Question about Wahl 9307
I dropped my 9307 on the floor - do i need to replace blades
Putting a wahl 9307 back together
You will notice there is a little hook that the spring thing fits into on the device. You want the smaller part of the spring facing upwards and it should tuck in smoothly.
This is the smaller part of the spring facing upwards:
Then it gets tucked in as such:
Take note from the above photo that the square edges on the plastic piece go at the top of the blade piece and the rounded edges are at the bottom.
Then the bottom blade piece rests on top with the curvature facing upwards: putting-wahl-9307-back-together-g0fa4lo4hxabacpjggd4qk4j-2-5.jpg
The rest should be straightforward!
Jul 10, 2014 | Wahl 9307
Cannot re-install spring
There is a small edge stick out at the base of the hollow mouth of trimmer. Put the spring in such a way that both the legs sticks out facing downwards. Once spring is installed, then slide the plastic holder (with rails) of the top blade on the spring and keep holding until you put together the bottom piece and tight it. Easy
Apr 09, 2013 | Wahl 9307
Parts for a 9307a
Feb 10, 2013 | Wahl 9307
How do you put that little metal piece back n???? on the 9307 model trimmers....
boottom peace goes that small goes first then the big peace goes on to of that.
Mar 12, 2011 | Wahl 9307
I need a fan blade for a Aloha Breeze floor fan
check the big box stores for replacement blades.
Sep 28, 2009 | Dryers
Where is the serial numbe ron the box?
Here are the bundled keys for Adobe Photoshop CS4:
1330-1473-8986-0777-1066-0841
1330-1149-8680-8826-2079-9036
1330-1193-3970-6999-1448-5950
1330-1258-6735-8548-6856-6068
1330-1179-3258-0293-7610-2519
1330-1409-6829-9786-8399-8047
1330-1680-7727-3628-3873-7625
1330-1321-2573-8243-5596-2306
1330-1836-2639-4367-7210-1791
1330-1070-9423-5792-3477-3630
1330-1936-7146-7221-5976-4469
1330-1615-1299-3019-7242-1546
1330-1043-6516-1505-2924-4405
1330-1614-6908-3941-2384-0909
1330-1443-6987-9307-7405-4256
1330-1252-9271-7220-3985-4522
1330-1692-9040-8033-4000-5264
1330-1364-9655-9747-2144-4369
1330-1011-7905-1557-1505-9767
1330-1266-1613-1692-9307-6182
1330-1149-8680-8848-6856-6068
1330-1179-3258-0293-726-2079-9036
1330-1258-6735-85610-2519
Just select one of them.
Aug 27, 2009 | Adobe Photoshop CS4 Extended Full Version...
Where do i put the oil to oil the blades
When oiling clippers you want to have them running and tilted blade down toward the floor. You put about 3 small drops right on the running blades. Then wipe off excess oil with a towel. You dont want the oil running back into the motor of the clipper. You should oil them about every other use. Good Luck!
Dec 30, 2008 | Oster 76076-040 Hair Trimmer
Replacement fan blade for fan
I have one of these pieces of junk. The motor swarmed, so the rest of the fan is perfect. I'll sell it for $10.00 plus shipping.
Skip marinaman@aristotle.net
Jun 13, 2008 | Patton U2-1487 Floor / Box Fan
Wahl 9307 Logo
67 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
