Question about Antifreeze Fluid Handler, 15 Gal, 30In Dia
Furnace does not turn on or off automatic - Antifreeze Fluid Handler, 15 Gal, 30In Dia
  • 336 Answers
Year & model May be flame sensor!
Posted on Apr 30, 2014
Furnace mounted humidifier when set thermostat to operate automatically it kicks the solenoid on but when the furnace shuts off the solenoid stays on When I turn it off at the thermostat it shuts off
Without knowing the exact humidifier and how it's wired one can only guess.
There are many different ways to wire a humidifier, one method involves the use of a current sensing relay monitoring the operation of the furnace fan motor. Another uses the HUM terminals on the furnace to control the humidifier.
Has the humidifier ever worked properly? If so, a component has failed. If not, it wired incorrectly and you need to refer back to your installation manual.
Oct 28, 2016 | Humidifiers
Furnace will not run when hooked up to electricity
Go to your thermostat and access the fan mode. Change the fan mode to Automatic, AU. This will stop the AC fan from blowing when the furnace is turned on. If the fan mode is on Hi or Lo and the furnace is turned on it will turn on the AC blower. Bad design...
Mar 02, 2014 | RVs
Arcoaire furnace ran out of propane and now wont ignite
Check along the gas supply line to the furnace and make sure there isn't a valve that is shut off. If you have a gas oven see if the ranges light and have gas. I'm assuming you've also turned on the gas supply at the furnace itself as well. Check that the furnace has electricity it won't be able to open the automatic valve let alone fire the igniter. My brand new furnace had a safety switch that went out 3 days after installation preventing it from lighting. You might contact Arcoaire about that. http://www.arcoaire.com/
Dec 23, 2013 | Ovens
I have a carrier 58RAV050-12 and my furnace won't turn on. It was working earlier today but it just stopped. Any suggestions as to why?
Check the pilot lt. If its out shutdown your furnace and call a repairman. If the pilot light is on, the flame sensor might have gone out. It's a long silver sensor that sits in the pilot light flame and senses when the flame is present. If it isn't working the furnace will automatically shut down.
Nov 04, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Why does furnace fan run continuously?
No on the thermosat go and check fan is not on the summer switch setting , if the fan is running it could be the AFC automatic fan control not shutting the fan off
Dec 29, 2012 | Honeywell Heating & Cooling
Reeeeeeeeeeeeeeeeeeeeeeeeee
  • Hey, nofarmark91
    Turn the Coleman furnace system switch to the "Off" position on the electric service panel.
  • Locate the manual reset switch near the left side of your furnace blower. Your Coleman furnace has an upper limit switch for manual reset and a lower limit switch for automatic reset.
  • Press the reset button, which you will find in the middle of the limit switch. Use this manual reset button when the furnace burner will not operate. (See Reference 1 pg 4 "The Furnace Controls and their Function/Important" & Reference 4 # 3)
  • Turn the system switch to the "On" position.
  • Good Luck
    Jul 29, 2012 | Coleman Heating & Cooling
    If the furnace will run one cycle after manually turning on and then shuts off and does not turn back on automatically what does this mean?
    dirty a coil,dirty filters,lack of air flow ,too many registers closed will trip high limit.furnace will run again after cooling down and turning power off and back on.till limit gets too hot again.
    Dec 20, 2010 | Coleman Propane Forced Air Heater...
    Install automatic ignition system for a coleman furnace
    For sure turn off the power at the breaker!! Now as far as the new board, usually the new board will be a new modified replacement, the wiring will be different from the original. It is very important to follow the installation instruction that come with the new board, if you go step by step, it will be ok. Just don't be surprised when you find that the new one is not exact. It is all in the name of improvement, follow the install manuals, step by step. As a 30 year Heating and cooling tech, it was very worrisome when they started doing this, but as long as you have a board that matches the brand and model of your furnace, it will be ok.
    Good Luck,
    Paul Gibson
    Mar 31, 2010 | Coleman Heating & Cooling
    Will not turn on when set to automatic. when switched to on position no hot air comes out of vent.
    If you are talking about the switch on your thermostat, "On" and "Automatic" refer to the fan. In the "Auto" setting, the fan only runs when the furnace is running, in "on" setting, it runs the fan constantly. Your furnace is not firing for some other reason, the on/Auto switch is working properly.
    Dec 16, 2009 | Goodman GMS90703BXA Heater
    Antifreeze Fluid Handler, 15 Gal, 30In Dia Logo
    18 people viewed this question
    Top Gray Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Gray Vehicle Part and Accessory Expert? Answer questions, earn points and help others
