Question about Canon PIXMA iP1600 Printer
My prixma IP 1000 has message "Waste Ink Tank full, contact Service Engg."
How can I solve the problem showing " Waste Ink Tank Full"  how can I solve the problem without calling Service Engg.
  • richard molnar Nov 07, 2007
    thank's
    fixed my prob. with a full waste absorber
    rembo
  • Anonymous Apr 01, 2014
    No black ink shows even though my ink tank is full
On Canon Pixma iP1600 it's the same?
Posted on Oct 16, 2008
Thank you very much
Posted on Jul 18, 2008
    Novelist:
  • 69 Answers
Please try below steps on your Printer and let me know the result. I hope this should work.
Steps are:
 Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
This should work. please let me know the result.
Bye.
Posted on Oct 18, 2007
My canon printer 1p 1000 says the waste ink absorber is full contact service center
hi
you need to replace the absorber waste container. But to ensure you can work around this, do this first. Remove the square rubber at the end of the right side of your printer. Use cotton cloth absorb the waste ink. Clean and wipe the ink around area and place the absorber back into the tray.
Finally clean your print head by using dry cotton swab. If this deosnt work, try this: if it doesnt solve the issue, you must replace absorber waste ink tank .
  • You can manually override it, but I recommend getting it replaced.
please send me 4 thumbs up
Jul 20, 2011 | Office Equipment & Supplies
My Canon Prixma ip 1000 printer stopped working due to something like a chamber that catches residue ink being full. Please suggest how I can repair this?
CANON WASTE TANK RESET CODE
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
or
Canon will sell you a new ink absorber pad.
Their phone #732-521-7230 M-F, 9:00 am to 8:00 pm eastern time.
Feb 28, 2011 | Canon Pixma iP2700 InkJet Photo Printer
A window displays inktank full and the printing is cancelled, when i give the print command ? what sould i do? when showed to an expert ,he told i need to update the firmware. Is this the solution ,if yes...
I suggest a window display "Waste Ink Absorber Full" or "Ink Tank Absorber Full" . It has to be reset.
4 step to Reset waste ink tank counter CANON PIXMA iP 1000
If that not work just write on kernel84@abv.bg , and i send you a software to reset your printer.
Jan 18, 2011 | Canon PIXMA iP1000
There is a message that ink absorber is full and contact tne service centre.
Need to reset waste ink absober full.
Follow this step to reset waste ink absober full.
1> download iptool to reset waste ink absober full
Download here ----> Service tool 1
Service tool 2
After ypur download finish
> turn off your printer power switch
> open your printer cartridge door
> press and hold on/off button (never release)
> turn on printer power switch
> push your printer cartridge door switch with pen or anything can press door swith.
> then release on/off button
> close open door
> then press on/off button 1 more
now your printer is in normal mode( no orange led blinking)
Then you can use ip service tool to permanent reset waste ink absober full.
Extra download
Fixwasteinkoverflowip1000
Jul 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
<Remedy>
1.Waste ink absorber
Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
absorber. Replace if the waste ink level is near the limit (14400).
After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
Apr 04, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Showing waste ink container full, contact an
You need a special software to clear this error.Look here.
Oct 27, 2009 | Canon i350 InkJet Printer
Waste ink full
Dear sir,
You clear the EPROM chip. its cant possible at u r home. Better you bring it to service station for cleak ink.
Cheers
Jaggu
Sep 21, 2009 | HP LaserJet 1020 Printer
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Question for canon pixma iP 1000
folow these steps to reset it..
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
Nov 02, 2007 | Office Equipment & Supplies
Canon PIXMA iP1600 Printer Logo
226 people viewed this question
old marine
old marine
