level.
You need LUBE the gear+shaft see the picture. But most importante adjust the POTENTIOMETER a little see the diagram attached.
Jan 14, 2013 | Exercise & Fitness
Kettler mondeo e2 fault
Dear Sir:
Press the keys> stop+enter +quick start in sucession and go with key down up, until the error presss SELECT, for to quick star to clear the error log. Anyway read your instruction manual.
If you do not have go for free download: www.fitness.manualsonline.com
sincerely. God bless you
Apr 22, 2012 | Kettler Overstock Dual-action Cross...
Can not get this to stop skipping (playing 30 sec of each track)
May 20, 2010 | GPX ML648B MP3 Player
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Exercise & Fitness Logo
65 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven Brandon
Steven Brandon
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
