My Google Android TV Box CS918 remote not working
I have an emish tv box the remote switches it off and on if I press it after about 5 seconds. But if I switch it off with the remote i have to use switch on back of box to switch back on
DIRECTV - Support: Your Remote Control
www.directv.com/DTVAPP/equipment/demoInfo.jsp?assetId...
DIRECTVTrying to get your DIRECTV remote control to work with other devices? ... TV Power On & Off - If your receiver turns off while the TV turns on, press TV Power On ...
Program the remote for your TV - Fiber Help
support.google.com > ... > About the remote control
GoogleThe Google Fiber remote control is not designed to fully control external audio equipment. ... Press and hold the button on the original TV remote that you want to program on the Google Fiber remote. If the learning works, the TV power button on the Google Fiber remote blinks twice ...
Dec 26, 2015 | Televison & Video
Tip
What to do when your remote doesn't work or it is lost
If you have an Android device that has infrared you can download SureMote Universal Remote for free from Google Play. It supports thousands of devices, TVs, Xbox, DVD players, AV Receivers etc
SureMote Universal Remote Android Apps on Google Play
on Apr 26, 2015 | Universal Remote Control Televison & Video
I threw away the instructions. how do I program it to work on my tv. It's a one for all controler
If you happen to have an Android phone with infrared why not try SureMote universal remote for free and then you don't need to worry about the manual. Link to Google Play:
There are simple setup instructions here:
Support
Apr 25, 2015 | One For All Televison & Video
Android 4.4 Smart TV Box CS918 rk31dkFrom time to time, the screen goes black for about 1.5 -2.5 seconds then restored and then again and again continues all the time. This happens during setup and during...
Usually caused by weak or narrow wi-fi signal. Try getting a stronger signal from your wi-fi router box. Move it closer or reorient the antenna.
Maybe that will help.
Feb 10, 2015 | Televison & Video
Have a ZTE android phone ,can it be used as a
It depends on if your phone has IR capabiltily. My LG Volt has this feature and I can control my tv with my phone, or if you have a cable box. Just google the model of your phone along with IR feature next to it.
Oct 16, 2014 | Android Cell Phones
I need Aquos LC-37D43U firmware
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 04, 2014 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver.
All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear.
Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off.
Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
Nov 23, 2011 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
172 people viewed this question
Top Televison & Video Experts
Electro Med Services...
