Tv will not power on , red indicator lamp is lit on lower left front corner
  • Televison & ... Master
  • 722 Answers
The problem lies in the power supply section. Please consult some qualified technician.
Posted on Dec 30, 2013
My allegra tv will not turn on
Could be an open internal fuse. The red light merely indicates power is getting to your TV.
Aug 03, 2016 | Televison & Video
Red light lit on front panel indicating a bad lamp
It'll likely be right behind where the power cord from the TV comes from.
Dec 07, 2007 | Mitsubishi WD-52525 52" Rear Projection...
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Red light on front flashes 4 times and picture comes on for 1 second then goes dark and red light flashes
THE FOUR BLINKING RED LIGHTS INDICATE A FAN PROBLEM. CHECK IN THE BACK AND MAKE SURE THE FANS ARE SPINNING ON POWER UP.THE PROBABLE CAUSE IS THE LARGE LAMP FAN LOCATED ON THE LOWER LEFT WHEN LOOKING AT THE BACK OF THE TV
Dec 15, 2009 | Sony KDS-R50XBR1 50" HDTV
Suddenly pic went out. Loud crackling and popping heard. Now, Blue indicator and red power light continually flashing. I think lamp. Unit 3 years old
the lamp has blown replace if got instruction book that came with tv shows you how if not got the lamp is behind cover on side or frount cover that comes off by undoing two black screws on back corners (each lower corner) anda sharp pull will remove cover
Dec 13, 2009 | JVC HD-56G786 56" Rear Projection HDTV
Where is the lamp located in a 62" mitsubushi tv dlp wd-62327? am trying to install the lamp and can't find it.
Some of their models require taking off the lower front panel. Some are in the back to the lower right corner. There is a cover about 6x6 that is removed usually with two screws and the same for the front except it will be the lower left after the cover is off.
Nov 17, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Televison & Video Logo
Top Televison & Video Experts
