Question about Garden
Gas line clog. How do I access the gas line and the carbeurator?
  • Garden Master
  • 2,478 Answers
On what?
Posted on Dec 29, 2013
CAR WILL NOT GO OVER 20MPH....ACTS LIKE IT IS STARVING FOR GAS....WHAT CAUSES THIS?????.....
out of gas, fuel filter, fuel pump, fuel injectors/carbeurator clogged, transmission issues would be my order of suspicion without any further info
Jan 26, 2012 | Car Audio & Video
Leaf blower not pulling fuel into carbeurator
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to replace carburetor.
Dec 31, 2011 | Craftsman Garden
I have a 1989 chrysler conquest and dont seem to have a strong vacuum comming from the carbeurator?
Suggest lots of possibilities...I assume it is NOT a TSi... so no Turbo.
If all vacuum lines are attached and in good shape, then you can have a back pressure issue, preventing the flow of burnt gas out of the engine, and therefore a low vacuum.
If you find that the Cat. converter is clogged (strong possibility...) the you can buy one...
http://www.carpartswholesale.com/cpw/chrysler~conquest~parts.html
Chrysler Conquest Catalytic Converter inv-dots.gif Notes : UNIVERSAL, 4 Cyl, 2.6L,CENTER UNIT Part # : CPWCC-70316 OEM # : Fit : 1987-1989 Chrysler Conquest (87-89)
Nov 23, 2009 | 1989 Chrysler Conquest
Loss of power will not start with air cleaner on
Your hedge trimmer is not getting enough gas through the carbeurator to run with the air cleaner in position. Do these two things:
Get a carbeurator cleaner called gumout at any auto parts store and add it to the fuel, one ounce per gallon of fuel. Also replace the air filter as they often look alright but are actually clogged with tiny particles of dirt.
Aug 01, 2009 | Garden
Lawnmower wont start
your carbeurator is gummed up. a common problem after the lack of use in the winter season. Since you havve a new plug you are partway home. Empty out any old fuel and put in new fuel which you buy now at the gas station. Then buy a can of carbeurator cleaner. Remove the air filter. Look and see if it is dirty, if it is replace it also. Spray two short ssquirts of carbeurator cleaner into the air intake opening exposed while the air filter is removed.
Pull the cord and try to start the engine. Even if it won't start you will be drawing the cleaner into the carb. so it can start to dissolve the problem gummy deposits. Wait half hour and repeat the spray and the attempt to start. If this fails after four attempts you will probably have to remove the carb. and soak it in carb. cleaner for three hours to dissolve the gum.
May 23, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
It only will run when i spray gas in th carbs
most likely the carb is clogged with old gas. normally caused from letting the gas sit without running the bike for a while
May 21, 2009 | 1985 Suzuki GS 700 ES
Trimmer will not start.
Yes. Your carbeurator is gummed up. Get some new gasoiline and add some carbeurator cleaner to it, usually one ounce per gallon. Dump the fuel u have in there and put in the new fuel.
Also, get some spray carb. cleaner, remove the air filter and put a couple of squirts into the air intake chamber. Then start it.
Finally if it still won't start, use a squirt of starter fluid to get things going and get the carbeurator cleaning into the system.
May 20, 2009 | Troy Bilt Tb70ss Gas Trimmer
Won't run at a constant speed.
Your carbeurator is gummed up. Put some carbeurator cleaner additive in your fuel, making sure that it is fresh gasoline, not gas that has been sitting in a can all winter. Also, spray some carb. cleaner into the air intake which is accessable by removing the air filter. Finally, if the air filter is dirty, replace it. happy power washing!
May 18, 2009 | Karcher 2500 PSI Pressure Washer
Its starts but will cut off
The problem you are having is due to dirt and gunk in the carbeurator. Spray a carbeurator cleaner into the air chamber [remove the air filter] and run it a couple of times then let it sit for two hours while the carbeurator cleaner does its job of dissolving any debris. Then start it up. IF this does it, great, if not repeat the cleaning technique.
If all of this doesn't do it, then the carbeurator will have to be removed and either replaced or rebuilt.
May 06, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Wont start
the problem is that your carbeurator is gummed from from sitting idle all winter with gas in it. Get an aerosol can of carbeurator cleaner, remove the air filter and give the air intake two squirts of carb. cleaner. Then start the mower. When it stalls again let it sit for an hour while the carbeurator cleaner works at dissolving some of that gum. Repeat the process until the mower runs again. Sometimes there is so much junk in the carb. that you have to remove it and soak it in cleaner for about three hours, and then rebuild the carb. with the proper little kit. hopefully you won't have to take this step.
Next fall let the mower run out of gas and stall then you won't have the gum in the carbeurator in the spring.
Apr 04, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
