Technika sound bar - I've just brought one of these and plugged it into my samsung ue40f6400 smart tv using the red and white type cables....simply cannot get it to work...help
    Top Expert:
  • Televison & ... Master
  • 45,079 Answers
The soundbar power supply may have failed. If a remote was supplied, it may not turn on the soundbar.
Posted on Dec 29, 2013
  • Jennifer
    Jennifer Dec 30, 2013
    The soundbar works, I can use it with my phone via Bluetooth. It just won't work with my tv
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Posted on Nov 29, 2008
eltoyosi
  • 8 Answers
SOURCE: connecting playstation
good day,
i am eltoyosi and am here to help you.
the first question i will ask you is this.....does your TV set have an av-output?
if it does then make sure you plug the AV cords from the game in the following manner...........
the yellow cord is for picture display and make sure it goes into the yellow cord on your TV set.
the red and white cords are both for sounds of the left and right speakers on your TV set. try this connection and you are set to have fun with your game,
thanks.
Posted on Jan 25, 2009
  • 453 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
u need a main signal board replacement
Posted on May 08, 2009
  • 57 Answers
SOURCE: No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
Posted on May 26, 2009
welcomejee
  • 10594 Answers
SOURCE: I cannot get my PC sound to play through my Samsung LE32457A HDTV
I hope 3.5mm to twin phono would have plugged in headphone jack of PC to get sound for TV, right?
Reduce PC volume level up to zero and increase it very little bit to get sound in TV.
TV is getting excessive sound level from headphone jack and causing mute circuit to activate to avoid any internal damage.
Posted on Sep 26, 2009
Testimonial: "Good advice, but didn't work. :("
Just purchased a Panasonic sound bar and Samsung tv. The sound bar is hissing at low vol from one end. Should I return to the shop or is there a setting issue?
I would check your cable connections. If you are using an analog Red & White connection flip the red and white connections and see if the hissing sound changes to the other end of the sound bar. If it does then try new cables.
If you are using a 3.5 mm Stereo headphone plug then try a new cable and see if the hissing vanishes.
If the hissing doesn't change then take the soundbar back it is likely a defect in the internal wiring., either bad grounding or a short in the wiring.
Jan 14, 2017 | Samsung Televison & Video
OH. I have a DVD player/VCR Recorder. I have Cable TV. How do I connect DVD player/VCR recorder to Samsung Smart TV?
Unless your DVD/VCR is Upconverted to use HDMI, then you would use either the RED/GREEN/BLUE + Red /White leads to your TV and then use the TV remote to select whichever your TV names that input. If it is Upconverted, then simply plug the HDMI cable into a spare HDMI input.
Oct 06, 2016 | Panasonic Original Pansonic Tv Vcr Dvd...
I want to connect my stereo to the tv to work like a sound system. What plug on the to do I have to use
You will need a cable with red and white RCA plugs at both ends. Audio out from the TV Red And White jacks on the rear or side of TV to red and white AUX jacks on your stereo Most older flat panel TV's have the red and white audio out RCA jacks **NOTE Newer flat screens like Samsung Smart TV only have digital sound output, or HDMI and if your stereo doesn't have an optical sound input. You can buy a digital to analog adapter at Best Buy or Wallmart. Hope this helps!
Feb 14, 2016 | Televison & Video
How do i connect a technika TKSBSE213 soundbar to a telly
Does your TV have a Digital optical port? It's a cable that sends a red light source. That is actually how you're suppose to hook up a soundbar. digital optical cable Bing images Straight forward. Plug and play. If you're TV doesn't have an optical port, as I know your soundbar does then you have to use a stereo Y Cable. 3.5mm to Red/White. Sound bar will have 33% the power going this way as opposed to an optical cable. Aux Audio Out has a itty bitty amp pushing power. Purpose of the Digital optical Cable is a light source.
Jan 18, 2015 | Audio Players & Recorders
My sound bar didn't come with the red/white aux cables. I had some at home. I plugged the red into the red, and white into the white, but, it's not working. And yes, the soundbar is on. My input lis
Think you can set sound bar to play via Bluetooth .go into the settings of the tv and look for Bluetooth.when the sound bar is on make it discoverable and the tv will pick it up.if you don't have Bluetooth then check to see if there is an option switch in settings to use external speakers.check cable and also check volume on sound bar is not muted.also see if you can link the tv to sound bar via optical link cable as this is much better than RCA red/ white audios which tend to fail as people pull on the cable rather than the plugs when removing them from equipment.
Dec 12, 2014 | RCA RTS735E Home Theater Sound Bar
I have a proscan with no sound so I brought a
You hooked up the sound bar to the cable box red & white sockets, right. Now you have the soundbar hooked up to the TV red and white sockets. Did you notice any difference with the labeling on the two sets of sockets? The cable box sockets were labeled "Audio Out", but the TV sockets are labeled "Audio In"
AV signals are directional. Any socket labeled "Out" will give a signal from it for connecting to another device e.g. the connection from the cable box to the soundbar.
Any socket labeled "In" is designed to accept a signal from something else, but it won't give a signal out. So you can't connect the TV's Audio In socket to the soundbar's Audio In socket because both expect a signal from something else and neither supply a signal out.
Check the back of the Proscan TV. Is there a socket labeled Audio Out? If so, use that.
Sep 03, 2014 | Televison & Video
Connecting sharp soundbar to new samsung smart tv?
Your TV does not have an audio out. If you want sound thru the sound bar then you have to hook it to your cable or satelite sourse.
Mar 21, 2013 | Samsung Televison & Video
How can I connect a sound bar?
Buy a digital optical cable and plug it in the audio output of the TV and into the audio input on the sound bar. If there is no digital input you can run it with a RCA cable (3 cable red, white, yellow) or just simply an HDMI cable.
SONY eSupport How to connect TV Sound Bar system to television
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Feb 15, 2013 | LG 42CS560 42 Class LCD HDTV
Getting surround sound from tv
The only way to get the surround sound by your set up box to your system by audio connections ok other than you cannot get from TV surround sound.
Dec 21, 2008 | Philips HTS3450 System
Televison & Video Logo
176 people viewed this question
Top Televison & Video Experts
